03-23-2024, 10:26 PM | #1 |
Rep 1,582
Any recommendations for LED brake lights? SOLVED
I lost my OEM halogen left brake light today after 11 years of dutiful performance
Any suggestions? I am not a $150/pair exotic bulbs kinda guy. I retrofit my halogens with LEDs for Daytime Driving and Low-Beam for under $25 a pair that work great, so LED brake bulbs in that range. I haven't visually confirmed yet, but I believe it's P21W (outer) for 2012 F30 328i.
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
03-24-2024, 11:29 AM | #2 |
Rep 16,094
I have these: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Make sure of what bulbs you have, the charts aren't always right. |
03-24-2024, 12:30 PM | #3 |
Rep 1,582
Thank you. I checked what bulb I need to buy, and didn’t say anything wrong with the filament. So I checked the connection and there was severe pitting. Cleaned it off with sandpaper and now it works. However, I need to prepare some replacement bulbs since they are 11 years old.
In the big excitement, I forgot to check the part number of the bulb. The two pegs are on the bottom and 180 degrees. So should be P21W
03-24-2024, 05:30 PM | #4 |
Rep 467
Over the years of use, the filament metal evaporates, some of it settles on inside surface of the glass bulb, the intensity of the buld lowers (bulb light becomes dimmer). Filament becomes more fragile and could let go at any moment. It is good to be prepared with replacement at hand or, at least, have the source lined up for purchase.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
03-24-2024, 06:18 PM | #5 | |
Rep 1,582
