BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
EXXEL Distributions
      08-09-2023, 09:27 AM   #23
turbo_joe
turbo_joe's Avatar
1616
Drives: 2012 M3 Coupe
Sold my stoptech trophy kit and upgrading to the Bimmerworld nickel plated Alcon kit
Appreciate 5
tsk941522.00
JobanM73.50
DrFerry6728.50
      08-09-2023, 10:26 AM   #24
tsk94
tsk94's Avatar
1522
Drives: E92 M3, E82 128i, F82 M4, E36
You'll be happy with those. I have that kit on my M4 and it's awesome.
Not nickel plated though Mine was an early kit before they offered it.
Appreciate 3
turbo_joe1615.50
JobanM73.50
      08-09-2023, 09:29 PM   #25
okusa
okusa's Avatar
846
Drives: 2011.75 E90 M3 - SSII
Aside from the wide body kit itself and 18x11 wheels, what else is needed to go wide body?
      08-10-2023, 06:43 AM   #26
turbo_joe
turbo_joe's Avatar
1616
Just a willingness to hack up the car haha. Nothing special besides making the kit fit and cutting up the car. I am full SPL arms but its all stock width components.
My goal was to fit 315s without any tire poking out of the body work. One day I will go the custom wheel route to run 18x12s with 315s
      08-10-2023, 06:45 AM   #27
turbo_joe
turbo_joe's Avatar
1616
BW is sold out of the normal kit right now with a 1-2 month lead time so I bit the bullet on upgrading to the nickel plated kit.
The finish looks amazing but its not as shiny as the AP plated kit haha
tsk941522.00
      08-10-2023, 10:20 AM   #28
Dean__Sanchez
27
Drives: 2010 M3
What alignment settings do you run?
      08-10-2023, 07:44 PM   #29
turbo_joe
turbo_joe's Avatar
1616
Just changed the entire alignment setup running over -4 camber up front and about -2.6 rear
DrFerry6728.50
      08-11-2023, 12:35 PM   #30
Dean__Sanchez
27
Drives: 2010 M3
For the front toe, are you running any toe out? Or just zero? Thinking of running a little toe out. (I only run time attack at a local grass roots track, 1 warm up lap, 2 hot laps, 1 cool down lap for the time attack portion). Figured slight toe out would help heat front tires up (toyo RR) and help with turning since the track is fairly short with good amount of turns. (Avg lap time is only 1:18)
      08-12-2023, 05:12 PM   #31
turbo_joe
turbo_joe's Avatar
1616
I run a bit of toe out up front and a bit in for the rear.
DrFerry6728.50
      08-13-2023, 04:53 PM   #32
DrFerry
Field Marshal
DrFerry's Avatar
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
Sub'd and to your YouTube channel. The VIR laps in the video of your first post are 'flyers'. The digital speedo showed 149mph on the back straight after Oak Tree. What final drive differential ratio are you running? The car looks really nicely buttoned down with slow hands at the wheel and early power on well before apex in many corners. Awesome. Well done. I'm sure the car is even better now with the custom H-Depot front splitter aero balancing the rear wing aero loads. Oh what fun it looks like your having.
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
turbo_joe1615.50
      08-14-2023, 06:38 AM   #33
turbo_joe
turbo_joe's Avatar
1616
unfortunately I am still on an oem rear diff right now with stock gearing. Slowly making more changes to get the car sorted out. Next big ticket items the car needs is better suspension and a rear diff. I think they will make a huge difference and make the car easier to drive.
DrFerry6728.50
      09-19-2023, 10:32 AM   #34
turbo_joe
turbo_joe's Avatar
1616
Some shots from Pitt Race/Nasa Champs
tsk941522.00
DrFerry6728.50
      03-26-2024, 01:28 PM   #35
turbo_joe
turbo_joe's Avatar
1616
Working on the new suspension setup. Went with MCS 2-way remote true coilovers. Almost done, need to corner balance the car and take care of the alignment.
Got the canisters mounted yesterday.
Untitled by Joey Hutchinson, on Flickr
Dropped the subframe to install a new sway bar
Changed up the rear diffuser. I lowered it a couple inches and now the exhaust comes out above it instead of through it. Also changed my setup for mounting the back of it.
Ignore the damaged rear bumper and terrible wrap. I have a spare but dont have the time to swap it and rewrap it right now
Appreciate 4
      04-03-2024, 02:43 PM   #36
wahwill
27
Drives: E92 M3
Love the the front splitter you made. Did you notice a difference after installing the splitter diffusers?
Also, does removing the oil cooler hole at the bottom cause any issues?
      04-03-2024, 06:22 PM   #37
turbo_joe
turbo_joe's Avatar
1616
Its hard to say as I changed some other things when I built that version of the splitter. Overall it has worked great but I am about to swap to a zebulon front splitter.
I've run my car for the last 3-4 years with no hole for the oil cooler and never had an issue. Ideally you dont want to be dumping air under the car if you can prevent it.
      04-10-2024, 02:51 PM   #38
turbo_joe
turbo_joe's Avatar
1616
Ready for race weekend at Summit Point
Gonna be more of a shakedown weekend working on tuning the new suspension.
[IMG]Untitled by Joey Hutchinson, on Flickr[/IMG]
Also finally got around to modding the driver door to be able to remove it to load it in the trailer.
Made an easy mount on the wall with some e-track and J hooks to hold the door during transport
Appreciate 4
      04-11-2024, 02:08 PM   #39
jmeenach
Drives: E92 M3
I bet the door mod makes it a lot easier to get out of the car once in the trailer!!
turbo_joe1615.50
      04-11-2024, 08:39 PM   #40
StripclubDJ
StripclubDJ's Avatar
4100
Drives: e92 m3
Cars new hips makes that wing look tiny now lol
      04-11-2024, 11:16 PM   #41
turbo_joe
turbo_joe's Avatar
1616
Hopefully that changes this year. Looking at switching to a 74" carbon wing with a larger chord
m3post
