KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
01-18-2018, 04:40 PM | #67 | |
Rep 3,997
There is more than one way to skin a cat, I wouldn’t say there is only 1 way to setup any given car. |
10-02-2018, 06:40 PM | #69 |
Form follows Function
Rep 43
10-03-2018, 07:17 AM | #71 |
F15 daddymobile
2356
Rep 3,531
Because people use the search function, like they should
10-04-2018, 06:38 AM | #72 |
Rep 1,216
OEM zcp
2011.5 E90 M3
LeMans Blue |
11-10-2018, 07:57 AM | #73 |
Rep 868
Reading conflicting stories in this thread on kw sleeve kit and it hitting perch in front on a 19 x 10 et. 20 but this was a case where no rubbing anywhere with this wheel setup and suspension in front without spacer, only in rear I believe
11-10-2018, 07:58 AM | #74 | |
Rep 868
11-10-2018, 06:21 PM | #75 |
Save the manuals!
6035
Rep 6,754
No, widths and ETs are fixed mathematical measurements.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
11-10-2018, 06:43 PM | #76 |
Rep 868
Ok do you think because one member was an e90 while the other was a e92? E90 have more clearance overall? The e90 was running bbs ch square, 19 x 10, offset 20, 275/30/19 and didnt experience rubbing in kw sleeve over kit. I’m at a lost here from different experiences, unless someone here is off on there experiences with kw sleeve over kit and rubbing/clearance in front
11-10-2018, 07:52 PM | #77 | |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
11-11-2018, 06:17 PM | #78 | |
55
Rep 228
11-11-2018, 06:41 PM | #79 | ||
Rep 1,612
Again , all depends on tires! Every sidewall is different .. And before you do any of this, take the kw sleeve kit and put it directly in the trash . |
11-11-2018, 06:54 PM | #80 |
55
Rep 228
Thanks, I didn’t think it would be an issue. I bet I won’t be able to use the current 265/35 up front with them though. And why? They seemed like the better choice vs springs.
11-11-2018, 06:58 PM | #81 | |
Rep 1,612
This is all baby easy fitment man lol And take my world with a grain of salt I'm a bmw race car tech , and they are to worst possible option for lowering this platform BAR NONE Get yourself some swifts/b&g/or whatever Do not use that sleeve kit Just some advice is all |
11-11-2018, 07:20 PM | #82 | |
55
Rep 228
Lol I just hate how tall the 265/35 looks up front on the 10’s and figured they would easily rub the strut/collar when I lower it. I almost went with b&g’s but I liked the idea of the slight adjustablily and didn’t think you could go wrong with a kw product! Just hoping these will hold me over until I get some ohlins or something along those lines. I’m always up for any advice though, appreciate it lol. |
11-12-2018, 04:52 AM | #83 |
Rep 1,216
I have 265/35/19 PSS up front and have the smallest amount of rub in zcp suspension. Only time it rubs is sharp turns with one tire off camber. From what I've read, you can run these on lowering springs with some camber but you'll still get some rubbing on inner fender liner in sharp turns
2011.5 E90 M3
LeMans Blue |
11-12-2018, 09:06 PM | #84 | |
55
Rep 228
11-12-2018, 09:20 PM | #85 |
Save the manuals!
6035
Rep 6,754
Switch to the 275/30 and do it right. 265/35 up front just isn't right. It's much taller than stock, limits fitment, rubs, looks bubbly, etc.
Scharbag2644.50 |
11-13-2018, 05:20 AM | #86 | |||
Rep 1,216
I didn't buy a ZCP car to ultimately change the suspension. I chose a 265/35 cause I wanted the best ride while filling the wheel gap. I get compliments all the time with how it sits. Every one has their opinion on looks so that'll be up to each person. It's like saying the only reason to go with a square wheel set up is to have the ability to rotate tires. It's certainly one of the main reasons but not the only reason.
2011.5 E90 M3
LeMans Blue |
02-27-2020, 08:03 PM | #87 | |
244
Rep 392
(With that said, the 19x10" ET25 up front will clear stock suspension with lowering springs, as well as many aftermarket coilovers.) ** I am currently lowered on B&G S2 Springs (E92 M3 with EDC, not competition pack.) So with the above being said, I should be able to run 19x10" ET25 squared without rubbing - but what tires could I run? Generally speaking.. I know different brand tires will have slightly different size variation in the same specs, but what are some tire sizes I would be safe going with? |
02-27-2020, 10:30 PM | #88 | |
coupe la goon
373
Rep 1,644
Drives: green, black, white
Garage List 2011 BMW 1M Coupe [10.00]
2013 BMW M3 Coupe [10.00] 2010 BMW 535i xDriv ... [0.00] 2008 BMW M3 Coupe ( ... [0.00] |
I would be encouraging of 275/30/19 sizing to avoid rubbing at steering lock. On 10" width I have run 265/30 (PSC2, too short) and 275/30 (PS4S, slightly short.) IMO 275/30 is better fitting on 9.5" width. |
