02-12-2014, 04:14 PM | #45 |
354
Rep 2,190
Looks like aftermarket wheels from the F10 5 series will transfer perfectly over to the F8x M3/4
mmmmm....... |
02-12-2014, 04:41 PM | #46 | |
General
21121
Rep 20,741
Drives: 2021 911 turbo
There are a few negatives. First, you need longer bolts with spacers which increases the stresses in the bolts due to the increased bending forces and doubled shear points. Second is that you need to rely on two "friction" surfaces to hold the wheel in place instead of only one. Both of which increase the chance of a failure (minimal for street use, IMO). Then, if you use spacers that alter the wheel center position relative to the hub (as opposed to using a spacer that brings an offending wheel back to OEM specs), you will affect how the suspension behaves. For example, I installed 15mm spacers in the front of my E92 M3 and I have clearly lost some steering feel because of it. This would also impact how the wheel bearings are loaded and could lead to premature wear (which could end up being negligible over the life of the car). Naturally, the larger the spacer and/or the larger the change of the wheel to hub position relative to OEM spec, the greater the impacts. |
02-12-2014, 05:24 PM | #47 |
Rep 3,688
Drives: 2021 Supra 3.0 (Past: 2015 M23
The black rims here are all black or those US specs?
02-12-2014, 05:56 PM | #49 | |
Moderator
7517
Rep 19,368
No since there was no CCB option that would preclude 18" winter wheels.
02-12-2014, 09:21 PM | #51 |
Rainbow Racer
1008
Rep 2,540
the 19" winter wheel looks awesome (probably the best in my eyes)...too bad they don't come in 19x10 for the rears though, they would make a great all-year wheel.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
02-12-2014, 09:25 PM | #52 |
15
Rep 342
Drives: 2013 BWM 335i M Sport sapphire
Why is it that no one is concerned about wheel weight, that's the #1 question I want to know after the wheel size and construction. What is up with all the use of spacers, all they do is add weight, weaken bolt integrity, adds another friction point and cost money - if one can afford a $62k car can they not afford the wheels?
02-12-2014, 11:00 PM | #53 | |||
Rep 7,298
And there are a bunch of other factors. Clearance to the strut, the overall width of the wheel, blah blah. Is there 15mm clearance? Prob. But i dont consider +25 concave whatsoever are they? Especially on a bigger wheel. Look at the te37 19" +22. Then look at 18"+22. Then possibly a 20" on this car. I couldn't imagine a 19"+25 to look concave at all. Then look at 19" +teens on other cars like a 370z. You cant just say i want x offset because it will give more concavity on a wheel and slap it on. How do i not understand wheel fitment? If the f10 could be a guage what are those guys running with an 11" wheel, which i suspect ppl will be getting on the new m3/4. 19x11+30 to 40? |
02-12-2014, 11:29 PM | #54 |
Rep 735
If anyone wants to learn more about the topic of off-sets, spend a few minutes on this site and you can answer all of your questions as there are a lot of variables to take into consideration.
http://www.e90post.com/forums/forumdisplay.php?f=12 Last edited by scrammer; 02-13-2014 at 09:27 AM.. |
02-13-2014, 12:08 AM | #55 |
Rep 7,298
oh gosh...ok here we go.
10" wheel with +40 offset vs. 11" wheel with +15 (super deep concave) its 38mm "more aggressive" (for lack of a better term), or 38mm more towards the outside. Add in a chunkier beefier tire that most of us almost always decide to run. is there almost 2" of space to work with on the outside? an 11" with +25 could possibly work as it is about an inch more out...but with fatter tires maybe close again. with the stock size wheel its exactly like putting a 15mm spacer to the stock wheel (going to +25 from +40) but who wants stock sizes?! id imagine ppl putting wider wheels, fatter tires on the new car with all that power. this is what i was talking about. I sure didnt need an offset calculator for that but i guess ppl need specifics in here |
02-13-2014, 12:51 AM | #56 | |
Rep 881
I certainly hope we will be able to fit the BBS FI with the F10 M5 fitment! |
02-13-2014, 06:02 AM | #57 |
Rep 939
02-13-2014, 06:10 AM | #58 |
Dinosaur supervisor
3030
Rep 4,214
I bet you can fit 15-20mm more aggressive offsets than stock (like always) so it shouldn't be a problem!
02-13-2014, 09:43 AM | #60 |
Rep 1,555
How would the 219M wheels, OEM 18s from E92 fit for winter setup?
18 x 8.5 offset 29 front 18 x 9.5 offset 23 rear
2011 E82 1M VO
2013 F84 35i VO |
02-13-2014, 10:18 AM | #61 |
Rep 4,190
I have these square setup winter wheels leftover from my 1M. I'm guessing they won't fit?
Size: 18x8 Offset: 20mm Backspacing: 5.31" Bolt Pattern: 5-120 Rec. Tire Size: 235/40-18 |
02-13-2014, 10:19 AM | #62 |
Rep 813
great info! the 18s look small
21 M5C DD|21 M550 xDrive|05 E46M3 race car 6SPD|2019 2LT Corvette GS 7SPD track car|22 Tundra SR5 TRD Sport|19 Q7 V6 & 22 Q7 2.0T|20 G63|19 Vantage 4.0TT|22 Boxster 25 Year 6SPD sold|08 Porsche Cayman 5SPD sold|18 R8 RWS sold|Many previous cars
02-13-2014, 10:33 AM | #64 |
Moderator
7517
Rep 19,368
02-13-2014, 11:01 AM | #66 | |
General
21121
Rep 20,741
I also plan on going to 245/40-18 PA4 once my 235/40-18 PA3 are worn out. |
