What did you do to your car today?
05-02-2024, 06:40 PM | #24399 |
Rep 1,184
Washed it! And figured out the A/C situation. Turns out the best way to get cold A/C even in stop and go traffic on a 90ºF day is to use Auto (which I always use), at the max intensity (bar to the far right, previously had it in the middle). I was used to the old IHKA setup (2006-09) where there were only 3 auto programs. The newer one has 5 and that confused me.
More airflow through the evaporator = cooler air. However, this does have me thinking. If I swapped in the 800W 335d/335is fan, would that improve airflow in traffic at all and give better A/C performance? My car has the PPK on it from the factory, but it’s not the PPK2, so as I understand it I still have the 650W fan. |
05-02-2024, 06:54 PM | #24400 |
202
Rep 151
On the 2011 xDrive @ 70k miles
-New front strut assemblies (including springs, mounts, hardware) - OE/Genuine -New Trans Filter & Fluid Major improvement with new front assemblies. The intermittent front end knock when turning, vibration at highway speeds and poor handling on bad roads are gone. Pleasantly surprised at the huge improvement given none of the struts seemed to be leaking. Also wondering what BMW changed mid-production after 03/2010 on the xDrive models since the struts and upper mounts have new part numbers after that date. Trans was shifting well, but wanted to get ahead of changing the fluid given age and it was the last fluid I had to change on the car to get it back on a schedule. Shifting smoother and feels great! Now onto the next thing on the list... |
Onizukachan1128.50 mattanderson209.50 |
05-03-2024, 09:18 PM | #24402 |
Rep 1,601
I did not run often the E91 N54, I did maybe 80km since the swap, and tonight I got my 1st guy reaching me fast on the street saying '' man, did you swap this wagon N54 ??!!!''
I said yeah, tf you know your engines ! ''dude sick car, sick sound man !'' a well educated fellow. My 328 look stock, I still even had the 328xi badge and stock wheels. this is gold for a car guy |
colorado.e9x3109.00 StradaRedlands5004.50 Seattlesquash912.50 zhent70.50 Runnin'Rich99.00 johnnyorange58.50 |
05-04-2024, 05:23 AM | #24403 |
17
Rep 13
Decided to do the evaporator myself, since the mechanic said he wouldn't have time in the next 2-3 weeks..
Wasn't as hard as I thought it would be. The most time consuming part was when the new evap came and I saw that the pipe bends were pretty far off from original. Had to be careful while bending them so that welds don't crack. All in all DIY-able, 6/10 in difficulty. Timewise probably around 9h, but I split it in two days 4-5h each. Would recommend anyone who is thinking about doing it themselves! Great way to better know your car. Oh yeah, managed to break off the head of the bleeding screw and nothing is working for the next few days so i had to DIY that too... |
StradaRedlands5004.50 Onizukachan1128.50 Runnin'Rich99.00 Nando_e90111.00 Seattlesquash912.50 BRG_N54310.00 DBShiznit145.00 |
05-04-2024, 08:40 AM | #24404 |
Rep 1,184
[QUOTE=Boksa;31124733]Decided to do the evaporator myself, since the mechanic said he wouldn't have time in the next 2-3 weeks..
Wasn't as hard as I thought it would be. The most time consuming part was when the new evap came and I saw that the pipe bends were pretty far off from original. Had to be careful while bending them so that welds don't crack. All in all DIY-able, 6/10 in difficulty. Timewise probably around 9h, but I split it in two days 4-5h each. Would recommend anyone who is thinking about doing it themselves! Great way to better know your car. Oh yeah, managed to break off the head of the bleeding screw and nothing is working for the next few days so i had to DIY that too... Nice! What were your symptoms? I’m assuming you went with an aftermarket evap, what brand? The N52 528i decided to leak out a good 2 liters of coolant. Yet I can’t find the leak. I think I’ll need to take it to have it pressure tested somewhere… No dried residue anywhere that I can se. |
StradaRedlands5004.50 |
05-04-2024, 09:59 AM | #24405 |
Rep 33
05-04-2024, 10:01 AM | #24406 |
Rep 33
Bonnet and boot struts
40 euro on Amazon for a set it was dumb simple, just take a flathead screwdriver to the back of the clips to release the struts.
No more bucket holding my bonnet open for oil checks 😅 |
05-04-2024, 01:46 PM | #24407 |
71
Rep 22
Today I swapped out the stock halogen headlightts for a set of LED projetors from BayOptiks.com
Since the lenses on the stock ones were cloudy and had been polished at least once already they needed to be replaced, and this is a total upgrade. Looks mostly stock, but now I have nice bright DRLs! With this I think I'm done with changes for a while, now back to our regularly scheduled maintenance... |
Onizukachan1128.50 colorado.e9x3109.00 StradaRedlands5004.50 Seattlesquash912.50 cehrl7827.00 johnnyorange58.50 |
05-04-2024, 05:23 PM | #24408 | |
111
Rep 244
Could you expand on what you said about bending the pipes? Do one needs to have any special A/C tool to put the new evap in place or is it a "plug and play" procedure? I thought it was the latter. |
05-04-2024, 09:56 PM | #24409 |
eBay Special
3109
Rep 3,039
Drives: E90 330xi
Slow progress on the 330
Common sense is a flower that does not bloom in everyone's garden
05-05-2024, 09:03 PM | #24410 |
eBay Special
3109
Rep 3,039
Drives: E90 330xi
328 got exhaust tips. Exact same specs as BMW PE. Much cheaper, and I get to keep my quiet cabin
Only problem is now they stick out like a sore thumb. Thinking polished lug nuts and dual slats with chrome surround to break it up. Undecided. Thoughts? Also added the old M3 style mirror caps from the 330. I think I might like the OEM ones more. If the M3 ones were paint matched though..
05-06-2024, 12:57 AM | #24411 |
Great Teacher
1129
Rep 1,315
Drives: 06 e91 325ix
Took it out to our NM BMWCCA First Sunday brunch,met a guy with a gorgeous LCI e91 blue water metallic and fox red interior, only down side was it was auto or I’d be jelly.
I’ll be helping him do a match amp and doing some DSP tuning, guy also has a r53 so really good taste.
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
05-06-2024, 03:34 AM | #24412 | |
17
Rep 13
[QUOTE=Hoody007;31124977]
The evap was some cheap polish brand. And to answer Nando_e90 question, mostly did it using my hands and some wood pieces. It should be plug and play if you don't cheap out like I did! If you are gonna do it, just buy some ziplock bags and a marker, label everything and watch some videos about it on Youtube. Good luck guys! |
Nando_e90111.00 |
05-06-2024, 05:13 AM | #24413 |
323
Rep 230
New Oil level sensor, Service, front discs and pads, summer wheels on, 4-wheel hunter alignment, Non-iDrive to CiC retrofit with 2024 Maps update + Bluetooth connectivity.
05-06-2024, 12:47 PM | #24414 |
Great Teacher
1129
Rep 1,315
Nando_e90111.00 johnnyorange58.50 |
05-08-2024, 08:49 AM | #24415 |
157
Rep 183
Drives: E90 LCI 320d SE
A quick oil and filter change, replaced with 5 litres of Castrol and can of Ceratec, and a quick wash. Seems slightly quieter, but that might just be my imagination. I suppose only time will tell.
05-08-2024, 08:44 PM | #24416 |
Rep 1,184
Ordered a Mr12Volt CarPlay unit. So excited!
Now on to backup cameras… any particular model someone here has used in the past? |
05-08-2024, 08:49 PM | #24417 |
Rep 760
Drives: E92 CT200h Cayman Boxster RC
Widebody kit should be here on my birthday
Also started to take apart a few small things to be color matched. Stoked on the headlight mods. upload images
Long Beach Blue E92 with Carbon Fiber Roof
Build Thread |
05-08-2024, 09:18 PM | #24418 | |
eBay Special
3109
Rep 3,039
Drives: E90 330xi
On things I did today: Successfully coded flashing break force display on the 328. I never got it to work on my 330. Now that I know how to, I'll be trying it again
05-08-2024, 09:22 PM | #24419 |
Rep 760
I’ve had one of those handles for years. It doesn’t plug into anything though haha.
Build Thread |
colorado.e9x3109.00 StradaRedlands5004.50 |
05-08-2024, 09:40 PM | #24420 |
210
Rep 169
I'm curious, what are your main use cases?
I'm about to try retrofitting the Combox in my non-iDrive car, simply to get good a good iPhone -> USB music connection, but I'm not yet convinced that I shouldn't have pursued an aftermarket solution. Everyone has a different use case/priority, though. |
