04-14-2024, 08:58 PM | #1 |
Rep 11
Drives: BMW 335xi 2013 sedan msport
Drivetrain Malfunction No CEL or codes
Wondering if anybody has experienced this and could help me out. (F30 335xi Sedan N55) Was driving normally and then merging on the highway I accelerated fairly quickly and car threw a drivetrain malfunction. This error goes right away as soon and car is turned off and on and comes everytime I try to accelerate fast. If I drive normally not accelerating quickly the malfunction won’t appear but can feel low power as when i push on the accelerator it would go slower than usual. Just got my water pump, thermostat, and charge pipe replaced and not sure if any errors from the mechanic could cause this but any suggestions would help!
04-15-2024, 02:24 AM | #2 |
AH3 Owner
204
Rep 311
Drives: BMW 335i ActiveHybrid 3
No codes is impossible. If you're getting a drivetrain malfunction, you have codes. You're just not using a scanner to read BMW specific codes. Charge pipe would be my first guess since it was worked on.
Billfitz8262.00 |
04-16-2024, 12:29 PM | #3 |
20
Rep 41
Drives: f30 and f15
This happened to me before. Usually when this happens, it is either the spark plugs or the fuel injectors. Replace all the spark plugs and see if the problem goes away. If not, I would move on to the coil packs. If that doesn’t work, fuel injectors. My bet is spark plugs.
04-16-2024, 12:47 PM | #4 | |
AH3 Owner
204
Rep 311
Billfitz8262.00 samspiderman312545.50 |
04-16-2024, 01:08 PM | #5 | |
20
Rep 41
Drives: f30 and f15
Edit: I saw the charge pipe was replaced. Like NxTH said, it could be the charge pipe. Check to make sure that the charge pipe is properly secure. |
04-16-2024, 02:29 PM | #6 |
Rep 11
charge pipe seems to be secured and properly installed but haven’t gotten the error in the past few days regardless of if i drove aggressive or moderately so am waiting for that and will go get it scanned as soon as that error comes up. Haven’t replaced the spark plugs in a while so hoping that’s the error but again not 100% sure. thank you for the help so far
04-16-2024, 03:03 PM | #7 | |
AH3 Owner
204
Rep 311
04-16-2024, 03:11 PM | #8 |
Rep 11
saw this and went to mechanic, here right now, he scanned it and no codes at all says eveything is normal
