      09-01-2020, 09:49 PM   #1
1st2nd8th
1st2nd8th's Avatar
Drives: bmw 128i
128i to 130i GM transmission flash.
So I flashed my DME 128i to 130i from Bimmerlabs the other day and it went well but I kept looking for the 130i GM trans flash for our car but couldn't find it. We only have the stock tune at their website. Do we have the 130i gm trans tune for our car? If we have, what's the batch file for it?
3 series on the other hand has 330i GM trans ZB # 7587776 on Winkfp. Since our car has the same engine, can we use the same tune?
If you want the 130i tune follow this guy's step by step only he has the 330i tune but pretty similar to our 130i.
      09-04-2020, 05:08 PM   #2
519.E82
519.E82's Avatar
245
Drives: BMW 128i Sport (Non M)
I dont think so? The only reason we have the 130 tune is to take advantage of the 3 stage IM, nothing of the trans is changed.
2008 SGM 128i - 3 Stage IM - 130i Tune - Dinan Camber Plates - BMW PE - Injen Intake - 1M Mirrors - LCI Blacklines - M4 Spoiler - Blacked 263's - Aero Bumper - Aero Side Skirts - OMGSplitter - AFE Intake Scoops
      09-12-2020, 07:41 PM   #3
E92William
Drives: 2008 E92 328xi
2008 BMW 328xi  [0.00]
Hey. I was the guy to make that video. To get to the gm transmission file you have to switch your ecu on your profile in bimmerlabs from msv80 or whatever it is to gm1912. It should show as a file from an e83 x3 3.0si and flash as a tune, no need for rsa delete again
      09-27-2020, 06:59 PM   #4
1st2nd8th
1st2nd8th's Avatar
Drives: bmw 128i
I did that but it fails to program it. at the end of programmimg, it gave me errors. at bimmerlabs project, under GM1912 there are two stock tunes available, both of them failed to program my car.
      09-27-2020, 07:09 PM   #5
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
What cable are you using?
      09-27-2020, 10:39 PM   #6
1st2nd8th
1st2nd8th's Avatar
Drives: bmw 128i
bimmertech pro cable. i also have icom but it's easier to use bimmertech. is this because I have a paddle shifters that's why it won't work? check bimmerlabs website for their GM1912 update. hopefully, they sort this out.
      09-28-2020, 07:14 AM   #7
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
I'm 99.9% sure those transmission files are original BMW files. Bimmerlabs uses batch files to run BMW software. If you have a flashing problem it's probably at your end.
Did you check your connections with INPA prior to flashing? I'm several years into this game and I always check the module for errors as a general Com check before I flash.
Windows updates likes to screw with your setting and I've even had a problem with my Bimmergeaks cable. The plug inside the case came loose and I had intermittent connections. Easy fix but if I had tried to flash the DME is would have failed.
      09-28-2020, 11:44 PM   #8
1st2nd8th
1st2nd8th's Avatar
Drives: bmw 128i
I checked INPA and they're both black
I've programmed my cic, combox, amp, and many other things into my car so it's impossible that these "stock tunes" for the trans of my car aren't programmable. i tried both batch file. so what gives? or maybe I'm doing something wrong or missed a step... i get errors at the end of the program.
note: i just programmed my DME earlier with the 130i tune with the batch file. no error.
[IMG]undefined[/IMG][IMG]undefined[/IMG]
      09-29-2020, 05:43 AM   #9
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
What were the error messages?
Do you have a screen shot of your transmission Ident page?
      09-29-2020, 08:52 PM   #10
1st2nd8th
1st2nd8th's Avatar
Drives: bmw 128i
I don't but everytime it reaches 100% it gives me errors.
      10-27-2020, 04:22 AM   #11
Nixis
13
Drives: 2011 E90 M3
Is the trans tune necessary? Does it actually improve shifts?
      10-27-2020, 11:18 AM   #12
E92William
Yes, it makes the shifts a bit stiffer and faster specially in manual mode. DS becomes more usable and the shift points are in line with the added power of the 3 stage manifold
      12-29-2020, 06:47 AM   #13
NE_P8riots
NE_P8riots's Avatar
Australia
Drives: 2011 125i Coupe
For the 125i Coupe does it still work? I’m Stuck with a detuned 3.0 engine with a 6spd auto box that wont downshift into 1st early enough (2500rpm max from 2nd) terrible on corners. Plus the shifting speed is terribly slow. 🤦*♂️
2011 BMW E82 LCI 125i Alpine white, M sport, BMW Performance Exhaust, H8 angel eyes, Blackline Taillights, Carbon Lip, Carbon Diffuser. 19” 666m replicas. Pirelli 225/35/19 245/30/19
Sold: 2005 BMW E87 118i
      12-29-2020, 01:48 PM   #14
E92William
Well you have a detuned 3.0 at least that's a good thing that you don't have the b25! Go under the car and check if your transmission has a metal pan if it does then you can flash it. Gotta check on the bimmerlabs website if it's available for you but I'm sure it would help a lot, I love how much better my xi shifts.
      10-20-2021, 01:45 PM   #15
Giberish33
Drives: 128i M Pack
Does anyone have news on the trans flash availability. Its been over 1 year since the last news on bimmerlabs website. I have tried emailing them to see if there has been progress / if I can help make progress in anyway, but no reply back.
      10-20-2021, 02:06 PM   #16
golfer23rm
golfer23rm's Avatar
South Africa
45
Drives: 2010 BMW 125i E82 Bluewater
can you load the files to sharing site for the rest of us please?
thanks.
"Life moves pretty fast. If you don't stop and look around once in a while, you could miss it...."
Ferris Bueller
      10-24-2021, 05:16 PM   #17
RaddDroid7
RaddDroid7's Avatar
14
Drives: 2018 M240i
Very interesting, I'm curious if this would work with the N51 since it already has a 3IM ? Stuck between this and Stage FP now
      10-25-2021, 01:18 PM   #18
golfer23rm
golfer23rm's Avatar
South Africa
45
thanks.
changed my profile on bimmerlabs and still shows 0 downloads for gearbox.
Ferris Bueller
      11-18-2021, 05:47 AM   #19
golfer23rm
golfer23rm's Avatar
South Africa
45
someone please send me the file....
Ferris Bueller
      01-02-2022, 03:47 PM   #20
mike5124
mike5124's Avatar
Drives: 2006 BMW 325i (E90)
2006 BMW 325i  [0.00]
Just flash the ZB shown in the first post in WinKFP. Works on most cars pre-2009 from what I've seen.
      01-22-2022, 11:44 AM   #21
aznbo187
Drives: E46 M3, 128, E91 328, E70 X5d
Also would be interested in achieving a bit more aggressive transmission shifts with post 09 GM trans. Especially off throttle downshifts!
      03-22-2022, 03:22 AM   #22
golfer23rm
golfer23rm's Avatar
South Africa
45
i have done the bimmerlabs 130i tune. but is that not only for the engine and not the gearbox?
Ferris Bueller
