09-09-2020, 06:23 PM | #67 | |
Rep 584
* 2011 M3 DCT * Built 4.4L Stroker * Gintani supercharger * Brembo GT * BBS FI * OHLINS * Nardo Grey *
09-09-2020, 09:28 PM | #68 |
272
Rep 298
I finally received my torque wrench today and after my family outing, went to work pulling half the shells so far. I first verified the arp 2000 rod bolts were torqued to at least 50ft lbs, then pulled and inspected the shell and journal, put arp lube on the bolts, assembly lube on the shells and reinstalled to 50ft lbs. So far no damage. I'll post some pics of the BE bearings soon. I only pulled and took pictures of the bottom shells, i moved the piston to look at the top shell but did not pull it unless it looked like it was installed wrong. So far all the bearings i pulled look brand new with 28k on them.
09-09-2020, 10:58 PM | #70 |
272
Rep 298
ok. i found where at least some of where the bearing material originated from. on my next crank rotation i ended up exposing the first 2 sets of rod bearings, i guess cylinders 1 and 2. After confirming torque i loosened the cap and tried to get it off but it wouldn't budge so i figured i must have found the problem, after tapping it with a rubber mallet several times i was able to get the cap off but without the rod bearing. Both upper and lower rod bearings were stuck to the journal. i was like oh crap, they are probably welded to the crank, however, using a dentist pick, i carefully pulled at the seating tab and managed to pull both shells of the journal. The shells look they took most of the damage. The journal doesn't look horrible in my opinion, slightly scored. The shells have mostly black scoring only in the center. At this point i am not sure how to proceed.Should i assume, based on the black scoring to the middle of the shell, the mains may have just started to fail, reducing/blocking oil to that bearing or some foreign material managed to get into the shell and that caused the scoring? if no additional damage can be seen, should I buy new rod bearings and replace and hope for the best? Should I attempt to lightly lap/polish the journal? Not sure if that is even possible without re-heat treating it.
akkando5864.50 Robocop30512.00 |
09-09-2020, 11:06 PM | #71 |
3752
Rep 2,907
Drives: 2011 E93 M3
I would be concerned that the main bearing above those shells had started to fail and blocked oil flow to those rod bearings.
09-10-2020, 06:20 AM | #73 |
Rep 3,337
Hope the core qualifies and order a 4.2L rebuilt S65 from Carbahn?
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
Bartledoo2691.50 |
09-10-2020, 07:52 AM | #74 |
272
Rep 298
Based on the size of the debris from the original install and the clearances with the rod bearings, it does not look like it would be possible for that to occur. Deansbimmer indicated this when i spoke with him about it. And if it were possible, i would think it would get embedded in the babit before destroying the shells, and probably would have happened sooner. I am just a shade tree mechanic at best, but i agree with Deansbimmer, that the mains started to fail reduced oil flow to those shells. If the pictures pretty clearly show that i should not attempt to only replace the damaged bearings and put it back in service and that a tear down is 99.9% required at this point, then a used engine or a carbahn rebuild is probably the most logical at this point. I am leaning towards carbahn. Its a tough pill to swallow not knowing if the mains are what caused the rod bearings to truly fail. once i pull the engine, is it possible/worth attempting to inspect the mains myself? I am guessing i would have to pull the crank in order to inspect the mains and i don't think i could do that especially without messing up timing or something else and maybe that doesnt matter as long as the core is viable.
09-10-2020, 10:32 AM | #76 |
272
Rep 298
that's because when a main spins it usually cracks the webbing in the saddle, correct? if that is the case and i were to take my engine out and pay to ship it to carbahn as a usable core, then It would behoove me to attempt to remove the bedplate my self to confirm the damage before wasting time and money to ship it out only for carbahn and for them to tell me the same thing? Else, take my chances with a used engine and sell my longblock as is to recoop some of the cost? it sounds like those are my options moving forward.
09-10-2020, 10:36 AM | #77 |
272
Rep 298
Without removing the timing chain or tensioner, could i follow your Main bearing service DIY to just remove the bedplate and inspect half the mains? if none are stuck to the journal and the journal looks clean, is that enough of a confirmation to hopefully consider the core viable?
09-10-2020, 09:29 PM | #78 | |
356
Rep 361
Also when you get a chance would you mind posting the pics of the other rod bearings you pulled? Would be one of the few examples of aftermarket bearings (especially BE) pulled after installation to see the wear (or lack thereof). |
09-11-2020, 09:44 AM | #79 | |
272
Rep 298
09-11-2020, 12:49 PM | #80 |
Rep 950
All I have to say is I thought you were crazy when you started this thread. I would have just drove it and hoped for the best. You made the right decision, not entirely sure that the outcome will be any different, though I am hoping for the best for you💪
09-11-2020, 05:25 PM | #81 |
116
Rep 159
I'm thinking the oil pump/front seal/timing chain would hold up the front of the crankshaft. Would the rear main seal housing hold up the rear? I don't know how much play is in the transmission input shaft. Look around the perimeter of the bed plate to see if anything is bolted to it, including the oil pump, front inner timing cover or the transmission bellhousing. Just some things to think about/look at until someone that knows responds!
09-18-2020, 02:26 PM | #82 |
272
Rep 298
It is with heavy heart that I am selling my car. I was originally going to attempt a stroker build, but I decided to put it back together and sell it as is. It still runs, however has slight rod knock. I listed it in the classifieds if anyone is interested. Thanks for all the support, I really, really appreciate it. I hope to get back into another M soon. Man, I am going to miss this car so much.
Blindside_1376709.50 |
09-20-2020, 12:48 AM | #83 | |
3237
Rep 2,160
09-20-2020, 01:53 AM | #84 |
Rep 860
Dan, While in the end the bearings were destroyed, I’m not convinced you could blame the bearings for failing. If the two rods failed side by side without obvious signs of installation error, it’s more likely there was oil starvation leading to ultimate failure. I don’t think we will really ever know unless the buyer of the car tears it down and proves or disproves the theory that the Upstream main failure caused oil starvation.
Edit- take note that the other inspected BE bearings on the engine showed basically no wear in 28k miles. |
09-20-2020, 03:37 PM | #85 | |
272
Rep 298
Blindside_1376709.50 Assimilator1594.00 |
09-20-2020, 04:11 PM | #86 |
272
Rep 298
Only the first cylinder rod bearing failed. I ended up replacing the failed rod bearing with one of my original oem rod bearings. It drove fine for about a mile then started knocking again so most likely #1 main failed.
09-20-2020, 05:30 PM | #87 |
3237
Rep 2,160
I thought when a main bearing fails, it doesn't knock but rather just seize up the motor completely.
Robocop30512.00 |
09-20-2020, 08:24 PM | #88 | |
3752
Rep 2,907
Drives: 2011 E93 M3
I've seen engines with BE bearings fail, but only due to main failure. |
