12-29-2010, 11:24 AM | #1 |
Rep 74
Coolant sign on - dealer says to just add water...really???
I have an 08 135i with 10k on it - The coolant sign came on yesterday . I called the dealership to ask whether i should add only BMW approved coolant and they said to just add water !!! WTF?? the car is a little over 2 years old i though may be it was time to flush , change the coolant and check for leaks . Any similar experiences ???
SGM|Terra|Sprt-Premium|Dinan Stage II|Dinan Performance Exhaust|35% tint| BMW SSK|Breyton GTS-R
12-29-2010, 11:34 AM | #2 |
Loves his G20
265
Rep 2,507
I've been through the same thing with previous bimmers as along as its a low amount it should be ok to top off with some water.
2020 330ix-Msport Past- 2013 135i 2011 135i |
12-29-2010, 12:28 PM | #3 | |
Rep 74
That's what i thought thanks for the insight
12-29-2010, 12:46 PM | #4 |
Rep 1,027
Mine did that and when i checked it it was dry as a bone..
i added distilled water.. never had anything come from it.
M Sport Line Estoril Blue
12-29-2010, 01:42 PM | #5 |
Rep 5,627
Prior to about 2005, BMW specified a 4 year interval for coolant changes so one change was covered under 4 yr maintenance. Now it's considered "lifetime", so while you may wish to change it, it will be on your dime.
Tom |
12-29-2010, 01:50 PM | #6 |
117
Rep 1,998
BMW has deemed the coolant in our cars to be "lifetime" and under the full maint program, they will no longer be flushed / bleed and refilled as a normal course of maint.
Thats the bad news ... The good news is that theses coolant systems are so fickel that somewhere along the lines something will leak and we get a coolant flush in disguise. If you need to "top-off" and you dont have the almight distilled water at hand, then just use bottled water.. most of us have them in the house... I for one have topped off with garden hose water a million times....and no the car s havent inploded and melted to the ground in a distilled fog of furry.. too each there own i guess.. p.s a coolant flush at the dealer with the proper bleeding will run about 1.2 hrs plus the coolant...
X1, R58 JCW, M2 in my future if planets align
12-29-2010, 02:00 PM | #7 |
15
Rep 305
Yup, just get a jug of distilled water from a Rite-Aid, CVS, supermarket to top it off if you don't feel like dropping by the dealer (they should top off for free). Distilled water actually transfers heat better than coolant, it just has no anti-freeze properties. On motorcycle track days distilled water is all I run since they won't allow ethylene glycol coolants and it runs cooler with just water.
Alpine White, Coral Red Leather, Sport Package, 6MT |
12-30-2010, 09:15 AM | #9 |
Rep 1,288
in the 2+ years of ownership, I've had to add coolant twice. The first time it took nearly half a jug to fill it back up. Took it to the dealer for a checkup and they said it had no leaks anywhere.
Second time it probably took about 2 cups to fill it back up... still no leaks. As others have stated, water is fine... but next time you are at the dealer, it might not hurt to pick up a jug of coolant... Because there will be a next time. |
12-31-2010, 07:25 AM | #11 |
Rep 50
Just another reason to lease 'em!!
2011 135i Alpine White - Black Boston - M Sport - Premium - DCT - HK Sound "Tastefully Optioned"
12-31-2010, 07:42 AM | #12 |
European Editor
10642
Rep 22,992
When I made my little "DIY Checking & adding engine coolant DIY" my car's coolant was almost ONE LITER low! It did not look that low. I used BMW's special coolant for my car. I had gone to the dealer to buy some... but they just gave it to me! I think your relationship with your dealer might be a little bit different IF they say just to use some water.
DIY Checking & adding engine coolant DIY http://www.1addicts.com/forums/showthread.php?t=401672 Dackel |
01-03-2011, 06:41 AM | #13 |
Rep 527
you could literally be down just a cap full. check it.
my low coolant water warning light has come on 2x in 3 years and i just put a few ounces of "wetter water" in both times and it topped off.
There is no substitute.
01-03-2011, 08:22 AM | #14 |
Rep 527
i see you live in D.C.
doesn't get crazy cold there too often so you would have zero issue with adding 100% distilled water to however much your down. besides, anything more than 2 quarts and you probably have a leak. bonus is your car will be much cooler in the summer with a higher water concentration.
01-03-2011, 11:13 AM | #15 |
Rep 62
Drives: 135i Coupe
Being a capful low- in the extreme cold has caused my light to pop on, but once warmed up and leaving my destination it goes off. Level is right at the MIN. Too bad I can't just use the "green stuff"
135i Coupe
996TT CR-V (no turbo,no fun) |
01-03-2011, 12:04 PM | #16 | |
First BMW
Rep 87
Maybe some people like visiting their dealer . Personally, the more I can avoid going back to the dealer, the better . |
01-03-2011, 12:06 PM | #17 | |
Rep 527
in a pinch. you can get wetter water almost anywhere.
