Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Europe (Continental) > Carly BMW E90 320d fault codes report
      05-31-2020, 02:33 PM   #1
E90isbest
Drives: E90 320d
Hey all!
I got this kind of report from Carly about faultcodes. These are after about 3 months of driving. I could burn DPF with the software driving 80km/h.
What of these faults are serious and should be fixed ASAP? And which of the fault codes I should not focus that much. My plan is to fix everything during the summer.
Thx for the answers!
BMW E90 M47 320D 2005/5 - 350000km
Engine:
Fault code: 004CF3 – Exhaust hack pressure sensor, signal
Fault code: 00483D – Throttle
Fault code: 004166 – Particulate filter system
Fault code: 003EED – Power management quiescent current (layer PMRUHVERL)
iDrive CCC:
Fault code: 00E18F – Central registry does not match the target configuration (error registry new)
Junction Box Passenger Module:
Fault code: 00A6CF – Auc Sensor
Fault code: 00A6D1 – Additional water pump
Foot Well module:
Fault code: 009CB4 – Unfortunately, no error text available / sensor height level, rear defective
Fault code: 009CBB – Short circuit fault 2
Fault code: 009CBC – Short circuit fault 1 / Short or open door contacts the front
Fault code: 009CD2 – Compare VIN ALC different with SMC right / Drive folded in mirror driver side defect
Fault code: 009CD3 – Drive folded in mirror passenger side defective / Unkonsistenz: software version and codierindex
Anti Theft Alarm System:
Fault code: 009D12 – Error battery circle
Central Info Display:
Fault code: 00A468 – No LVDS signal / Errors in the video signal / Cable break externally / Energy-saving mode active
      07-18-2020, 05:52 AM   #2
nplasko
nplasko's Avatar
Drives: BMW 320d Touring E91 2009 A
Did you got some help on this?
I am in Finland too and just bought 2009 320d E91 (Germany - imported to finland).. I was thinking that I may get some help for any future faults.
Driving BMW 320d 2009 E91 Touring (Germany)
iDRIVE with no Bluetooth / no USB
      12-10-2020, 10:53 AM   #3
E90isbest
Drives: E90 320d
As you see. There is not that many answers.
Good luck with your BMW. I found Carly pretty good to dig these out but unfortunately it is really hard to get any support from forums with these codes...
BR,
E90isthebest
      11-03-2021, 02:54 AM   #4
allex29
13
Drives: BMW E91 M47
most urgent are the ones regarding the particulate filter, if you don't mind spending a couple of thousands for a new one
