BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > HID fog lights easy as pie and a cost of only $60.95
      01-06-2010, 01:54 PM   #23
DMA
DMA's Avatar
Drives: 16 F80 M3~09 E92M3~03 E46M3
Cool man! People tend to hate on ingenuity which is the first step in many of the lighting mods available now. Great post!
Now if you could do something like this to make HID angel eyes work for that price!
IG:@DMAGARAGE - 2003 E46 M3 | 2009 E92 M3 | 2016 F80 M3
      01-06-2010, 02:01 PM   #24
335iredline
14
Drives: BMW 335i E90
As a matter of fact I am working on that as we speak. Unfortunatley the capacitor trick does not work for the angels I have found out but I have 2 other wiring schemes I am devising and will surely let everyone know of the outcome!!
      01-06-2010, 02:01 PM   #25
Tee212
Drives: yes
2010 335  [8.00]
Originally Posted by arianacaparelli View Post
your rims are gorgeous
Really? it looks like dark space covered with brake dust?
      01-06-2010, 02:08 PM   #26
iAerodynamic
iAerodynamic's Avatar
Taiwan
116
Drives: 325i
2006 325i  [0.00]
what did you use to hide the capacitor? i would assume it would get wet or something?
      01-06-2010, 02:11 PM   #27
335iredline
14
Capacitor is ok in the elements. I covered soldering and leads off cap with heat shrink.
      01-06-2010, 02:18 PM   #28
E92-Lighting
E92-Lighting's Avatar
Drives: Next Generation LED Lighting
looks hot, great shots
      01-06-2010, 02:29 PM   #29
335iredline
14
And thanks to you for the awesome angel setup!!
      01-06-2010, 02:33 PM   #30
jpsum
jpsum's Avatar
Drives: 2010 TSX
sorry that I have to ask. What is the purpose of the capacitor? Is it to prevent it from throwing an error code? I thought people always use resistors for that.
      01-06-2010, 02:45 PM   #31
azwillnj
318
Drives: 2023 M340i xDrive
I wonder if you could apply this mod to the rear fogs? I would love to be able to blind people that tailgate me.
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive
WE ARE!
      01-06-2010, 02:52 PM   #32
335iredline
14
Capacitor stores excess power and distributes as needed from the source requesting it. Issue with BMW when switching to HID's is the HID bulb requires much less power to light than a typical halogen bulb. With less power needed our computer detects that it is consuming less than normal power and it throws an error code and also sends pulses repeatedly to ensure it is accurate as being bulb out situation (hence the flickering members speak of). Well when you add a capacitor it stores the excess power tricking the computer into thinking it is a normal situation and sends only amount needed for HID ballast to function in turn eliminating the error and pulse situation
I have no idea. Im pretty sure this is why US spec cars did not get this option lol
      01-06-2010, 02:54 PM   #33
OwnAge
Gourik
OwnAge's Avatar
187
Drives: soon
2009 328i  [8.90]
Looks amazing, i just got my 3k kit this morning cant wait to install it. I wanted to add yellow rings but i think ill go the same way you did. White rings yellow fogs.
Good job with the hids.
      01-06-2010, 03:47 PM   #34
jpsum
jpsum's Avatar
Drives: 2010 TSX
Thanks for the explaination. One more question, shouldn't the capacitor be installed upstream of the ballast? Also, capacitors have resistence only when it is being charged, so if you turn the fog on, off then on again quickly, would that trigger an error code since the capacitor would have no time to discharge and therefore, has no resistence when you turn it on the second time around?
      01-06-2010, 03:50 PM   #35
335iredline
14
Yes your are correct and it is. The harness the capacitor is integrated with plugs into the factory fog lamp plug.
      01-06-2010, 03:53 PM   #36
jpsum
jpsum's Avatar
Drives: 2010 TSX
just added something to my previous post. sorry.
      01-06-2010, 03:59 PM   #37
335iredline
14
Not sure. In theory you are probably correct but I dont think it is regular practice for people to toggle lights on and off as you are explaining. But also if doing quickly as explained the capacitor will retain a bit of the energy so im not sure but again highly doubtful this should even be a problem unless your trying to do a light show with your E9x
      01-06-2010, 04:00 PM   #38
cstmx_ryder
cstmx_ryder's Avatar
Drives: A metal box with a roundel
looking for some 3K HIDs as well, but for 9006 bulb setup because I have Mtech kit.
Are DDM Tuning or whatever the name is, the only ones that offer the HID in 55W? I believe the Mtec HID kit is 35W, and that's the one I've been looking at.
TIA
'08 AW E90 335i
PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10
      01-06-2010, 04:06 PM   #39
jpsum
jpsum's Avatar
Drives: 2010 TSX
hey, I'm not trying to be an ass... I like to talk about these things as I'm a geek like that.
Yea, I agree that shouldn't be a problem. But if it does, I think a resistor inline with the capacitor might just do it.
      01-06-2010, 04:09 PM   #40
335iredline
14
No I wasnt critisizing just making a joke. I play by the KISS (Keep It Simple Stupid) rule and the method is working for me. One isue with resistors and our cars is that sometime the polarity is reversed and when that happens resistors go KABOOM
      01-06-2010, 04:16 PM   #41
singhbmw23
PUNJABI KING
singhbmw23's Avatar
India
67
Drives: aw e90
Looks sick Ive always wanted yellow fogs.
      01-06-2010, 04:19 PM   #42
Craig@SupremePower
G.O.A.T.!
Craig@SupremePower's Avatar
Drives: '18 GMC Yukon XL
nice..
      01-06-2010, 05:42 PM   #43
nyc3r
nyc3r's Avatar
Drives: E90
do you have picture of the install? where did you mount them? don't they get hot?
anyone with MY06 tried this yet?
      01-06-2010, 05:56 PM   #44
Kensta335
Kensta335's Avatar
163
Drives: 335i Coupe
This looks great. Love those yellow fogs.
