11-24-2020, 01:26 PM | #23 | |
Rep 595
Drives: 2012 F25 (N55), 2014 I01 (REX)
* chuckle * so that is actually a sous vide container. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 TIP: if you buy from amazon warehouse deals, its cheaper and usually shows up NEW or Like-New (for automotive use, I honestly dont care how clean or not clean it is) |
6MT_Addict283.00 |
09-24-2021, 02:17 PM | #26 |
891
Rep 2,556
Drives: Z4MC-X3-35i-525i, Corrado G60
09-24-2021, 03:42 PM | #27 |
Rep 595
09-26-2021, 08:32 PM | #28 |
46
Rep 120
Marathon session today. New tensioner, idler pulley, and belt; changed out front and rear differential fluid; changed out transfer case and transmission fluid. I'm a bit tired from all the in and out underneath the car. I'm an old guy who doesn't move as well as I used to. Thanks to the folks who posted all the wonderful material photos and writeups on these DIY tasks. No pix from me since these have all been well documented.
I will add several items/tips though. Tensioner and belt replacement were beyond frustrating. Hardware installation is straight forward. The new belt did not want to mount on the pulleys. It had folds in it that had taken a set from being in the package. It kept hanging up on the bottom of the crank pulley where I couldn't see it and I kept thinking the belt was too short. Lesson here is to warm the belt in the sun and pay close attention to it's location when placing on the crank pulley. The transmission fluid replacement was also straight forward. Be careful when doing the fill at operating temperature. The exhaust pipe is just inches from the fill hole and very hot. No burns here, but worth mentioning. Also, others were concerned that only about 5 liters was used for the refill. That was my experience also. Used about 5.25 liters. Tran temp was 28C when filled and not running. Checked at 35C while running and added to, checked at 40C while running and added to, checked at 45C and added to, checked at 50C and was full. All running checks were done with the car in gear. Moving around under the car on jack stands while it's in gear is a bit unnerving. Final note, once the trans had reached operating temperature I rechecked pan bolt torque and got about an eight of a turn more from each bolt at the 10nm value. Brake pads and rotors tomorrow. Thanks again to all who went before and provided great info on these DIY items.
Pat
2015 F25 X3 35i M Sport - Carbon Black |
evilchargerfan271.50 |
09-27-2021, 02:34 PM | #29 |
15
Rep 48
good tutorial video
here is good tutorial for the transmission oil change.
couchflyer106.50 |
09-27-2021, 04:26 PM | #30 |
Rep 595
09-27-2021, 04:35 PM | #31 | |
Rep 595
Pat, thanks for sharing your insight! I was foolish enough to let my arm touch the exhaust pipe, it was not fun. Could you re post your experience in the big DIY thread? there would be a larger audience there, and many other will find your tips useful https://x3.xbimmers.com/forums/showthread.php?t=1824067 |
09-27-2021, 07:51 PM | #32 | |
46
Rep 120
Pat
09-28-2021, 07:14 AM | #33 |
15
Rep 48
slowblackx3f2573.00 |
10-02-2021, 07:21 PM | #34 |
107
Rep 158
Drives: M4; X4 M40i
I just did my X4 M40i, thank you for the guide.
10-08-2021, 01:30 PM | #35 |
Blue Blood
195
Rep 91
OP,
Can you speak to whether or not the transmission behavior was improved (or worse) after the fluid change? I have 150k miles on my F25 35i trans without any fluid changes and have been given mixed advice on doing a first fluid change at this high mileage. The dealer actually recommended against it, if you can believe that. The Blackstone report was also interesting and helpful, as it seems to imply that the fluid was basically fine, factoring in the detected metal was likely from initial break-in.
Rob
C : 2005 BMW M3 / 2013 BMW X3 P : 1969 VW Beetle / 1989 BMW 320i / 1991 BMW 318is / [a ton of BMWs between 99 and 2012] / 1991 Porsche 944 S2 |
10-16-2021, 06:55 PM | #37 |
107
Rep 158
Drives: M4; X4 M40i
10-29-2021, 02:49 PM | #38 |
Rep 595
10-29-2021, 02:52 PM | #39 | |
Rep 595
This is not a scientific response, but my butt dyno feels as if the shifts are now "smoother" A local shop mentioned if they find metal shavings in the fluid, that they would immediately replace with original fluid. (to clarify, re fill with the fluid they drained and NOT replace with new fluid from a new bottle) I'm not sure what would be best in your situation. On one hand, (IMO) it sounds most reasonable to change the fluid. But on the other hand, you're doing just fine and maybe its best to not rock the boat? |
07-01-2023, 03:26 PM | #40 |
Rep 2
totally jumping on an old tread, but wondering if anyone has waited to long to do this and got the permanent fault code "transfer Box (VTG): oil wear......I would love to know how you cleared it if you did!!
07-03-2023, 10:07 PM | #41 |
90
Rep 176
This thread is for transmission…did you try searching the forum for transfer case VTG faults? ….but to answer your question, you need to clear the fault through ISTA after completing the oil service procedure
02-16-2024, 12:07 AM | #42 |
Rep 7
This is not how I flash transmission. In brief: I drain transmission fluid, change filter/pan and measure how much transmission fluid came out. Then I pump in exactly same amount of new transmission fluid back. Then shift thru all gears several times as you described, then I drive about 600 miles and drain the fluid again thru drain plug, measuring it. And again filling out back in same amount + half a quart because of temperature deference. Works great!
02-16-2024, 09:26 AM | #44 | |
891
Rep 2,556
Why not simply following the manufacturers refill procedure, they know what they're talking about? Your method is more work, measuring what came out, measuring that same amount to put back in, then hoping, though not knowing, if the level is correct But you do you if you "think" that works great, but I wouldn't advise others you use that method, instead follow the manufacture's procedure so you know for sure that the level is correct... Last edited by pungo; 02-16-2024 at 09:53 AM.. |
