BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
Mporium BMW
      09-24-2016, 02:47 PM   #1
maicol76
194
Drives: E92 M3
Electric hydraulic steering pump
I'm planing to install Electric hydraulic steering pump(EHPS pump) instead of stock pump.
As I know stock pump of S65 engine is only mechanical pump and has no CAN control wiring, so many of race cars based on S65 engine are using EHPS pump, Benz A-class pump, Opel Astra pump and etc.
Which EHPS pump is the best pump?
And how about feeling on track?
If someone has information and experience, plz give me some advice ~
      09-24-2016, 05:59 PM   #2
roastbeef
roastbeef's Avatar
Drives: E92 M3
Motorsport24 makes one. It's a fairly large project. What's your intent or goal?
Instagram; @roastbeefmike
      09-25-2016, 02:56 AM   #3
maicol76
194
Drives: E92 M3
Goal...uhm...
My M is under construction for track only car.
the Goal of Removing P/S pump and A/C compressor is for increasing engine response and weight saving.
M24 use A-class pump, may be.
      09-25-2016, 03:01 AM   #4
roastbeef
roastbeef's Avatar
Drives: E92 M3
i see. i don't have any experience, but i've asked m24 about them just because i was curious. they stated the biggest benefit is getting rid of the a/c and ps pump for a freer running engine. other than that, i don't know.
      09-26-2016, 08:08 AM   #5
Richbot
Drives: Jerez Black E90
20lb off the nose too.
      10-21-2016, 07:09 PM   #6
warp10
warp10's Avatar
776
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
2011 M3  [10.00]
2011 28i X3  [0.00]
yes need to figure this out!
      10-26-2016, 10:10 PM   #7
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
Okay
Been talking to m24.
Hesitant to pull the trigger as I'm not sure the install time required to get this done and I don't want it to be a crazy thing to do.
Has anyone done this? They sell the kit so it has me believe that people have. But I can't find anything.
I have done the upgraded cooler and bigger BW reservoir tank and I still get over heating.
Thanks.
      10-28-2016, 10:18 AM   #8
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
It has been ordered so let's see how this goes.
roastbeef11586.00
chamba002238.50
      10-30-2016, 03:41 AM   #9
roastbeef
roastbeef's Avatar
Drives: E92 M3
Can you keep us posted with costs, the install and performance? This isn't for me at this time, but I enjoy learning about this stuff.
      10-30-2016, 12:40 PM   #10
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
Yeah will do.
It is replacement pump not a rack or anything like that.
Basically allows to delete the ac and ps pumps and take parasitic drag off the engine.
Cost thru far has been $1400 for the pump and bracket and shipping. Expose to be plug n play so we shall see.
My guess is 3-5 hrs depending. Will keep an update here.
Adam
roastbeef11586.00
      10-30-2016, 08:44 PM   #11
roastbeef
roastbeef's Avatar
Drives: E92 M3
i've always wondered if there is any benefit to having lower weight pulleys. same size (not underdrive), just less weight.
      10-30-2016, 08:46 PM   #12
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
Don't think that will solve the problem of the high rpm and pressure build up on track. Street driving probably no difference in performance.
      10-30-2016, 09:01 PM   #13
roastbeef
roastbeef's Avatar
Drives: E92 M3
Yea I don't think it would help with any device performance wise, but each pulley has to have some momentum to it whether it powers something or just provides tension. Getting each pulley spinning has got to have some kind of drain, but maybe minimal.
      11-02-2016, 09:31 PM   #14
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
Everything should be here in a week or so. Will keep this update with the progress.
roastbeef11586.00
      11-05-2016, 07:23 PM   #15
Leglessracing
121
Drives: M3 E92
Hi guys,
I'm running this setup in my car. With ac deleted too.
Main savings is weight on the front end and a more responsive engine.
Also we have used a Mercedes pump. This keeps costing down quite significantly too!
E92 M3 - Frozen Black Race car sold
F80 M3 - Fire Orange sold
E92 M3 - Frozen Grey Track day car Current
roastbeef11586.00
      11-05-2016, 07:55 PM   #16
roastbeef
roastbeef's Avatar
Drives: E92 M3
Originally Posted by Leglessracing View Post
Hi guys,
Just so I'm not confused- it's an electric hydraulic pump, and not electric powered steering, right?
So steering feels the same? How is the wiring setup?
Bx Tpr122.50
      11-05-2016, 09:50 PM   #17
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
Hi guys,
Talked to your guys how did your and yes it cheaper but the m24 kit comes with bracket and all plug and play hardware. Paying for ease of install....hoping
      11-06-2016, 03:01 PM   #18
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
Hi guys,
Correct. Replaces the engine driven pump with an electric driven one. Steering should remain the same as your not replacing the rack. Wired I assume to a direct power source when engine is running I might run is as a switch.
      11-07-2016, 01:53 PM   #19
Greg S
84
Drives: 08 M3 DCT
The MB pump has 3 wires, positive, negative, and a low amperage signal(+) wire. Don't forget to install a ~50A(I can't remember exactly) maxi or similar fuse/holder(I think it's 6ga wire).
-Greg S
2016 NASA TT3 NASA Eastern States Champion
warp10776.00
      11-07-2016, 03:23 PM   #20
Leglessracing
121
Drives: M3 E92
You will find that the Marc setup I have installed is more responsive too. Taking out the mechanical slack on the belts means the steering doesn't feel as loose
roastbeef11586.00
      11-07-2016, 03:55 PM   #21
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
I have heard this now from a few people. We will know shortly!
      11-07-2016, 03:56 PM   #22
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
Thanks for the tip
m3post
