2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Heat Exchanger Bolts Torque Specs
      03-03-2024, 06:41 PM   #1
Conserve
186
Drives: 1976 BMW 2002 & 2015 BMW535i
I replaced head exchanger gasket 7 months ago and now noticed trace of oil leaks. At the time I reused existing bolts (M8X20) because I had ordered wrong ones (M8X25, other heat exchanger type) and needed to get the job done at that time.
For those with ISTA and Service Repair Manual I have two question before I proceed to fix oil leak.
1). What is torque specs for item #10 (prevoiusly used torque chart shown).
2). Is manual telling us to reuse the bolts or new ones are must per manual.
Thanks in advance. Regards
      03-04-2024, 09:35 AM   #2
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
16nm, can reuse bolts.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets
ISTA VM Setup/Tutorial
      03-04-2024, 07:18 PM   #3
Conserve
186
Unspec Thank You for your respond. I am going to monitor it now and if it continues to leak I will replace gasket with OEM ones. Because I double check torque specs and it is right-on and with that it leaves me to think is the gasket.
      03-15-2024, 10:50 PM   #4
ChiltiCoatl89
ChiltiCoatl89's Avatar
I just got this gasket and the OFHG and I have watched and read it must be done very carefully, thankfully on my car it has been replaced already at around 40k however I am waiting for the day to see the leak appear from around that area. Hope you got it all taken care of!
5post
