MHD "take a look at my log" thread
04-23-2024, 12:06 PM | #5963 |
18
Rep 48
Hey guys.
Just finished installing inlets and outlets, car is now true FBO, stock turbos, 91, stage 2+. XHP stage 2 At WOT, near redline the car goes into limp mode, I’m guessing it’s a fueling issue. Code 29DC - DME: Cylinder injection cutout. Always comes up Code 2C7B - DME: Oxygen sensor after catalytic converter: Signal. Sometimes comes up. The car pulls strong when it gets into boost but then it falls on its face. Have had 2AAF - DME: Fuel pump, plausibility. Since I bought the car a few years back. Bought it at 198K, now at 206K Thank you guys First log is the pull Second is how it idles horribly when I pull over to the side of the road https://datazap.me/u/eriksson/wot-3r...og=0&data=3-21 https://datazap.me/u/eriksson/wot-idle?log=0&data=3-21 |
04-23-2024, 02:22 PM | #5964 | |
Rep 3,652
Eriksson04288718.00 |
04-23-2024, 02:24 PM | #5965 | |
Rep 66
Drives: 335i n54
04-30-2024, 03:32 PM | #5966 |
Rep 17
Hey guys its me again!
After the experience i have since changed the LPFP , did walnut blasting , changed the chain guide rails (aparently afew pieces of the plastic broke due to high milleage). Have currently flashed stage 1+ 93 oct will attach the log below , still has some timing pulls but nothing above 3 on average , need more experienced guidance if the tune is fine! Turned off burbles too Ps: i did get a 2D2E throttle valve angle-intake manifold vacuum corelation code, searched online and alot are pointing towards it being a false alarm, but some advice on this will be greatly appreciated too Edit: from my logs it seemed the 2D2E came when i temporarily went over boost target so dme tried to compensate by closing throttle? I think that is normal yes as long as it doesnt happen too often? vadonchez hey bro greatly appreciate your advice too if you are free could you take a look at this log stg1+ 93oct |
05-02-2024, 11:02 PM | #5967 |
Rep 3
https://datazap.me/u/bluemeover/log-...og=0&data=3-20
91 oct 6466 port injection how’s she look |
05-03-2024, 09:40 AM | #5968 | |
35
Rep 95
Your log is ok to me everything looks good on fuel side.Everything looks good on boost side too. But timing corrections on all cylinders as if you are using bad fuel. Did you try to run 91 octane map with 93 octane fuel? And again, try V7 2+ map as they are demanding less timing @low rpm than V10 wich can help in your case. |
05-03-2024, 10:10 AM | #5969 | |
Rep 17
As for the 2D2E code , i cleared it that day and it didnt came up ever again, think it was just a freak accident or something , anyways what is VC? |
05-03-2024, 10:32 AM | #5971 |
Rep 17
05-03-2024, 11:08 AM | #5972 | |
Rep 1,539
05-03-2024, 12:02 PM | #5973 | |
Rep 17
stage2+ v7.1 91oct |
05-03-2024, 12:11 PM | #5975 | |
35
Rep 95
I think je just not wot totaly but if you look at his other logs that's better. |
05-03-2024, 05:07 PM | #5976 |
Rep 1,539
05-04-2024, 12:32 PM | #5978 |
Rep 17
Hey man did another log for you! Gear 4 WOT now! I would suggest showing throttle position too , a short while after WOT timing pulls all dropped to 0 , im assuming thats a good sign and timing pulls just normally cruising before wot is normal , think the massive timing pull could be due to fake noise as i downgeared with burbles before pulling so that section can be ignored? If im wrong could correct me too! Lmk!
stg 2+ v7.1 |
05-05-2024, 02:06 PM | #5980 |
Rep 17
