02-25-2016, 01:16 AM | #1 |
Enthusiast
Rep 22
Drives: 435i M Performance Edition
Project X - F32 435i - Mods/Coding
I have been wanting do this post for a while. Finally got around to it.
I will be posting list of changes with some detail that I have so far done on my 2015 435i M Perfomance Edition. Most of the coding is has been covered in different posts so I will not be going in too much detail unless there is an specific question with regards to it. However, some of the coding I encountered were specific to a 2015+ models so this could answer some of your questions if you are doing the same. First, shout-out to svache for his detailed post on coding F30 base cars. http://f30.bimmerpost.com/forums/sho...d.php?t=696777 This was a big help and starting point. For the coding I used the following versions of software: E-Sys: v3.26.1 psdzdata: v57.3 (this is newer that the firmware in my car, however, psdzdata is backwards compatible and uses the I-level for your car so as long as it is newer, it will not make a difference. More on why this matters later.) List of changes 1. Enable Active High Beam Assistant This has been covered in other forums. But since I had to gather information from different places, here is all the changes I did in one place. VO code: remove 5AP and 8S4 from FA change the speed to active and deactivate HBA (I used deactivate under 60kph and activate over 75kph) There is also a highway mode which lengthens the stretch of hwy in front of you that is illuminated. this mode has an activate/deactivate speed as well. (I used deactivate under 90kph and activate over 105kph) 2. Enable Extended Bluetooth Here is where 2015+ matters. prior to this the definition of basic and extended bluetooth were different. 6NH (basic BT) on earlier cars (i.e I-levels) meant just being able to have a phone call over BT without audio streaming capabilities. However on the newer ones, 6NH (basic BT) has audio streaming as well. hence, I did not initially look into BT upgrade codings as I thought I have the extended. On 2015+ models, if you have extended BT you will have the Office feature in iDrive which allows you among other things to access Txt messages from your phone. If you do not have this feature then you are likely programmed with 6NH like my car was. VO code: change 6NH to 6NS and you will get the following features. 3. Folding Mirrors with Fob and CA A lot has been covered on this. So, just a few notes. Closing mirror with Fob is disabled in NA cars for safety regulations since this is shared with closing windows and sunroof with fob. It has to be separately enabled. the delay between door lock and closing each of mirrors/windows/sunroof can be exclusively set. (i.e. everything can happen at once or there can be delays in between) 4. Seat-belt gong timer reduced to 1s 5. Video in motion activated 6. Main Disclaimer and Camera Disclaimers removed Changes that have not been made yet, but looking into it I will move these up as/if they are completed. 1. Changing timer on the seat-belt assistant (F32 Exclusive) 2. Unlock doors on engine turn-off 3. change BMW logo to M Performance This has been a bit tricky so far as apparently it doesn't work after certain I-level. instead the logo changes to //M 550d. looks like I have the affected one. Note that using newer psdzdata in E-Sys will not matter. the car has to be updated/flashed with the newer version. I am trying to find out if there is a way without having to flash the ECU. 4. Possibly Retrofitting SLI (Speed Limit Info) There is a different way of doing this than what I want to do which is enabled by a module which will only show the information from the navi. However, I want to retrofit the reading signs as well (not sure if this is possible - maybe just difficult?) To do this I need to first retrofit the hardware. I have the basic FLI camera which is good for HBA but not SLI or LDW (Lane departure warning). The camera which will enable the SLI or LDW is the KAFAS module. I think I need to replace my mirror unit with one that has the KAFAS camera (will this work?) If this is doable, then I will worry about the software issues. (give me thoughts on this) So far, this is what I have. I will be adding to this later. Cheers.
2015 BMW 435i ///M Performance Edition - Black Sapphire Metallic, Black Dakota Leather, Piano Black Trim w/ Satin Chrome Highlight
02-25-2016, 02:06 AM | #2 |
Schmollbraten
12516
Rep 1,985
Sounds nice.
Im also interested to delete the disclaimer at Navi and Cam, can you toss me please the coding chapters, thank you. A word to the planned retrofitting of sign assist: The additional module will display only the already saved signs from the Navi and not the true and actual signs on the street. You'll need the KAFAS2 on top and maybe another module box and some coding too. For me too expensive and not worth the effords, but go ahead and try it.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
02-25-2016, 02:29 AM | #3 | |
Enthusiast
Rep 22
Section 3001 -> Function LEGAL_DISCLAIMER_TIME -> change value from "ld_mit_timeout" to "kein_ld" for camera disclaimer also same as above. the function is MACRO_CAM_LEGALDISCLAIMER Thanks for the info on the retrofit. Is KAFAS2 a different camera? or is it a module box? I know that cars with HBA/SLI/LDW have a single camera that is capable of doing all these functions. Is retrofitting this camera alone not enough as far as hardware goes? |
02-25-2016, 03:37 AM | #4 | |
569
Rep 987
Drives: 2022 X4 M Competition F98 LCI
KAFAS Camera Rearview Mirror without FLA (since KAFAS would supersede it) - btw wouldn't mind taking that rearview mirror off you if you decide with it, was planning on doing a HBA retrofit Windshield that supports the KAFAS Camera KAFAS module (FLA Camera has the module integrated in the mirror, while KAFAS uses a separate module) Some wiring (?) Steering Wheel Vibration motor (if wanting to activate LDW) For SLI to work, you'll need to obtain a FSC code on top of all that to activate that function. It actually seems quite difficult to obtain one, and even that it would be quite pricey as well. Personally I am looking to retrofit KAFAS, but probably when I have the time to source all the parts, which will be quite a pain to do... |
02-25-2016, 06:16 AM | #5 | |
Schmollbraten
12516
Rep 1,985
KAFAS2 is a module which is necessary and built into F32 like this here. I dont know exactly, if KAFAS with or w/o 2 are the same.
02-25-2016, 12:51 PM | #6 | |
Enthusiast
Rep 22
I will look into the windshield thing more. Cheers |
02-25-2016, 12:59 PM | #7 |
Schmollbraten
12516
Rep 1,985
Afaik you need only to change the windshield if you got the grey stripe into the upper part of it. If you havent, then you're lucky and save money
02-26-2016, 07:50 AM | #8 | |
Rep 436
Drives: 2016 435i xDrive Gran Coupé
http://www.bimmerfest.com/forums/sho...d.php?t=887200 and here: (warning...very long thread) http://www.bimmerfest.com/forums/sho...d.php?t=660719 Last edited by Beowulf65; 02-26-2016 at 07:58 AM.. |
02-26-2016, 09:03 AM | #9 | |
569
Rep 987
No Cameras / FLA (HBA Only) KAFAS/KAFAS2 |
02-26-2016, 09:56 AM | #10 |
2JZ-GTE
3070
Rep 4,020
Did 6ns get u the office in I drive ?
02-26-2016, 01:10 PM | #11 |
Enthusiast
Rep 22
02-26-2016, 01:25 PM | #12 |
Schmollbraten
12516
Rep 1,985
I dont know if its clever or more cheese to compare the F30 with the F32 but I found a German forum where someone stated, that if you got the camera already into the mirror holder and also high beam assist and the rain sensor...than it should "only" be a matter of the ECU and an additional FSC to activate the new feature. Dunno if thats true of if bimmer until that has made the way to improve the own car with gadgets more stony.
02-26-2016, 01:33 PM | #13 | |
Enthusiast
Rep 22
02-26-2016, 09:26 PM | #14 | |
569
Rep 987
Oh and keep in mind with 6NS, you can also retrofit the 2nd USB outlet in the glovebox as well!
"The FLA video camera is a simplified image sensor that can identify the color and intensity of light." So I'm assuming due to the image sensor of the camera, it doesn't exactly detect objects but more tuned towards a glorified light sensor. |
02-27-2016, 11:31 AM | #15 |
Schmollbraten
12516
Rep 1,985
Just compare the P/N from the KAFAS cam and the installed one, then you'll see if its a difference
coding, e-sys, f30, f32, mod |
