07-27-2017, 09:23 PM | #90 |
1301
Rep 2,093
Drives: '11 135i M Sport
Little teaser. Bumper has been wet sanded, compounded and polished. Wheels mounted and sealant put on.
Last few things to wrap up tomorrow and hopefully pull it out of the garage just in time for a rainy weekend drive.
Matticus913474.50 |
07-28-2017, 08:25 AM | #91 | |
FOUO
415
Rep 873
And FYI, I learned this the hard way... If you decide to swap out your rear bumper carrier, MAKE sure to replace that gasket (or put over). It's a one time use gasket, and that was the culprit to my water leak in the trunk. I still don't understand how water could go up from the bumper carrier, but it definitely fried my amp and CA modules. |
07-28-2017, 09:00 AM | #92 | ||
1301
Rep 2,093
Ill see if I can take a quick shot of how it turned out. I planned it carefully and you can't really notice where I made the cut. Quote:
- Added picture of where I cut the liner next to the bolt. Best picture I can do until the cars on the lift again.
07-29-2017, 04:11 PM | #93 |
1301
Rep 2,093
Finally done. Took it for a drive this morning with a break in the rain. Beyond happy with how it turned out.
07-30-2017, 04:54 PM | #94 |
1301
Rep 2,093
Some better pictures out in the sun with the good camera today before taking it on a nice drive.
Also laste update for a while until this winter. Up next will be Ohlins R&T, 1M/M3 control arms w/ rouge or turner bushing, knuckles, etc. and finally 1M/M3 brakes or StopTech. Haven't made up my mind on brakes yet.
07-30-2017, 06:40 PM | #95 | |
Rep 7,224
Yeineken1300.50 |
08-01-2017, 10:58 AM | #97 |
Rep 3,722
I am SO impressed by your paintwork on these. The fact that this was done with rattle cans blows my mind.
Car is looking awesome man!!
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
Yeineken1300.50 |
08-01-2017, 09:14 PM | #99 |
1301
Rep 2,093
I removed the first bottom plastic bolt that holds the side skirt to the body so I could pull it outward to wrap over the M3 fender liner. The M3 fender liner is supper tough compared to the plastic side skirt and holds it well. Once it's in place you'll have to heat and start pushing in the top of the side skirt to start matching the 1M fender.
As you can see mine came back out a little after a couple days. Just need to reheat and keep chasing it until it finally takes the right form.
08-02-2017, 08:40 PM | #100 |
Rep 11
Fitment is not bad at all! I was debating to the conversion piecemeal, but I think I'm just going to do it all at once after I find a good shop to do the rear quarters.
08-02-2017, 10:00 PM | #101 |
1301
Rep 2,093
Yea it's not a bad temporary solution. Just realized how bad those pictures make it look. In natural light it looks decent. It also helps the car is black as well. Really hides it.
08-09-2017, 08:32 PM | #103 |
1301
Rep 2,093
18x9.5 et22 with PSS 255/35/18
08-10-2017, 08:34 AM | #104 |
1Addict
3234
Rep 7,894
Do you have any poke? Running my rear wheel with a 20mm spacer will poke 12mm less than your setup.
08-10-2017, 11:53 AM | #105 | |
1301
Rep 2,093
Once I install the M bits up front it should bring the wheel in just a little.
08-10-2017, 05:06 PM | #106 | |
1Addict
3234
Rep 7,894
Another note, the M3 arms up front will push the bottom of the wheel out, top stays put. Just a fyi.
Yeineken1300.50 |
08-13-2017, 04:39 PM | #107 |
1301
Rep 2,093
Got around to installing my Lightweight Fender Decals. Wasn't sure how they would look on a BSM car but I think they came out pretty well.
Matticus913474.50 |
09-18-2017, 10:13 AM | #108 |
1301
Rep 2,093
Nice dewy morning and the car was left outside... decided to play with the camera.
Esteban43802.00 Matticus913474.50 |
09-29-2017, 09:20 AM | #110 |
1301
Rep 2,093
Got some black chrome presents from IND.
Matticus913474.50 acoustix268.00 |
