325i to 330i conversion successful! Dyno charts included!
04-21-2010, 01:54 PM | #111 | |
Freight Dawg
104
Rep 2,103
There apparently is a small difference between a manifold an a header, at least on the exhaust side. I'm not exaclty sure but a factory car usually comes with an exhaust manifold and if you go aftermarket you can get headers. Semantics aside they are esentially the same.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
04-21-2010, 02:03 PM | #112 |
Freight Dawg
104
Rep 2,103
328 owners: if you have an N52N, this mod will most likely work. The engine block pistons and exhaust manifolds are the same as a 330. The rest of the exhaust will have no bearing on software tuning. If you have an N51 you already have a 3-stage intake manifold but your compression ratios are different so this will not work. However, you can just get aftermarket software and get more power with the engine you have. You can go to www.realoem.com and compare the part numbers to double check.
PBX owners: Using this in conjuction with aftermarket engine software is not a good idea. It's like saying, "I want an AFE intake and a Gruppe M intake." That will probably not work out well. Aftermarket tuners can tune the throttle for you. Also, ECU will most likely adapt out the tuning from the PBX if you go with aftermarket tuning.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors Last edited by e90pilot; 04-21-2010 at 02:16 PM.. |
04-21-2010, 04:58 PM | #114 |
Rep 144
Ok, lemme get this straight. The software is`nt custom software, it is the powerchip 330 tuning software.When you slap the intake in and do the software the disa valves operate just like a 330?
04-21-2010, 05:15 PM | #115 |
Freight Dawg
104
Rep 2,103
It's been mentioned in this thread that the DISA valves will work like the 330i with the stock 325i software.
--Marcelo
04-21-2010, 08:40 PM | #116 | |
cool beans
63
Rep 1,364
Some people reported flat spots in the full throttle acceleration. This can be fixed with software. |
04-21-2010, 08:47 PM | #117 | |
cool beans
63
Rep 1,364
Any different software we could buy? Anything cheaper than the powerchip that works with the 325? |
04-21-2010, 08:48 PM | #118 |
Rep 241
okay, so do i send in my 325i ecu for a 330 tune or do i need a 330 ecu for it to get tune
04-21-2010, 09:24 PM | #119 |
Freight Dawg
104
Rep 2,103
Both cars use the same ECU.
--Marcelo
04-21-2010, 10:14 PM | #120 |
台北 台灣
44
Rep 619
Drives: 2004 MazdaSpeed Miata
So, basically what I will need to do is to order the intake manifold and install it myself-- that will gain 8hp... And get the powerchip which will give me a total of extra 30hp. Am I right? I was being a bit confused after reading all six pages..
2006 E90 325i AT TiAG...Sold!
2000 E39 M5 "The Beast"...Sold! 2004 Mazda Speed Miata... Bone Stock... 2000 Ford Explorer... Beater all the way |
04-21-2010, 10:28 PM | #121 |
Freight Dawg
104
Rep 2,103
Correct me if I'm wrong... But didn't I say that in my first post? Lol!
--Marcelo
04-22-2010, 07:17 AM | #122 |
台北 台灣
44
Rep 619
yea you did.. its just after reading all six pages I got a bit confused with all those numbers and charts.. lol
04-22-2010, 07:32 AM | #123 |
台北 台灣
44
Rep 619
has anyone try to combine this tune with an aftermarket intake? outcome?
04-22-2010, 11:49 AM | #124 |
Rep 1,040
04-22-2010, 01:07 PM | #125 | |
10
Rep 224
actual hp gains are prob somewhere between 3-6 hp from an intake, although some claim 10 hp like the injen, but i don't remember if this is actual, and i have heard that there is also some loss at a certain RPM. ( i have bmw perf intake FWIW. ) and this MOD would 100% NOT be affected by different intakes or exhausts, except for perhaps helping in power gains. so there won't be any problems springing up from varying set-ups. |
04-22-2010, 02:10 PM | #126 |
bimmer freak
98
Rep 579
i just typed 11617559523 into realoem and its showing this part is for both 330 and 328.
heres the e90s it says: E90: Details on E90 E90 328i Sedan E90 328xi Sedan E90 330i Sedan E90 330xi Sedan is it possible the 328s already use the manifold? perhaps with downgraded software which is why it only has 15hp over the 325 rather than the 30hp of the 330 |
04-22-2010, 03:28 PM | #129 |
Freight Dawg
104
Rep 2,103
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors Last edited by e90pilot; 04-22-2010 at 03:39 PM.. |
04-22-2010, 04:10 PM | #130 |
Dillo boxers
272
Rep 3,360
And would therefore be ineligible for this swap?
Which models came with this engine?
2019 M5C Matte MBB / Tartufo
04-22-2010, 10:39 PM | #131 | |
Freight Dawg
104
Rep 2,103
--Marcelo
04-23-2010, 12:14 PM | #132 |
Rep 249
great job on the swap man...are you planning on writting up DIY for this mod?
What did the five fingers say to the face?
COOOOOLD BLOODED! |
330i coversion, active autowerke, manifold swap, n52, tune |
