XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
      08-19-2018, 05:41 PM   #23
sayemthree
sayemthree's Avatar
597
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
Originally Posted by BeeHemDoubleU IksWane View Post
Honestly ? Because I don't see how that could affect the xdrive system. AFAIK offset doesnt affect xdrive, right? It's all about total circumference, no?
In theory in a straight line it shouldn’t but it could in turns. Then again cheap tires shouldn’t either
      08-19-2018, 07:11 PM   #24
0w40X1
Drives: 2014 BMW X1 s28i M Sport
I didn't think shorter front axle would would cause sway either.
Ok, we are looking for easy solutions here.
Hhow are the brake pads?
Like I said, traction overeaction can be tamed down by getting the aggressive semi metallic pads off, and ceramic in Centric or Akebono.
BMW is supposed to make the ultimate driving expperience, but here we are with a finicky car so you should fix offset if you can.
Your front axle might be 58mm more narrow than rear.
I had trouble with 24 mm too narrow that I fixed.
      08-19-2018, 10:28 PM   #25
BeeHemDoubleU IksWane's Avatar
16
Drives: BMW X1
Keep in mind that at highway speeds and while cruising downtown everything is fine. The car only stutters while acceleraring from a dead stop, typically between 10 and 30 km/h. The rest of the time all is fine
You talk about German technocracy and you get automobiles.
      08-19-2018, 11:00 PM   #26
sayemthree
sayemthree's Avatar
597
Does it matter if u are gently accelerating or accelerating hard? Since ther3 is no problem when stock wheels are back on. It’s got to be something about the tires or wheels or combo
      08-20-2018, 02:26 AM   #27
0w40X1
My s28i could be said to stutter in first gear.
Many have had loss of power when starting off which is not traction control, just feels like running out of gas. A pause.
Some times i just start in 2Nd gear, and pulls great.
I wish i could program out first gear.
      08-20-2018, 10:48 AM   #28
thestimp
Drives: 22 X3MC MBB - C-17 Globemaster
2022 X3mC  [10.00]
2016 BMW M3  [0.00]
I have this issue both starting and dropping to first at a stop, so annoying its the engines way of "handling" the torque conversion, aka shit sucks.
      08-20-2018, 01:49 PM   #29
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
I have aftermarket wheels staggered 245-40/19 fr. and 275-35/19 r. which leaves the fronts slightly taller than rears, like yours. No issues such as you describe.
      08-21-2018, 03:35 AM   #30
16
Drives: BMW X1
Just my luck
      08-24-2018, 04:14 PM   #31
0w40X1
When you say stutter, is it like what others call throttle lag?
Every time I start off I find myself playing with throttle, but it's always jumpy forward or balk unless pedal to the metal with no one in front.
      08-25-2018, 07:35 PM   #32
16
Drives: BMW X1
No. Again, the car doesnt do it with a square setup. I have a brand new engine and it was doing it with the old one too.. its not a misfire or throttle lag
The car stutters. Like little successive stomps on the brake.
      08-26-2018, 02:43 PM   #33
Dalco450
Dalco450's Avatar
84
Drives: X1 M-Sport
Mine did that with 245/40R19 and 275/35R19. Strange noises and vibrations with stuttering acceleration. Doesn’t do it with my style 230 with 225/40R19 and 255/35R19 or squared style 454 on 225/45R18. I changed the 245/275 for 225/255 on my style 225 after 3 weeks. Driving is impeccable now.
      08-27-2018, 01:58 PM   #34
16
Drives: BMW X1
Its weird. I'll lose alot of cash selling mines who are brand new for some of another size and maybe not even help with the problem. Meh
      05-11-2022, 08:07 PM   #35
Botlfed98
16
Drives: X1
Unfortunately i am experiencing the same issue with 245/35r20 & 275/30r20
      05-20-2022, 09:33 PM   #36
brad850csi
1316
Drives: 16 F13 M6 Comp
First post here - funnily enough I have just purchased an F11 528i and am looking at 324M wheels for it as they are quite lightweight and good offsets for the 5 series. Funnily enough I was also looking at E9x M3 wheels at one point too but they aren't really the right offsets for the F11.
That's what bought me here - looking for good pics of them to I can photochop them onto pictures of my car.
However I found this thread and thought I'd comment as I've seen the same things going on with the F8x M3/4 and various F01/F06/10/13 5, 6 and 7 series owners.
With the F82 the rear tyres are quite a bit taller than the front, they have the same side wall ratio front and rear but with wider tyres at the rear. This gave them 799 rotations per mile at the front and only 783 at the rear. When people kept their fronts the same 255/35r19 and changed the stock rear from 275/35r19 to 295/30r19 with the same 799 rotations at the front they had massive problems just like you describe. It was fixable by completely turning traction control off as the actual cause for the issue was the car thinking the rear wheels were spinning under acceleration.
On the E84 with staggered wheels the stock sizes are:
225/45r18 802
255/40r18 799
225/40r19 797
255/40r19 799
So I would have thought that any tyre height plus or minus a few rotations would be fine. Based on your sizes for a few different tyres I searched on they all seem to be about 5 more rotations at the rear:
245/40r18 809
275/35r18 814
I'd perhaps suggest going with a 285/35r18 which tend to be about 804 rotations as then the car will think the rear is going slightly slower than the front however I don't know what that will do to xdrive.
I also wonder if the quite different offset front and rear is creating a weird issue that the steering detects, probably to do with scrub radius - videos here.
I'd suggest perhaps going for a drive without traction control on at all (don't come back to me if you crash though haha!) and see how it goes. That should at least eliminate the chance of the scrub radius being a problem and focus on just the tyre size.
Next I'd try and find some cheap 285/35r18 tyres and see how they go. Are the current tyres all brand new with plenty of tread? If the rears had less tread that'd make is worse but second hand 285/35r18 should be OK and it should be possible to find a few second hand ones for under $100.
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
      05-20-2022, 09:39 PM   #37
brad850csi
1316
Refer to my post above please and try no traction control first then read this:
245/35r20 777
275/30r20 784
If you change your rear to 285/30r20 I think you should have a better time as their rotation is 777 as well.
Again, for trial and error I'd suggest looking out for a cheap set somewhere or if you can even find someone with a set mounted to BMW wheels they might let you borrow them for a bit. Conveniently 285/30r20 is stock for an F8x M3/4 with the comp pack and the offset even works too so finding a set with a friend may not be too hard
      03-21-2024, 05:29 PM   #38
fnp93
fnp93's Avatar
Drives: X1 35i - Z3 DASC
Undergoing the exact same problem. Slightly worried form my transfer case.
Always studders when pulling away from a stop and traction control does kick in under heavy accel
Just spent a pretty penny on a new set of Michelin ps4’s on the factory recommended tire size on the door sticker.
225/40/19 front 255/35/19 rear. I followed instructions 😅.
Any solutions from anyone.
xbimmers
