08-22-2021, 11:44 PM | #397 | |
119
Rep 284
09-05-2021, 11:08 AM | #398 | |
Great Teacher
1124
Rep 1,314
Drives: 06 e91 325ix
i figured it out for you. When i did the t/a i turned off the sub expander (loudness) since i dont need it at 70-85% where i usually run mine. when i turned down to 50% or less there was no bass as a result. made a new tune for you with it back on and the sub t/a fine tuned a bit. it hammers at lower volumes again. I hope you enjoy it.
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… Last edited by Onizukachan; 09-05-2021 at 09:29 PM.. |
09-20-2021, 03:51 AM | #399 |
Rep 4
Hello guys!
I have read all the 19 pages and getting confused finding a better setup for my F30 that the stock. Car have installed the full Match stage 4 kit. Match7UP amp, rear speakers with tweeters , front subs, front speakers with separate tweeters. Car does not have a central dashboard speaker. Which would be the best option for customer tune file for that amp and F30? Onizukachan's last post has a touring setup and as far as I read, the F31 that this tune was made for has central speaker. Do not want to experiment with putting the touring profile on a sedan car, having in mind mine doesn't have central speaker. Any advice or direct f30 custom tune with similar setup to mine ? |
09-20-2021, 08:47 AM | #400 |
Great Teacher
1124
Rep 1,314
All f30/32/36/80/82 and f31 that had the amp the match7 replaced are with center speaker. All tune files you get from match will have the center turned on. I’m guessing yours was euro base with 4 speakers and the amp and speakers were retrofitted.
That being said, on my tune the center is very tuned down in volume so it ain’t gonna hurt to not have it. I can flip it on or off with only the tiniest of differences. Just watch a couple of videos on YouTube about how to use the software and load a file of your choice and go to town tuning. Start with mine, start with match sedan or match touring, whatever you think sounds closest to your ultimate goal.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
09-21-2021, 02:53 AM | #401 |
Rep 4
Yes, it was retrofitted. I will not then take any actions since I do not want to screw things up.
It is not so bad now and will not experiment and lose the current settings. |
09-21-2021, 08:27 AM | #402 |
Great Teacher
1124
Rep 1,314
That makes no sense.
Just Save the file you have now.
12-04-2021, 09:01 AM | #404 |
51
Rep 255
Drives: F36 430d GC, XKR, Clio 172
I'd be very interested in this. Maybe I'll start a thread and see what happens
Midnight Black Jaguar XKR Convertible | Saphire Black BMW F36 430d Gran Coupe | Iceberg Silver 2002 Renault Clio 172 Track Car
12-21-2021, 02:32 PM | #405 |
Rep 4
Sub in the trunk tune card??
Does anyone have a good tune card/profile for a sub in the trunk? I just got the Match UP 7BMWf for my 18 BMW 320i. I have Focal speakers and 10" sub in the trunk. I'll share one I created but thought I would see if others have good ones as well.
12-21-2021, 02:40 PM | #406 |
Rep 4
Does anyone know if you have to add FL/FR/RL/RR to subwoofer channel (for a sub in the trunk)? Or do you just move front left and front right over to the trunk subwoofer channel?
12-29-2021, 06:48 AM | #407 | |
51
Rep 255
I've actually used mr rear channels which with the S676A hifi option give a full range signal. This way I can use the drive fader control as a sub level controller (IE knock the Front to Rear fader towards the front to reduce the Sub level)
12-30-2021, 09:50 PM | #408 | |
Rep 4
12-31-2021, 10:31 AM | #409 |
Great Teacher
1124
Rep 1,314
Yes, then turn on the center channel feature so it on
Y plays what is on both channels. Otherwise it’s just a left. Sound like you didn’t turn on a crossover for it or set the level yet.
01-01-2022, 09:03 PM | #410 | |
Rep 4
Also - I was reading a crutchfield review of the amp and this gentleman says: “ By default, the amp relies on the potentiometer for amplifier gain and applies an additional +5 dB input gain from the BMW headunit. You need to first go into DCM tab, Signal Management to switch to a standard 8V input.” Should I set it to 8V as well? I’m having trouble getting the system to sound just right. Especially my sub. Thank you!! |
01-15-2022, 06:09 PM | #411 |
Great Teacher
1124
Rep 1,314
I’m talking about the real center feature /fx where center only plays what is on both channels and not a sum of both channels.
01-31-2022, 08:20 AM | #413 |
Rep 24
I tried looking but nobody seems to have.. anyone got a tune for BMW F15 X5 for the match up 7dsp? I upgraded to earthquake underseats.. b&o speakers with JBL GTO19T tweeters and I’m just looking for something that would give it that finish touch.. cause as it comes from factory its pretty rough.. not impressed .. and match don’t seem to have a tuning file for UP 7DSP, if not… I’m gonna go from 0 and try and get a good tune myself
01-31-2022, 07:52 PM | #414 |
Great Teacher
1124
Rep 1,314
Just load one from a match up7bmw.
02-10-2022, 09:00 AM | #415 |
Rep 5
Is there Anyone in here who has a F31 with:
OEM HiFi speakers + monoblock and a Trunk sub and has a mint file you are happy with? (Im playing mostly electronic music but also some other genres) Could be interesting if someone with another atleast similar car has a sweet file aswell just so I can compare with mine, I´ve been tuning the Touring-file with some own parameters and exploring with "subXoabder" and "Dynamic Bass Enhancement" among other settings. Time allignment made a big positive impact for me. Cheers. |
Onizukachan1124.00 |
03-24-2022, 08:13 PM | #416 |
Rep 481
Here is mine, I have calibrated for driver by distance, so everything sounds infront of driver. I have removed center speaker.
I have Bimmertech complete sound system with PP86DSP, with HI-FI system. Last edited by MEN54; 03-24-2022 at 08:36 PM.. |
03-25-2022, 01:43 PM | #417 |
Rep 24
Hello guys, just installed Match Up 7bmw amp and loaded a preset for BMW GT series from a fisher, a nice upgrade to HIFI audio. Wondering can it be even better, so maybe somebody has a preset made for f34? Thanks
03-30-2022, 07:38 PM | #418 |
Rep 481
I have a question, I have 2017 BMW 330xi with Hi-Fi, I have upgraded Tweeters, Mids front and Rears and two under seat Subwoofers also installed Match PP86DSP DSP Amp, I feel I need more bass, can I add Match PP 7S-D Compact trunk Subwoofer and not loosing existing underseat subwoofers?
