n52 Tune for 3 Stage Intake Manifold - new CA smog test
11-08-2021, 12:40 PM | #45 |
Rep 7,215
The checksum is updated regardless of how you flash, and the VIN is always going to be there (unless you got a donor DME or something). I think it will be fine but I can't know for sure because in expert mode it doesn't write to the UIF, but I also do not know if the DME even uses that to report the software version info to CARB. As long as the DME reports the software version that's actually inside your DME to CARB, then it doesn't matter.
Batch flashing always uses expert mode - that's how it works. If you want to use comfort mode, you have to use the WinKFP interface and flash it by entering your VIN. |
11-08-2021, 12:49 PM | #46 | |
996
Rep 2,287
11-08-2021, 01:02 PM | #47 |
Rep 642
rjahl
Can you enlighten me on how to flash using comfort mode then? I don't care about the "coding error." I just need to complete the process using comfort mode so it will update the vin/checksum for smog purposes. |
11-08-2021, 01:07 PM | #48 | |
Rep 642
Thanks for this input. So you think i'll be ok? There is no "pass or free retest" option anymore in California. I also saw an option in winkfp to check a box that says "force program programming in comfort mode" will that do the trick if I check that box prior to batch flashing? |
11-09-2021, 03:03 PM | #49 |
Rep 7,215
no, that won't do anything.
Honestly I can't say for sure. If you go into INPA, and read the current DME status - does it report the same software that you flashed? If so, I think you're good. But I don't know how the test is reading the software version. The plus side is, if you go and it passes without issue, we'll all know for sure what needs to be done to pass the CVN check. |
11-13-2021, 09:04 PM | #50 |
Rep 642
Stock program and stock tune works in expert mode via batch files.
CA smog at test only facility passed. Just reflashed to 330i tune and all good for 2 more years until next smog. |
mct128i74.50 IllSic_Design2124.00 bluewater328625.50 hassmaschine3972.50 The Nightman1090.00 CornerGorillaPit238.50 |
11-16-2021, 07:51 PM | #51 |
Rep 7,215
Awesome! I mean, you took a risk - but now we know for sure, they are not reading the UIF, the DME just reports the actual checksum stored in the calibration and program.
Next would be just making it so the checksum always matched the program version string. That's something I've wanted to do for ages, I just haven't had time to mess with it. |
11-17-2021, 10:04 AM | #52 | |
996
Rep 2,287
Hassmachine, check this out, maybe this will help. Reverse CRC checksum creation |
hassmaschine3972.50 CornerGorillaPit238.50 |
11-17-2021, 10:33 AM | #53 | |
Rep 642
Yeah I definitely took a risk. Maybe 2 and almost 3 risks if it didn't go right. I said more risks because it actually failed the first time due to the parts of the OBD being "not ready" which was the o2 and catalyst. I needed more time driving the car to get those systems ready for smog, which was strange because it's my wife's daily and she drove it for 3 days (but it kind of makes sense because she only drove to work and back and each day was like 5 miles of street driving). The last thing I wanted to do was to retake the test again after all OBD systems were ready and it failed due to the program/tune. They're super thorough here because I swear that smog tech took a good while doing the visual check going into every nook and cranny with a flashlight and several mirrors. He even spent like 10 minutes looking for stickers under my hood and asked me about them, but I told them it was a painted aftermarket carbon fiber hood and he gave me shit about that too. Either way, I passed the visual and the OBD test. My program/tune was the stock one off of bimmerlabs and I used expert mode. |
11-17-2021, 01:38 PM | #54 |
45
Rep 158
Drives: 2011 328i
Is the Bimmerworld Stage 2 a plug and play option (i.e. they send an entirely new DME ready to install)? Is there such a thing? If not, can you get a used DME, flash it to your car, and then flash it with a tune in order to be able to reinstall the OE DME to put everything back to stock? I'd like to be able to squeeze out a little more performance but not have to worry about not passing smog checks and Bimmerworld is the only one I can find that offers a tune specifically for the N51. I was hoping to find something here about that, but either I'm terrible at search or there's nothing that exactly fits what I'm looking for.
My latest E9x is a 2011 328i E93 SULEV (aka N51). |
11-19-2021, 01:04 PM | #56 | |
45
Rep 158
Drives: 2011 328i
I guess what I'm really trying to figure out is the quickest/easiest way to have a mild tune for weekend track sessions that's fully reversible for on-street daily driving. Is this something I should I make an entirely new thread to ask for advice on, or is there somewhere it's already been beaten to death that my awful search skills are unable to find? Thanks again in advance! |
05-06-2022, 09:48 PM | #57 | |
Rep 38
Have you done the bimmerlabs 330i tune yourself? I have all the software from them and tried to flash my old car but something went wrong and I almost bricked my dme. Had to sell it to a guy that knew how to fix it. The shop wanted 2k to fix so I decided to just sell it. I use the bimmerlabs tools like inpa and ncs winkfp etc and I have ista + so im kinda familiar with diag but coding i still don’t know wtf im doing. Im scared of messing something up again. I thought I followed every step precisely but either my charger wasn’t strong enough, or I didn’t have everything set up right. Looking to do this to my new car, or just get a turner ms tune. |
05-07-2022, 12:35 PM | #58 |
Rep 7,215
I made it, so, yes.
most likely it was a cable issue. In the last few years, it seems like most of the cables are not any good (even from reputable brands). I have several cables and like 4 of them don't work for flashing - some of them used to work fine, but stopped randomly. Your DME wasn't really bricked, but was in safe mode - it would still be possible to re-flash it but not without fixing the root cause of the issue. |
ptpending460.50 |
05-27-2022, 06:01 PM | #59 |
Rep 64
Just to add: I flashed stock 330i program, drove around for a few days and passed CA smog test today. Flashed with WinKFP in Expert mode (batch) with 330i stock program downloaded from Bimmerlabs. I had to flash a few times as I kept getting failure errors even with BimmerGeeks cable. Note, connect a battery charger to car as flash took 20-30 minutes. I plan to re-flash to Bimmerlabs custom tune.
2006 330i with Bimmerlabs custom tune for 3SIM, noMAF and MILVS |
08-03-2023, 01:42 AM | #60 |
82
Rep 154
So is stock 330i tune from bimmerlabs passing California smog tests?
08-12-2023, 12:37 AM | #61 | |
Rep 42
If you were to tell me California actually GETS IT and doesn't penalize people running a FACTORY STOCK OFFICIAL BMW 330i "tune" on an N52 engine was designed for it would be the first props I'd give the state since the mid-90's when the state started going downhill. Finally some common sense in Sacramento |
08-12-2023, 09:10 AM | #62 | |
996
Rep 2,287
Even though the tune is 99.999999% BMW, the one byte changed in the calibration file requires a different CRC32 checksum for the processor to run. CRC32 It's an internal data validation/memory failure check. Unfortunately that CRC32 bit checksum is the CVN number. If they check, it will appear as a modified program. The Bimmerlabs tools do not conceal the modified tune. Pretty sure it can be done but probably very illegal to distribute. Expect jail time. |
AmuroRay2303.00 |
03-03-2024, 05:07 AM | #63 | |
9
Rep 8
Drives: BMW 328i E92
03-03-2024, 06:40 PM | #64 |
201
Rep 161
04-02-2024, 12:19 AM | #65 |
Rep 11
04-06-2024, 08:03 PM | #66 |
Rep 2
Hi all. I've been looking at this thread as I did the 3SIM mod on my Z4 3.0i N52 to make it have the same power as the 3.0si N52 (same as 328i -> 330i mod just for the Z4) and was also scared about smog testing. I used the oem 3.0si file from Bimmerlabs and passed smog today. Did not have to revert back to the factory 3.0i tune.
