2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications LSD for F10 550i 6MT
      05-06-2018, 04:28 PM   #1
windowmaker
70
Drives: 2013 550i M Sport 6MT
Thinking of getting this LSD for my '13 550i 6MT:
https://www.ecstuning.com/b-wavetrac...309172wkwvtkt/
I looked up Quaife as well but it appears they don't make one for the manual, and Wavetrac on paper has some competitive advantages in zero traction scenarios (one wheel off the ground/ice).
I called a differential shop to ask if they would install this Wavetrac diff and he was reluctant since they've had customers complain due to a clunking behavior specifically with the Wavetrac (despite backlash being set to spec). He commented that it could have been due to the suspension being designed around the open diff and not meshing well with LSD. He didn't comment whether this was with this particular year/model so this isn't too deterring for me without more info.
Anyone done the conversion with Wavetrac or other brands? Thoughts?
      05-10-2018, 02:21 PM   #2
frankfuster
Drives: 2015 BMW 550i
Would love to know as well. Although I suggest you call up Birds Auto UK directly, it might be that when they state "550i" they mean the manual transmission car versus when they state "550i auto".
http://www.birdsauto.com/tuning/search?s=42855
      08-16-2018, 12:33 AM   #3
Punisher007
Drives: 2015 550
Any updates? I’d like to know also
      08-20-2018, 11:52 PM   #4
windowmaker
70
Still planning on the Wavetrac but I'd decided to hold off on getting it until some time next year.
      08-11-2019, 03:38 PM   #5
jayster0966
jayster0966's Avatar
Drives: 2011 535i
Anyone ever get this done on their f10 yet? Been wanting to do this ever since all my engine mods are now done and have experienced really lousy traction characteristics on the strip/track.
      08-12-2019, 11:23 PM   #6
Klerin
Klerin's Avatar
Drives: 2014 550i M-sport
putting this in my bucket list. I almost cried the day I found out the 550i has an open differential following a one wheel burnout.
      09-14-2019, 10:32 PM   #7
jayster0966
Drives: 2011 535i
Wavetrac LSD
Finally got my LSD in this week. Now, to find time to have it installed. [IMG]undefined[/IMG]
      09-15-2019, 02:08 AM   #8
windowmaker
70
Keep us updated
      01-19-2021, 05:28 PM   #9
OppositeLock72
Drives: BMW 550i 6-Sp
Any Update on this LSD?
      01-20-2021, 06:25 PM   #10
jayster0966
Drives: 2011 535i
The one from wavetrac actually did not fit and correct version was still under development when COVID hit. Have not checked back with them since then. I really should as they are local to me. Thanks for the reminder.
      01-22-2021, 10:31 AM   #11
OppositeLock72
It did not fit? As in: you ordered the one spec'ed for your F10 535i and it didn't fit when you tried to install it? That's startling. Any story behind it?
But yeah - let us know if you find out anything. I've been planning on the Wavetrac from ECS Turning for a while now. My 550 is such a great car with this huge, ugly glaring fault. My track experience is pretty much ruined by the open diff - I'm a track rat but I won't do another one until I'm running the LSD. I'm absolutely appalled BMW would install an open diff in any high powered car of theirs.
      01-25-2021, 07:03 PM   #12
jayster0966
Drives: 2011 535i
Yes I did order the unit specifically for my car and good thing I checked axle fitment before pulling the diff completely off. Problem being was the spline count was wrong and axle shaft diameter hole was too small.
I was lucky enough to be able to sell it locally to someone with an E90 and he says it fit perfectly.
      04-22-2021, 07:08 PM   #13
OppositeLock72
I went and talked to my local BMW shop about LSD's. They work with diffsonline.com to put LSD's in these F10's. Diffsonline doesn't have anything on their website for F10's, so its a custom job ostensibly. I can't get a price out of either without digging further.
Anyone have comments on how tough it is to install the Wavetrac yourself? ECStuning has the diff + install kit for the M/T cars and that sure sounds like a fun project.
***UPDATE: DiffsOnline got back to me and said this is something they do indeed do without being what they would define as 'custom.' Dan there quoted me at $2.8k (parts & labor) to move to a Wavetrac.
      03-18-2024, 11:50 AM   #14
windowmaker
70
Finally decided to order a Quaife LSD for the 550i, from Birds Auto in UK.
Prefabricated complete diff to avoid a long downtime for the car, and leaving it to the Birds Auto experts who have done many of these conversions. It requires cutting of the welded ring gear and some other machine work to convert it from the stock diff.
No coding required since the electronic diff is controlled by ABS when wheels slip.
Already negotiated installation labor on home soil once it arrives. Just gotta order some gear 75W-90 gear oil, probably will be Amsoil. Need to figure out the required volume.
bake601.50
      03-21-2024, 11:43 PM   #15
windowmaker
70
Placed the order for the diff, confirmed with a scope that for the Manual it is a 3.08 final drive ratio. Ordered 75W-90 Amsoil diff fluid and a magnetic drain plug.
Might have to extend labor cost to replace clutch pilot/throw out bearing since it's making more noise than it did before.
Hornet-01121.50
5post
