TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > Fixing side mirrors that keep adjusting themselves
      10-25-2014, 08:03 PM   #1
Drill
Australia
71
Drives: e92
My drivers side mirror seem to move by itself and was in a different spot each time i got into the car. Really sick on having to adjust it back to the right spot all the time.... Found a DIY on the net so had a go and problem fixed....
Thought I'd rewrite the fix cause I cant find the link to the original DIY
hope this helps....
Problem: Drivers side mirror keeps moving from where you set it
Cause: Corrosion on the mirror motor connector pins
Fix: Remove mirror glass, motor, clean pins
Time: Approx 15 mins
Difficulty: 2/10
Notes:
The drivers side mirror adjusts automatically to the last position in the seat memory/key fob (regardless of if you have auto adjust on or off in idrive)
Corrosion on the mirror motor pins can cause the mirror to self adjust to the wrong position
The passenger side mirror does not self adjust.
Some people have reported that their passenger side mirror will point down to the ground. This is normal. Its a feature to help see the curb when reversing.
The feature is activated by having your mirror switch in the right position. If you want to turn this function off, keep your mirror switch in the left position
The following fix is for the drivers side mirror problem
BSG33530.50
      10-25-2014, 08:09 PM   #2
Drill
Australia
71
Drives: e92
Step 1 - Removing mirror glass
The glass mirror is glued to a plastic backing plate that clips onto the mirror motor inside the mirror casing
It is pops off easily with a bit of light prying with a screw driver inserted behind the mirrors plastic backing plate
Use light pressure, working around the mirror until it pops off
Careful not to drop it !!
BSG33530.50
      10-25-2014, 08:13 PM   #3
Drill
Australia
71
Drives: e92
Step 2 - Disconnecting the mirror
Depending on the type of mirror you have (heated, folding etc) there will be a number of wires to unplug before you can free the mirror
Mine is the basic version so there are only two small wires to disconnect
Unplug them and put the mirror somewhere safe
BSG33530.50
      10-25-2014, 08:18 PM   #4
Drill
Australia
71
Drives: e92
Step 3 - Removing the mirror motor
The mirror motor is secured in place with a single torx screw
Remove the screw and put it somewhere safe
The mirror motor is now held in place by a connector behind the motor, simply pull the motor towards you and it will pop off (feels like it is still screwed in but it is not, just takes a little effort)
BSG33530.50
      10-25-2014, 08:21 PM   #5
Drill
Australia
71
Drives: e92
Step 4 - Exposing the corroded connector pins
With the mirror motor out, turn it over and you will see the connector pins that need cleaning.
To get access to the pins, remove the mirror motor back cover.
Simply pull the cover at the 3 tabs and it will pop off easily
BSG33530.50
      10-25-2014, 08:24 PM   #6
Drill
Australia
71
Drives: e92
Step 5 - Cleaning the corroded connector pins
Using a emery board or small nail file, lightly sand each of the pins to remove any corrosion. Take care not to bend or break any of the pins, don't go crazy, a light sand is all that is needed!!!
BSG33530.50
      10-25-2014, 08:34 PM   #7
Drill
Australia
71
Drives: e92
Step 6 - Reassembly and testing
Reverse the process to reassemble:
* Take care to align the corrector pins and the blue connector when plugging back in the mirror motor.
* Don't forget to plug in the wires onto the right connections before refitting the mirror
* Push the mirror in the middle (not the sides) when refitting the mirror to the mirror motor
To test, get in the car and insert key fob without starting car
Adjust the mirror using the controls to make sure everything in connected properly
Remove the key fob from the ignition and without getting out of the car, lock and unlock the car with the key fob.
The mirror should move to its set position. Test it out by adjusting the mirror to another position and seeing if it goes back to the same position when locking/unlocking the car
If everything is working, adjust the mirror to your desired position and store the new setting in the seat memory before removing the key fob
Key and seat should now be programmed and the mirror should reset correctly each time you open the car
BSG33530.50
      10-26-2014, 01:38 AM   #8
lemonpark
lemonpark's Avatar
Australia
58
Drives: '08 335i E92
nice! I'll try this out, I was starting to think it was weird how the mirror kept moving, not by much but it still was moving, and after having s horror movie marathon, not the best ://
      10-26-2014, 01:48 AM   #9
Drill
Australia
71
Drives: e92
My guess is your car is possessed so this fix wont help you lemon
      10-27-2014, 04:48 PM   #10
ATTN
ATTN's Avatar
Australia
96
Drives: 335 E92 DCT
2009 BMW 335i  [10.00]
Nice DIY
      10-28-2014, 05:19 AM   #11
Drill
Australia
71
Drives: e92
Originally Posted by ATTN View Post
Nice DIY
Thanks Attn
      10-28-2014, 10:20 PM   #12
Testercles
Testercles's Avatar
Australia
Drives: 2008 E90 335iA
Thankyou so much. The original DIY that I printed out seemed like way too much hassle for me to tackle myself. This seems doable
Current: 2008 E90 335iA Sparkling Graphite Metallic
Past: 2009 E90 LCI 323iA Black Sapphire Metallic, 2005 E46 325iA Black Sapphire Metallic, 1992 E34 535iA Glacier Blue
BMW Driver's Club of South Australia member
      10-29-2014, 02:23 AM   #13
Drill
Australia
71
Drives: e92
You are welcome, it is pretty easy, I'm not mechanical at all and i was able to knock it over in under 20 mins. Good luck
      11-16-2014, 06:52 PM   #14
greg328
Drives: 2011 X5 MSport
I'm having the same issue with my 2008 335i coupe. Driver's side mirror re-sets almost every time the car power cycles.
I'll try your method. I heard that a bad footwell controller could be the cause but I'd rather that not be the case!
Greg
Houston TX
      01-11-2015, 06:33 AM   #15
dizzy_7
Australia
Drives: 335i E93 MY08
Anyone having problems with the passenger side?
I have the mirror move down when in reverse but then when it readjusts back up it is all over the place.
Do you think this could be the same fix for the passenger side?
      01-11-2015, 08:01 AM   #16
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Sounds possible
Give it a go and let us know if it works
      01-11-2015, 09:22 AM   #17
AYEDEE
AYEDEE's Avatar
Australia-Aboriginal
56
Drives: 3 Series BMW
Lol. Thats actually a feature used to help you park so you dont gutter your wheels. The mirror points downways to lookk directly at the kerb. Also helps in carparks so that you can see the markings on the floor. If you dont like this feature on the master window switches theres a sliding knob that you slide to the right which will deactivate the function.
      01-11-2015, 08:59 PM   #18
Midlife_C
Australia
Drives: 2010 335i
I am pretty sure you need to slide the switch to the left (as if adjusting passenger side window) in order to deactivate this feature.
      01-11-2015, 10:15 PM   #19
320i_Beemer
320i_Beemer's Avatar
Australia
Drives: 07 320i E90 Executive
Great thread
      01-11-2015, 10:30 PM   #20
AYEDEE
AYEDEE's Avatar
56
Left or right! Haha. Well just jam the car in reverse hold staionary, flick the switch either way and yull know lols
      01-12-2015, 04:44 AM   #21
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
4th para in the DIY talks about the passenger mirror feature
I took from the post that the mirror was going crazy after returning from gutter view mode
      01-12-2015, 06:11 AM   #22
dizzy_7
Australia
Yep..
i know the mirror tilts down for reversing.
When you move back to park or drive it sometimes does not return to the position it was before tilting.
I am going to give the cleaning a go, just waiting on some dielectric grease.
