04-23-2021, 10:41 AM | #1 |
591
Rep 345
Hard wiring M emblem on seats to stay illuminated.
Hi All,
Strange question but figured it was worth a shot. Does anyone know which pin from the connector under the seat needs to be removed to accomplish this? I have a new wire with pin but not sure which one needs to be removed from the one under the seat. (There are a bunch, like 14 or so) I received the new wire from Mod_emporium but with no instructions and he isn't responding on insta. Thanks in advance!! Here is what he messaged me when he sent the wire: "The Harness ties into the seat connector. You remove a pin from the connector and replace it with ours on each seat connector (Under the seat) and then run the wire about 12 inches to the back of the center console and it connects to a wire in there that powers the center consoles ambient lighting, then you're done"
2017 Daytona Violet ZCP F80
Bm3 Stage 2 |
04-23-2021, 12:48 PM | #2 |
Rep 1,009
I would measure the voltage of the emblems when they are turned on to see how much voltage they need. Then find constant power and ground from the seat motor or where ever and splice the emblems to them. They will probably need an extension cable made.
I dont know the exact pin you are asking for but its always better to measure yourself... |
04-26-2021, 11:17 AM | #3 | |
591
Rep 345
Bm3 Stage 2 |
04-29-2021, 09:17 AM | #5 |
Rep 8,189
I mean, you don't see the badge when you're in the seat, do you?
04-29-2021, 07:01 PM | #6 |
293
Rep 360
It should be the gray wire with a purple stripe (not the purple wire with the gray stripe). At least that's how it is on the M2 comp seats, and they're basically the same.
Here's a picture of the driver side harness (car side) with the yellow outer part removed. In this case it's for my non-comp M2 so it's missing the wire, but on yours you should have gray w/ purple in slot 7 where the arrow's pointing: upload pictures online I'm guessing you de-pin that, put in your new wiring and then hook that up to whatever source you want for when the lights are on?
Current:
2017 F87 M2 6MT 2013 F25 X3 3.5i 2008 E90 M3 6MT |
05-04-2021, 08:45 AM | #7 | |
591
Rep 345
Thank you!! This was exactly what i was looking for. Appeciate you!!
Bm3 Stage 2 |
12-11-2021, 07:30 PM | #8 |
14
Rep 77
Did you ever complete this? If so, any specifics?
12-13-2021, 03:24 AM | #9 |
Headlight Guru
70
Rep 131
We sell a harness for this. Shoot us a message on IG. You dont want them on 24/7. We tie them into the ambient lighting so they are on with unlock still and at night all the time.
IG Mod_emporium |
12-14-2021, 03:35 PM | #10 |
71
Rep 303
Mod_Emporium69.50 |
12-16-2021, 08:14 PM | #11 |
94
Rep 326
Private IG sent
Mod_Emporium69.50 Bimmer.Plug135.50 |
12-18-2021, 12:58 PM | #13 |
No 55mph
1623
Rep 8,479
There isn't anything about the harness on the site AFAIK, but I messaged them & the harness is $44.99 shipped, I didn't get any pics or explanation as to how it installs
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
bvrider1346.00 |
12-18-2021, 04:03 PM | #14 |
I'm Batman!
3949
Rep 1,477
Same here.
S55, 2JZ, M48.00 |
12-19-2021, 01:41 PM | #16 |
No 55mph
1623
Rep 8,479
I asked for instructions - was simply told they are included
Don't know what the big secret is? I'm not buying something site unseen & no idea how it installs
Mod_Emporium69.50 |
12-19-2021, 10:36 PM | #17 | |
Headlight Guru
70
Rep 131
What would you like to see or know brother? It's a wiring harness. Literally wires, we source oem pins/parts and wiring that redirects the power to the ambient lighting. Instructions are included as we have said. What secrets are you referring to? The installation takes about 5 mins. Unplugging the battery being the longest part of the process. |
1QuikWS61623.00 |
12-20-2021, 12:20 AM | #18 |
Headlight Guru
70
Rep 131
Because theres no mystery. In fact just the opposite, I went up to the shop at 1am so you can see what the kit actually looks like and includes.
We have about 10 of these kits left until after the holiday this week due to constant supply issues. These kits are each hand made. The kits include everything you need to install: - The wiring to redirect the power to the ambient lighting, complete with oems pins from BMW. (We tried sourcing generic ones but they just don't fit the same in the connector. - Zip ties to neatly route the wiring along the path of the oem wiring -Mini screw driver to remove the pins from the oem connector - heat shrink wrap to cover the oem pin that gets replaced and tucked away. - Instructions (not pictured) We have sold these kits behind the scenes for 4 years now with zero issues, everything is also completely reversible if you decide to switch back to oem at any time. Any questions just ask. |
1QuikWS61623.00 |
12-20-2021, 09:51 PM | #19 |
166
Rep 356
A YouTube install video a la IND would be great. Interested as well but pain in the ass install level is unknown
Mod_Emporium69.50 |
12-21-2021, 10:02 AM | #21 |
No 55mph
1623
Rep 8,479
I just picked up the harness kit takes care of both front seats
Glad I saw this post as I have been looking for a PnP method to make the emblems functional ever since I did a full M4 Interior swap in my 435 - Thanx
Mod_Emporium69.50 |
12-21-2021, 06:35 PM | #22 |
94
Rep 326
Other buyer here..
Mod_Emporium69.50 |
