BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > General M3 Forum (E90 + E92 + E93)
European Auto Source (EAS)
      03-27-2024, 08:49 PM   #1
anotherchengman
Drives: 2007 BMW 328i
Air Filter Solution for Pre 09/09 M3s
As some of you have heard, BMW/Mahle have discontinued the charcoal lined (p/n 13727838805) air filters for pre 09/09 M3s. The difference is the spring loaded nub in the intake housing. I have designed a ABS printed replacement to allow you to reuse your existing housing with the later paper filter (p/n 13727838804).
If anyone is interested, I would be happy to make and sell these to support those who do not want to replace their air boxes or run aftermarket filters.
Appreciate 4
Ajolives922.00
akkando5864.50
      03-28-2024, 11:44 AM   #2
NiBe
453
Drives: BMW E91 & E92
Hi, this shocked me a little bit. I have 2008. But per my research this applies "only" to US models, right? For EU models (mine) I use the 13727838804, right?
US 2008:
https://www.realoem.com/bmw/enUS/sho...diagId=13_1243
EU 2008:
It really sucks, sorry about that my US friends.
      03-28-2024, 04:24 PM   #3
anotherchengman
Yes it applies to US models only it seems. The filter had an activated carbon layer for evaporative gases when engine is off.
NiBe453.00
      03-28-2024, 05:36 PM   #4
NiBe
453
Thanks for that. Your solution is good. I saw it on some other websites also when doing the research. I hope that the ABS is able to go through heat cycles without shrinking or changing its shape. Btw you could also publish your STL file, I guess people from the forum would appreciate it Still many people would buy it because they don't have a printer.
      04-01-2024, 02:24 PM   #5
LKN624
LKN624's Avatar
Germany
274
Drives: 08' E90 M3 and 08' E92 M3
Just an FYI, you can still search for Mahle LX1667. They are the same filters that came from BMW and are still available.
      04-04-2024, 10:17 PM   #6
anotherchengman
The mahle is discontinued too. Whatever is being sold is the remaining stock
jd501371.00
m3post
