Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > Fixing side mirrors that keep adjusting themselves
      01-12-2015, 06:16 AM   #23
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Didnt bother with grease and worked just fine.... no problems since
Apparently frequent car washing can cause the pins to corrode as water gets under the mirror caps. I avoid directly hosing the mirrors now
      01-12-2015, 06:19 AM   #24
dizzy_7
Australia
Drives: 335i E93 MY08
I just bought some on ebay for $10.
If anyone needs it for theres, free to use, im located in Sydney.
I doubt ill ever use it for anything else.
      10-22-2017, 12:17 PM   #25
SeanCon
SeanCon's Avatar
Drives: 2008 BMW 335i
THANK YOU! This has been driving me insane for too long...
Build Thread | '08 E92 335i | Pure | MHD | VRSF | M-Sport |
      10-22-2017, 02:59 PM   #26
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Haha ur welcome
SeanCon101.00
      10-30-2017, 04:37 PM   #27
satz
Australia
336
Drives: 2019 BMW X3 M40i
Slightly related question, do the 2009 built E90s have auto-dimming and heated outside rear view mirrors?
2019 X3 M40i, Sophisto grey, H/K, pano
Previous: 2019 BMW X2 Msport, Mineral Grey, Adaptive Suspension, H/K
Previous: 2009 335i LCI, Bluewater
      10-30-2017, 07:30 PM   #28
Desertraptor
Desertraptor's Avatar
Australia
10
Drives: 2006 E90 325i
thanks for reviving this thread. My passenger mirror no longer is adjustable. Will give this a try.
      10-30-2017, 08:53 PM   #29
SeanCon
SeanCon's Avatar
This is more for the phantom mirror where it readjusts ever time you get out of the car. Might work for non operational as well. Let us know if it does
      10-30-2017, 09:55 PM   #30
Desertraptor
Australia
10
I read it's usually the switch on the drivers side? But worth starting here
      04-06-2018, 09:47 AM   #31
Friveraaa
Drives: 328i
Thanks for this tread! My passenger side mirror don’t fold in nor adjust. I hope doing this will fix the issue. I was reading it might be the motor it self but let’s hope it don’t come down to that.
      04-07-2018, 02:56 AM   #32
Mayuri Krab
The Cheap Arse Asian
Mayuri Krab's Avatar
Australia
47
Drives: E90 335i & R33 Skyline GTS-T
I just ended up coding this "feature" off using carly app lol
      04-07-2018, 06:29 AM   #33
e36mmm
Drives: 335i M Sport
Looks like I was not the only one going crazy haha. I shall do this next weekend. Thank you for creating this great thread.
      02-19-2019, 08:03 PM   #34
rgfinn76
47
Drives: 2008 335i Sport Coupe
Cleaned pins and still passenger mirror moves on its own 🤬🤬
      03-25-2020, 09:46 AM   #35
Sergio e93
Drives: Bmw e93 -2008
Hi, I'm writing from turkey, I have the same problem, I found this place while doing research, I hope this method works
      03-25-2020, 11:17 PM   #36
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Good luck
      05-17-2020, 04:44 AM   #37
schriss
schriss's Avatar
34
Drives: 2017 BMW 330e Plugin Hybrid
Worked for me, mirrors do not move anymore and also mirror related codes are gone too
I scraped pins with sharp knife and put dielectric grease on pins before reassembling.
If pins still make bad contact then its possible the other end is corroded, where the pins plug into.
Current: 2017 F30 330e PHEV
Past: 2007 BMW E93 N53 Convertible
      05-17-2020, 06:52 AM   #38
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Glad this thread is still helping people
      06-06-2020, 05:23 PM   #39
MrForgetful
Drives: e90 335i
This has been annoying the crap out of me for so long, cheers for bringing this thread back up again! haha
      06-09-2020, 01:29 AM   #40
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
      07-18-2020, 01:26 PM   #41
axe127
139
Drives: 2009 e91 328i xDrive 6MT
To answer the question of whether this applies to passenger side mirrors: yes! My LCI E91 has driver and passenger mirror memory, and it had been adjusting to the wrong position every time I got in the car recently. After cleaning the contacts, it’s back to normal.
      07-19-2020, 05:44 PM   #42
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
nice
      06-24-2023, 08:41 AM   #43
Missionpoole
Missionpoole's Avatar
Drives: 2008 BMW 335i e92
Will give this a shot. My passenger mirror is also malfunctioning even when the switch is to the left, any ideas from you guys on what could be causing this? Even when it does tilt down in reverse, it’s such a severe degree tilted that it just shows directly underneath and is totally useless lol. The issue seems sporadic. Maybe try to clean contacts on both sides or is there another known cause?
Edit: just saw the response above about this helping passenger too, so ignore me, but I’ll update if it works for me too 😂
