05-26-2022, 01:20 PM | #89 |
77
Rep 120
My PSS aren't directional, though. They're marked outside/inside. I assume you wouldn't do that for those?
Also, for people who do a lot of tire changes (and do their own work), does anyone actually buy a tire machine and balancer? Something I'd be tempted to do in the future. |
DrFerry6728.50 |
05-26-2022, 03:01 PM | #90 | |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
The practice of flipping the tires on the rim has merit only in a dry track environment and only when a homogenous tread compound is employed with a non directional tread design. The Michelin PS2, PSS and PS4S tire product lines all use asymmetric, dual compound, design strategies. Hence, there is a reason why their inner sidewall states "Inside". To paraphrase what others have already stated in earlier posts: With some tires, used solely on a dry track, flipping them on the rim has been done to extend tire life in a track application. However, one has to be very careful of the engineering constraints designed into the product to avoid not degrading dry grip, vehicle balance, and stability [assuming a dry track]. For example: Below is a photo of an OEM PSCup 2 tire that uses 3 different compounds across the face of its tread. So flipping this type of tire can reduce dry grip when the alternative wet compound focused tread shoulder faces the outside. . . Here's an illustration of the PS4S dual compound design strategy. . And PSS . . Source link and other more detailed information: https://motoiq.com/not-all-michelin-...ed-the-same/4/ . Not to confuse things any further, but if a directional tire were to be flipped on the rim and used in a wet environment its tread will actually pump water "into" the contact patch rather than away from it.. This is the reason why directional tires use a marking of some type to indicate the direction of rotation in service.
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
05-26-2022, 03:15 PM | #91 | |
Derbo Tuning
3610
Rep 3,022
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
05-26-2022, 03:40 PM | #92 | |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
05-26-2022, 04:03 PM | #93 | |
Derbo Tuning
3610
Rep 3,022
yeah, I should've been more clear, it was just 5 alternating compounds with 3 different materials lol. Even then, it is interesting the compund of black carbon is different from the aftermarket PS4S too. Carbon+ vs Carbon+++ Still interesting regardless!
IG:ruhrohz_m3
05-31-2022, 08:59 AM | #94 |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
Recently updated Grassroots Motorsports article on May-29-2022:
Ultimate track tire guide | 200tw, 100tw, street-legal track and R-comps https://grassrootsmotorsports.com/ar...-buyers-guide/ .
rg122077.00 ///M Power-Belgium63359.50 b4hand661.00 beats225.00 omgzirra_exe1489.50 Davisca4552207.50 bigjae19761571.00 |
05-31-2022, 11:00 AM | #95 |
Rep 1,366
In the comments it says nothing was actually updated and their editor made a mistake, oops lol
They should have tests on the Goodyear RS, Bridgestone RE71rs, and the Nexen NFera Sport soon though I would think
#ladydriven Heavy-spec M3 // KW Clubsports // AA x-pipe // Gintani muffler // Macht-Schnell intake // Gintani tune // OMP Seats // Too Many Apex Wheels // Stoptech ST-60 // Cobalt Friction brake pads |
05-31-2022, 07:16 PM | #98 |
Rep 865
I noticed that as well when I was trying to figure out my track tire/wheel setup.
The issue for me was sizing. 275/35/18 305/35/18 The NT01 checked the most important boxes for me. In order of importance: 1) Heat Tolerance (don't like it when my tires get greasy) 2) Wear (I feel bad when Suzanne asks me "Didn't you just buy tires?") 3) Sizes 4) Pace (was only a B, but I don't need to set the world on fire to have fun at an HPDE) 5) Wet (Have the PS4s if it rains)
Chris, 2008 E92 |
DrFerry6728.50 |
05-31-2022, 07:16 PM | #99 |
Rep 893
Still planning on ECF next. Seems to have all the great traits of the rs4, but a little faster. Should be a nice upgrade from PS4s.
Instagram: slcook54
06-01-2022, 09:40 AM | #101 |
Rep 1,424
06-01-2022, 09:47 AM | #102 | |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
. Nitto NT01 . https://www.nittotire.com/competitio.../#pdp-features
06-01-2022, 10:01 AM | #104 |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
06-01-2022, 10:11 AM | #105 | |
Rep 1,195
Its a fast rack tire who cares what it sounds like. They shouldn't be street driven anyways. |
06-01-2022, 10:31 AM | #107 | ||
Rep 1,424
Seriously. I get unreasonably angry about that tire 🤣 |
06-01-2022, 10:39 AM | #108 | |
Rep 1,195
What tires are you referring to that are faster? I am very fast with the NT01s and a factory suspension car. I rarely am passed. If you look at the grassroots motorsports chart posted in this thread there aren't many other options. I'm actually interested in your answer, not just being a jerk. If I want a 18" track day tire, dont care about wet performance or noise whats the best tire? Last edited by Gossypiboma; 06-01-2022 at 10:52 AM.. |
06-01-2022, 10:54 AM | #109 | |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
///M Power-Belgium63359.50 |
06-01-2022, 11:00 AM | #110 |
Rep 1,195
I was planning on trying the Proxes RR actually. Supposedly they are the same compound as the NT01. The A052 has a horrible heat tolerance rating so its gonna fall off fast after a few laps.
I'm interested in the V730, but finding a direct comparison is difficult. I've also read they are quite narrow. Last edited by Gossypiboma; 06-01-2022 at 11:05 AM.. |
