BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > aFe Intake Fix/Solution | Surging & Power Loss Issues Resolved
      10-23-2012, 10:43 AM   #111
tj13
tj13's Avatar
Drives: '06 325i
Originally Posted by Tim603
Originally Posted by tj13 View Post
Any way I can get a spacer sent my way? I've had to wait a long time to writ on this form!
I sent it out this morning tj, I tried pming you with the tracking # but it says you can recieve messages right now?? anyways lmk if you want the tracking #
Thanks for the parts. Car runs so much smoother! Kind of wasted a lot of gas yesterday... Lol
      10-24-2012, 08:16 AM   #112
Tim603
Tim603's Avatar
Drives: 2007 335i E90
2007 335i  [0.00]
hahah nice ya I couldnt keep my foot off the pedal for a lil while after I installed mine too lol
      11-01-2012, 11:44 PM   #113
LocDawgg
Drives: AW e90
Anyone using the spacer experience any fault codes because of it? my car car been stalling a lot at red lights and while slowing down, it threw a code that said "Mass or Volume air flow A circuit low input"
      11-04-2012, 07:46 AM   #114
Brian_TII
Drives: 06 e90 330i 6spd
I haven't noticed any issues with mine, but I haven't read the codes lately either. I have no stalling or cel though. I'd make sure you sealed it up correctly and that the maf isn't actually just bad. Also look at the screw inserts on the flange of the filter, mine were not level and I had to recess / enlargen the screw holes on my custom DIY spacer to ensure it sat level.
      11-12-2012, 10:59 AM   #115
tj13
tj13's Avatar
Drives: '06 325i
I haven't had much problems with it. Every now and then my SES light turns on. The CAI had a few leaks that I fixed(ie. screws loose and new gaskets for all air tight spots). Since then no problems.
      11-14-2012, 02:45 AM   #116
E90LA
Drives: 2007 E90
im interested in a spacer... how do i get my hands on one!?
      11-14-2012, 10:06 PM   #117
apptwins
apptwins's Avatar
Drives: e90 2006 325xi 6MT
Hi guys -
Received a spacer/shim from Tim a month or so ago. Installed it right away. Thought I would wait a bit and drive my 3'er for a few weeks before providing feedback.
I did have the bloody SES light on when I installed it. Geez, getting a sunburn from that friggen thing. Light was still on till I acquired a PEAKE code reader tool. Reset the code and the car has run great for the duration.
In the mean time I have installed a Rogue - ICON stainless pipe and deleted the worthless piece(s) of garbage secondary/post Cat's. The exhaust sounds so sweet it is un-F'ing-believable! It is too much fun mod'ing these wonderful Bimmers.
Many thanks (again) to Tim for facilitating this shim solution to the aFe intake system.
Cheers mates.
Cheers-Bill
2006 E90 (early build 11/05) 325xi 6MT Alpine White, DeBadged, Rogue-ICON, stainless brakelines, Power Slot rotors, CDV delete, post-CAT delete, aFe intake+MAF TimShim, LED interior lighting, Escort Passport 8500 x50
      12-10-2012, 11:18 AM   #118
Tim603
Tim603's Avatar
2007 335i  [0.00]
Hey J Dawg if your reading this, you need to make posts before i can send you a pm. If its easier just contact my email at timmcmahon.2011@gmail.com
Also I haven't received a single fault code since i installed my spacer for the MAF so for all of you out there using it just make sure the spacer is completely sealed up and you should not have any problems (otherwise it might be the MAF with the issue). Happy Holidays everyone!
      12-10-2012, 05:05 PM   #119
NoImDirtyDan
NoImDirtyDan's Avatar
Drives: 2018 BMW M3
2018 BMW M3  [0.00]
When I got mine made, I had two extra's made just incase, I dont have any use for them anymore. If you're out of stock Tim I dont mind selling mine.
      12-10-2012, 07:48 PM   #120
geyer25
Drives: 2008 BMW 328 xi
I have an AFE intake on the way for my 08 328 xi, is this spacer as good as it sounds and is it definitely needed?
      12-11-2012, 08:27 AM   #121
Tim603
Tim603's Avatar
2007 335i  [0.00]
Thanks man I appreciate that Ill have to let you know
It made a big difference on my car, theres a pretty good amount of testimonials on this thread
      12-11-2012, 06:43 PM   #122
rich123321
rich123321's Avatar
Drives: BMW 325i E90
2015 335i  [0.00]
Got some surging today again
EDIT- Dirty MAF... Good as new
      12-11-2012, 08:55 PM   #123
geyer25
Originally Posted by rich123321
Got some surging today again I think it could be from a air leak or maf sensor damage because ive cleaned it 2x within the past 3 months
And you have the spacer so could it just be in everyone's MAF sensor?
      12-19-2012, 08:30 AM   #124
DGrady11
Drives: BMW E90 325i
I have the same problem... good to know the solution
      12-19-2012, 08:37 AM   #125
DGrady11
Tim you still making the spacers?
      01-15-2013, 06:51 PM   #126
digz
Drives: 2006 325xi
I have 2006 325 xi and i bought the afe intake model # 51/54-1102 had my mechanic install it.
PROBLEM #1
the coupler 3.5x2 didn"t fit to big had to spend $40 for a new one.
PROBLEM #2
losing power now it sucks bad was about to spend $ to reprogram the car.
PROBLEM#3
called AFE they said they never heard of this beforeand they cant do anything for me. I told thm to read these post. I sent them the lnk 3 times and he said he never got it. now i have to pay someone to make this spacer so hopefully it works. they said just upgrade to a new one. the company doesnt want to hear the problems they have wrong and fix them just make money. I'm going to call back and see where i get. if anyone else has these isues call maybe if they get enough calls things will change.
      01-15-2013, 08:18 PM   #127
rich123321
rich123321's Avatar
2015 335i  [0.00]
PROBLEM #1
PROBLEM #2
PROBLEM#3
They know about the problem for sure. Buy the spacer and be happy with the intake or return it
      01-16-2013, 03:31 PM   #128
digz
Drives: 2006 325xi
its beening made right now. i dont want to return it it sounds good. we'll see how it runs after that.
      01-16-2013, 05:25 PM   #129
NoImDirtyDan
Drives: 2018 BMW M3
2018 BMW M3  [0.00]
I have two spacers if anyone needs them $50 shipped.
      01-16-2013, 05:46 PM   #130
digz
Drives: 2006 325xi
ohsix,
let me see how the one thats get made for me works . if the happens that it doesnt work.. i might have take one off your hands.. i"ll let ya know by this weekend. im also getting the throttle cleaned and reprogramed to fit the way i drive. do you think its worth the $200 to do this to my car. im still new to bmw just got it not to long ago and starting to work on things......
      01-18-2013, 07:57 PM   #131
digz
Drives: 2006 325xi
had the spacer made and put on today. it makes so much of a difference. it runs perfect. also had memory relearn and throttle relearn. that dead spot that was there before when i took off. its gone step on it and go......
thanks for the info on the spacer great find......
      01-19-2013, 10:42 PM   #132
LeonardBMW
1Addict Lets MOD!
LeonardBMW's Avatar
Drives: 2009 135i E82
I recently installed the AFE intake. Has anyone ever had a "yellow engine malfunction" symbol come up? Is this symptom linked to the spacing issue? I havnt noticed any performance issues yet with the intake (in a negative way). Until the light. Which after letting the engine cool after along hard drive, and restarted the car, the light and limited power were gone. I've only experienced this symptom once recently.
afe, issues, power, problems, surging
