BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > BMW F30 and Bimmercode
Studio RSR
      03-31-2024, 12:03 PM   #1
83ndy
Drives: BMW F30
Hi everyone,
Last year I have used Bimmercode to activate the mirrors to close automatically when I lock the car.
The issue is that now I don’t want this anymore, and I have lost the backup of the coding.
I dont have the option anymore to disable it from BimmerCode.
Any ideas on how I can disable this again?
I have the App purchased and i’m using iOS device
Thanks!
      03-31-2024, 12:45 PM   #2
GreenF30N26
GreenF30N26's Avatar
153
Drives: F30 328ix N26
Google has almost everything. Or use the search function here.....
https://f30.bimmerpost.com/forums/sh....php?t=1844177
      03-31-2024, 03:08 PM   #3
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Anything you code with Bimmercode can be reversed, there's no need to use backup.
      03-31-2024, 03:44 PM   #4
83ndy
Drives: BMW F30
@GreenF30N26
Thank you my friend. I've searched on Google, I posted even on local groups to find a solution but no-one was able to help me.
@Billfitz
I had only the option "Active" without anything else, but now it's solved.
Billfitz8295.00
      04-03-2024, 07:00 PM   #5
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
Ditto…I was lost about needing a backup to revert. If you pull up the list of supported coding for the f30 ( https://bimmercode.app/cars/f30/ )…then scroll down to MIRRORS…you can see that there are two coding parameters…one for convenience close and one for auto close.
The one has two coding parameters and the other only has one. IF you coded the convenience close for ACTIVE…and you don’t want that anymore…simply recode and select NOT ACTIVE.
But it appears from the post above that the OP figured it out enough to be satisfied.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      04-04-2024, 01:56 PM   #6
Billfitz
Billfitz's Avatar
There are cases where Bimmercode doesn't show the option for active or not active, just active. But if it's checked active and you click on that the check will go away, and that makes it inactive.
      04-05-2024, 08:47 AM   #7
Qsilver7
Qsilver7's Avatar
excellent follow up and explanation for the singular coding parameter
      04-21-2024, 03:13 PM   #8
TomFord514
TomFord514's Avatar
Drives: 2018 Bmw 330i xdrive M Package
Hello Everyone apparently you need to update kombi and I-level to get the proper logos on BimmerCode. When adding the M performance, I get the M550d instead.Are you able to walk me through it and explain for me how to do it and what I need please? Look forward to hearing back. Thanks. 2018 Bmw 330i xdrive F30
