XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
      08-16-2019, 10:36 AM   #1
johnjh
Drives: bmw x1 2015 (e84)
bimmercode supports only a few modules for 2015 x1 e84 s28i
Hi,
I recently bought a full-version Bimmercode iOS app and Veepeak BLE4.0 scanner to try out coding my 2015 X1 s28i.
On Bimmercode homepage, my X1 is in the supported car list and the scanner is one of their recommendation tool.
However, when I connected my car with the app, the list of modules seems limited, which is totally different from that in demo mode. In fact, with this list, I can not code any basic coding, such as folding mirrors using the keyfob.
is there anything that I am missing to enable to code the modules unlisted at this time? or my car has kind of less-supportive ECU so no such coding is possible?
Thanks!
      08-16-2019, 11:08 AM   #2
NYBulldog
Specialist
1310
Drives: Nikes
I checked it out myself. Very disappointing. I thought it would have the same exact options from the E9X. I think you would need to play with Expert Mode and that is not exactly an ON/OFF switch. You should send a message to their Support team, they've been good to me in the past with answering about options.
      08-17-2019, 09:31 AM   #3
jjrolls
Drives: BMW X1
I talked to the support team about this. Apparently there is no way to do Enhanced Bluetooth :'( for our x1's
      08-17-2019, 05:10 PM   #4
johnjh
You mean I can see more options via WiFi?
FYI, I contacted Bimmercode cs, and he told me that this will be resolved in the next app update.
      08-17-2019, 06:11 PM   #5
jjrolls
Drives: BMW X1
We'll get more options?!
      08-21-2019, 02:02 AM   #6
johnjh
I am pretty sure that all the options described in the website for at least my car, E84 X1 2015, will be supported from the next update.
      08-28-2019, 10:09 PM   #7
jjrolls
Drives: BMW X1
When?
      12-10-2023, 06:10 AM   #8
Kingb4
Drives: BMW X1 20D XLine
Conscious this is an old thread.
I can confirm that Bimmercode will definitely enable Enhanced Bluetooth. You have to do it on the 'Expert mode'
In HEADUNIT Menu...go into Expert mode then 3003_Telefon_Telematik_Online
Turn these to "Aktiv" :
CDMM_Bluetooth_Audio
CDMM_BT_DATABASE
AUDIO_PLAYER_ON_OFF
BT_MODUL_ON_OFF
A2DP_PROFILE
In COMIBOX Menu....go into Expert mode then 3004_Bluetooth_Parameter and turn this to "Aktiv" :
A2DP_AVRCP_EIN_AUS
Have just done this on my X1 this morning - really pleased.
      03-01-2024, 10:51 PM   #9
Bhandyman1976
Drives: 2016 x4 m40
CDMM_BT_DATABASE
AUDIO_PLAYER_ON_OFF
BT_MODUL_ON_OFF
A2DP_PROFILE
A2DP_AVRCP_EIN_AUS
What is “enhanced Bluetooth”?
Any other codes you’d recommend? Only thing I’ve used it for is registering my new battery!
      03-03-2024, 09:27 AM   #10
cwickberg
32
Drives: X1 35i MSport Ultimate,
This allows streaming and to also have music data pop up on your idrive display, amongst other things
      03-05-2024, 09:16 PM   #11
Botlfed98
16
Drives: X1
is bimmercode capable of disabling TPMS ?
xbimmers
