BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      09-02-2014, 03:33 AM   #1
X88RED
X88RED's Avatar
Drives: E92 M3
Thumbs down Clutch and flywheel question
Hello
Just had a new clutch and flywheel fitted - typical me didn't think about the break in procedure and was never told by BMW about this either. Now I think I should be ok as in I have not launched the car or redlined and changed gear since getting it done. Although I would say that I may have changed gear above 5k revs at a few points (nothing really excessive as far as I can remember) Is this something to worry about and have I potentially affected my clutch and flywheel? I have not experienced any shattering or anything.
      09-02-2014, 04:32 AM   #2
SenorFunkyPants
SenorFunkyPants's Avatar
2511
Drives: 2019 M5
You should be fine....I think as long as you avoid overheating the clutch (excessive clutch slip) in the first 100 miles or two you won't have a problem.
      09-02-2014, 06:48 AM   #3
X88RED
X88RED's Avatar
Drives: E92 M3
Ok its just I have been reading all this stuff about dont go over this rpm for 500 miles etc, kinda worries you.
I know in the manual it states to engage the clutch gently for 300 miles when you intitally break in the car, so not sure about that?
      09-02-2014, 07:17 AM   #4
SenorFunkyPants
2511
Drives: 2019 M5
Originally Posted by X88RED View Post
[...] engage the clutch gently for 300 miles when you intitally break in the car, so not sure about that?
I would go with that.
      09-02-2014, 07:57 AM   #5
X88RED
X88RED's Avatar
Drives: E92 M3
The thing is I have not been doing that - well not gently.. and have probaly already covered that
      09-02-2014, 08:35 AM   #6
SenorFunkyPants
2511
Drives: 2019 M5
You will be fine...you are only trying to bed in the clutch friction material against the flywheel surface, a bit like when you have new brake pads - you don't go bananas for a 100 miles or so then you are good to go.
      09-04-2014, 11:14 PM   #7
douglee25
92
Drives: E36 M3
Believe it or not, you actually WANT to slip the clutch a little more on the first few hundred miles so it deposits some of the friction material on flywheel surface. Again, it's similar to bedding in brakes.
Doug
      09-04-2014, 11:33 PM   #8
Arben
Dunce Cap
Arben's Avatar
Drives: '12 E92 M
Isn't it to late for it to matter now? Drive it and enjoy it, don't let things you can no longer change effect your mood.
      09-04-2014, 11:42 PM   #9
douglee25
92
Drives: E36 M3
Agree with the above. It will be fine.
Most race teams barely break in a clutch before beating the crap out of it.
Just drive it.
Doug
      09-05-2014, 07:05 AM   #10
X88RED
X88RED's Avatar
Drives: E92 M3
Thanks guys.. im going to forget about it now and just enjoy the car.
clutch, flywheel, question, slipping
m3post
