TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > X5 Photo/Video/Audio Gallery
      10-09-2023, 01:49 PM   #331
argento
argento's Avatar
538
Drives: 2013 X5M
Thanks, really appreciate it. A LOT of members to lean on here, they’ve all really helped this thread.
      11-02-2023, 02:39 PM   #332
argento
argento's Avatar
538
Drives: 2013 X5M
New Pirellis for the rear…
JDAURIA725.00
      11-12-2023, 03:48 PM   #333
argento
argento's Avatar
538
Drives: 2013 X5M
Creaking Noise and Felt Tape...
This is not a fix-all, however I was able to remove SOME creaking from the trunk area. I noticed when I pressed down on the trunk plastic pockets I'd get major creaking noise in the area shown in the pic. I used felt tape and random foam I had laying around to remove the creaking on both sides. I also added some to the bottom of the d-pillar panels, however that location only had minor creaking. Note, my d-pillar panels are already lined with dynaliner foam so I only needed felt on the bottom...basically where you see plastic on plastic or body.
Name:  Noise Problem.png
Name:  Add Felt Tape.png
Name:  Add Felt Tape 2.png
Name:  Felt Complete.png
Name:  X5M Trunk.png
///SY33140.00
      12-02-2023, 09:44 AM   #334
argento
argento's Avatar
538
Drives: 2013 X5M
Upper Glovebox Trim Replacement
My upper glovebox trim, like all of them eventually, began to seperate. Not sure why, but always thought this was an arduous process to replace. I found the instructions on ISTA and was surpised at the ease of removal. I swapped in the leather version of trim and plan on trying to repair the one I removed and add it to my reversible parts bin.
BEFORE YOU START, take pictures and/or all around gap measurements of your current upper glovebox trim...which assumes it's never been removed or you like the look of the current gap situation. Once you loosen the bolts for the upper trim you'll see there is a lot tolerance for final placement.
Everything is done with the glovebox open, except when removing the upper trim...it's easier with the glovebox closed. I have to say, this trim piece is bolted down with SIX screws...which is just...WOW.
Name:  ISTA E70_Upper Glovebox Lid_1.PNG
Name:  ISTA E70_Upper Glovebox Lid_2.PNG
Name:  ISTA E70_Upper Glovebox Lid_3.PNG
Name:  Glovebox Delamination_IMG 9170.png
Name:  Glovebox Upper Trim 6 Bolts_IMG 9170.png
Name:  Glovebox Upper Trim Removed_IMG 9177.png
Name:  Glovebox Upper Trim Removed2_IMG 9181.png
Name:  Glovebox Upper Trim Installed_IMG 9185.png
      12-11-2023, 12:32 AM   #335
argento
argento's Avatar
538
Drives: 2013 X5M
Morning light in b&w. And some yearly leather maintenance on steering wheel using Leatherique and oxyclean on stitching.
XRatedM136.50
///SY33140.00
      12-23-2023, 04:24 PM   #336
argento
argento's Avatar
538
Drives: 2013 X5M
Interior/exterior/engine
///SY33140.00
JDAURIA725.00
      12-25-2023, 04:07 PM   #337
argento
argento's Avatar
538
Drives: 2013 X5M
When I cleaned the exterior glass, there were random stripes or striations that would appear until it completely dried. Kinda like permanent streaks. They would also show up on humid days. Not super obvious, as you can see in the previous post, my glass "looks" clean in dry conditions...but it isn't.
Under certain lighting you could clearly see the the stripes/grime (see before pix below). I thought maybe it was behind the interior tint, but found the same stripes on the rear windows that were factory tinted. So I obviously needed a bit more than the Sprayway glass cleaner...I started with windex (amonia), GTechnique water spot remover (vinegar), clay, and finally isopropyl alcohol...NOTHING WORKED. Suprisingly, not even a tiny bit of improvement.
So I had to go to the next level, which was polishing. But not so far as my earlier post on polishing out scratches from glass (Post #139, Pg.7). Instead I decided to try Griot's Garage Fine Glass Polish. The video in the link below tells you HOW to use it, VERY EASY with a dual action buffer or equivalent.
https://www.griotsgarage.com/fine-gl...ish-16-ounces/
This worked exceptionally and I spent about 5 minutes per window (3 crosshatch passes). Below are BEFORE/AFTER pix of my exterior glass polishing (left side windows). I used the 6" polishing pads, but in hindsight I would use the 3" pads for the side windows and 6" pads for the rear window and windshield. The polish wipes off clean from the window seals, however I will observe them over the weeks to see if any white residue appears (like AIO, but that's probably b/c it's acrylic based whereas griot's glass polish is water based). I plan to coat the windows Griot's Glass Sealant and add this to my maintenance routine.
[INSTALL UPDATE: 3" pads are the only way to go for the side windows. After application of the polish there is some white residue, but once cleaned it doesn’t reappear. I had to use a pick in sime cases to clean some of it. The Griot’s sealant is a bear, IMO. Part if it was the local humidity and temperature (60F, 70%). It states to apply, let dry and reapply second coat, wipe off. Given the alcohol base I thought the first coat would dry quickly (within 15-30m) and so it appeared. I applied a second coat and it started to bead a bit. Too much. I left it to dry about 12 hours and began wiping. Still not dry bc I was just moving it around. Washed my half dozen dedicated glass microfiber towels and over the next couple days wiped over and over, rewashed. Finally the excess was gone. I used super bright light to illuminate the glass and hunt for residue. Went over the glass with Sprayway which helped a lot. Also, you may want to clean the inside glass to avoid appearance of streaks on outside. It took longer to apply the sealant than polish all the glass. I wouldn’t do two coats next time and maybe wait until 80F+ weather, but we always have high humidity.]
[UPDATE 3FEB2024: The sealant works well in wet weather, even when driving around 45mph/72kmh. I haven't been annoyed by glair in day or night driving, which is a pleasant surprise. I guess 2 coats IS the way to go, just remove all the dried excess to enjoy it. Before polishing the windshield I drove an iX 5.0 loaner and the clarity of new glass stood out (secondarily, obviously, to all the technology). The polished glass rivals new glass and it's a welcome and tangible improvement., FWIW.]
FRONT LEFT GLASS:
BEFORE - YES, This is the cleanest I could get the glass pre-polish.
Name:  Front Left_Before_IMG_9310R.png
AFTER
Name:  Front Left_After_IMG_9311R.png
REAR LEFT GLASS:
BEFORE - This is the cleanest I could get the glass pre-polish.
Name:  Rear Left_Before_IMG_9317R.png
AFTER
Name:  Rear Left_After_IMG_9321R.png
///SY33140.00
XRatedM136.50
      12-26-2023, 12:21 AM   #338
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
Looks stunning as always
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
argento538.00
      12-26-2023, 04:40 PM   #339
XRatedM
XRatedM's Avatar
Drives: 11' X5M - 19' VW GTI
Fantastic! That glass looks clean!!
IG @E70_XRatedM | YT: E70M Garage
argento538.00
      01-13-2024, 03:22 PM   #340
argento
argento's Avatar
538
Drives: 2013 X5M
Nice lines BMW…
Appreciate 3
      02-03-2024, 12:04 PM   #341
argento
argento's Avatar
538
Drives: 2013 X5M
Updated this list so I can more easily find past posts.
My favorite mod to date is, by far, the F-Series Shift Knob retrofit. It makes the interior look significantly more modern. I actually made a second one for a forum member now driving with a ceramic F-Series M-display shift knob in Germany. I think it went well, he was very patient and I'm thankful becasue I learned a lot about how to recreate this mod. If there is some demand, I may one day offer to sell a few more...it's just a fun project and completely reversible back to the old aluminum E70 shift knob.
Post #31, Page 2 - 15mm Rear Spacers Installed on 21" OEM Wheels
Post #39, Page 2 - Start of Accident Documentation
Post #46, Page 3 & #99, Page 5 - Accident Lesson's Learned
Post #71, Page 4 - Dashcam Hardwire DIY
Post #100, Page 5 - F85 OEM Interior LED Light DIY
Post #109, Page 5 – Front Bumper Removal Notes & ISTA Instructions
Post #119, Page 6 - Aftermarket Kidney Grill Install Tips
Post #121, Page 6 - 10mm Front Spacers Installed on 21" OEM Wheels
Post #122, Page 6 - Polishing OEM Exhaust Tips
Post #133, Page 7 - Android Monitor PROS/CONS (one of many)
Post #135, Page 7 - Roof Rail Delete DIY
Post #137, Page 7 - LED Reverse Lights
Post #139, Page 7 - Windshield Deep Scratch Repair/DIY
Post #144, Page 7 - Android Monitor Questions/Answers from Vendor (4x4)
Post #149, Page 7 - 4x4 Android Monitor Installation Notes
Post #156, Page 8 - USB Cable Routing from Android Monitor to Armrest
Post #158, Page 8 - P3 Gauges - Vent Gauge - V2 DIY
Post #169, Page 8 - Tinting Headlights and Taillights, Part I
Post #178, Page 9 - Tinting Headlights and Taillights, Part II
Post #185, Page 9 - Comparing Carbon Fiber Vinyl Wraps
Post #195, Page 9 - Rear Bumper Removal/Install DIY
Post #197, Page 9 - Exterior Mirror Gloss Black Vinyl Wrap w/Template
Post #210, Page 10 - 4x4 Android Monitor Sound Quality, Updated 3Mar2023
Post #212, Page 10 - Windshield Drip Molding Removal/Install DIY
Post #217, Page 10 – OEM F85 Rear Rotor Installation
Post #218, Page 10 - Dinan Lowering Springs, Pre-DIY, Part I
Post #219, Page 10 - Bowers & Wilkins Speaker Frequency Analysis & Fabricated Crossovers & XO Response Analysis
Post #220, Page 10 - Dinan Lowering Springs, Checklist DIY, Part II
Post #231, Page 11 - Dinan Lowering Springs, FULL DIY, Part III
Post #232, Page 11 - Aftermarket Carbon Fiber Diffuser, Part I/IV - At first glance...
Post #234, Page 11 - Aftermarket Carbon Fiber Diffuser, Part II/IV - About the Vendor...
Post #237, Page 11 - Zurich Aftermarket X5 Warranty Details
Post #238, Page 11 - Aftermarket Carbon Fiber Diffuser, Part III/IV - Test Fit...
Post #240, Page 11 - Bowers & Wilkins Matched XO Installation (working…)
Post #241, Page 11 - Bimmergeeks ProTool Coding Parameters
Post #244, Page 12 - X5M Pic w/Dinan Lowering Springs on OEM 21's
Post #249, Page 12 - BMW Steering Wheel Stitching and Leather Cleaning
Post #254, Page 12 – Aftermarket Carbon Fiber Diffuser, Part IV – FINAL Installation
Post #255, Page 12 – Universal Steering Wheel Cover Installation (Honda Pilot)
Post #256, Page 12 – Sprint Booster V3 Installation (since removed)
Post #265, Page 13 – S6F1A B&W Subwoofer Installation
Post #274, Page 13 – F-Series ///M Shift Knob Retrofit DIY
Post #285, Page 13 – Ebay R-N-D versus OEM R-N-D display
Post #291, Page 14 – Rear Axle Air Spring (Airbag) Installation
Post #292, Page 14 – Final Dinan Spring Ride Height Measurements
Post #301, Page 14 – OEM Carbon Fiber Front Splitter Installation
Post #313, Page 15 – OEM Constant and ACC/Switched Power Access
Post #318, Page 15 – Final OEM Carbon Fiber Front Splitter Installation
Post #327, Page 15 – Final OEM Bowers & Wilkins 14-Speaker Retrofit
Post #328, Page 15 – DIY Oil Pressure Gauge Installation
Post #333, Page 16 – Creaking Noises and Felt Tape
Post #334, Page 16 – Upper Glovebox Trim Replacement
Post #337, Page 16 – Exterior Glass Polishing & Sealant
      02-10-2024, 09:51 AM   #342
argento
argento's Avatar
538
Drives: 2013 X5M
VINTAGE BMW FLASHBACK...
Been sitting on some old E36M3 parts in my attic and started to go through them. I stumbled across some 2013 pix of my 98E36M3 coupe that I sold in 2014 with about ~80k miles. I bought it with 17k miles in 2004. The previous owner did a eruo delivery and kept it in Belguim working for some time so it was euro dot spec'd to be compliant (headlights, taillights, class III alarm, etc.). I went enthusiast excessive and installed every OEM retrofit kit and rare OEM part I could get my hands on from bmw.
A couple notable items: GT2 Spoiler full kit, LTW splitters, OEM PDC, OEM Power Rear Vent Windows, OEM Nappa leather center console trim and glovebox, OEM Euro-Spec Steering Wheel (custom wrap), Custom nappa F&R door panels, OEM Headlight Aiming, Euro-Only 323ti M-Paket Gauge Cluster, OEM chrome door handles, and more. You'll also notice the Dinan Exhaust, TCK Coilover setup, and custom xenon euro headlights. Those are LM replica wheels, but I had the OEM LTW's as well. You'll notice on the GT2 wing there is a imprint on the right side for the oem certification sticker. I had it, but I never installed as I didn't want to degrade it. I passed it on to the new owner....yes...obsessive. I've calmed down since then (of course, budget has a lot to do with it)…
In hindsight (as always the case), I was crazy to let her go. Sadly, within a year of sale, the new owner reported that someone crossed four lanes of highway to make an exit and tookout the front end. Not sure what happened afterwards.
I hope you enjoy the pix:
Last one...engine bay at purchase:
Name:  2004 at Purchase IMG_1372-resized.png
///SY33140.00
XRatedM136.50
      02-10-2024, 11:43 AM   #343
0-60Motorsports
Bahrain
792
Oh wow she was stunning
Current Mods:
IG: @060Motorsports
argento538.00
      02-11-2024, 05:45 PM   #344
///SY33
140
Drives: 2013 X5M
Immaculate!!
argento538.00
      02-19-2024, 12:02 PM   #345
argento
argento's Avatar
538
Drives: 2013 X5M
DIY Spark Plugs & Ignition Coils
If you've already swapped spark plugs and ignition coils, there is no new information in this DIY.
DIY_E70X5M Spark Plugs-Coils_19Feb2024.pdf
This was my first time swapping these on the E70 so I created this DIY to remind me of the pitfalls and challenges on my next time around. This wasn't a difficult of a job with the right tools and now with the understanding of the characteristics of these spark plug threads.
My spark plugs were replaced at purchase (15k miles) and this is the 30k replacement (@44658 miles). I used OEM plugs and Turner Motorsport coils. I like to do everything OEM, but since I'll likely be changing these out in another 30k, I went with TMS. I suspect one or more of my OEM coils was faltering as I had a poor fuel consumption symptom and a very slight lag in second between 1k-2k rpm. The lag is gone, will monitor fuel consumption. Except for one coil significantly grey/white-tarnished at the tip, they all looked quite well. After install, it was nice to feel the crisp throttle response.
Ok, this post need pix:
      02-19-2024, 12:44 PM   #346
argento
argento's Avatar
538
Drives: 2013 X5M
Lubricating Engine Hood Latch Coil Springs
I have my hood open each time it's in the garage to facilitate cooling, especially in the summer. I noticed it getting a bit harder to pull. So I used Finishline (FI106) synthetic lubricant on the latch coil springs. You don't need a lot and this disperses as a foam then melts in place. I actually have it around for bikes, but does the trick here.
Pull handle is buttery smooth afterwards.
Name:  IMG_9733 (Medium).JPG
Name:  IMG_9737 (Medium).JPG
Name:  IMG_9741 (Medium).JPG
Name:  IMG_9742 (Medium).JPG
      02-19-2024, 01:37 PM   #347
argento
argento's Avatar
538
Drives: 2013 X5M
Turbo Cooling Hose Repair
Productive weekend. I had a small seepage in my Return Hose CYL 1-4 turbo cooling lines. Luckily at the very top. As you can see from below it was the small hose and both of the of feed line screws:
Name:  IMG_9384 (Medium).JPG
Name:  IMG_9387 (Medium).JPG
I had planned to have bmw replace both turbo cooling lines while doing an oil service last month, but it was a small fortune for such tiny leaks. I had the parts pre-ordered so I decided to just use the component hose from the whole return hose line (11-53-7-598-343, $58.85 at genuinebmwminiparts.com).
I had also orded and used:
Feed Line Screw (11-53-7-507-218, $5.24/ea)
Feed Line O-rings (11-53-7-593-308, $5.04/ea)
and various hose clamps, but needed the following for this small hose:
Return Line Hose Clamp, 21.3mm (11-15-1-726-339, $1.37/ea)
Hose Clamp, 15,3-18,5 (32-41-1-131-346, $2.65/ea)
Name:  Hose Clamps.png
I used the following clamping tool: Knipex, 8-3/4", P/N: 10 99 I220. I did not clamp it as tight as the others in the vicinty, but I will monitor. The tool allows me to clamp further, but I felt they were over-tight which is the reason the hose was leaking. It all came out well, but noticed after clamping I could have pushed the hose up against the feed line screw block. I have more clamps if it becomes an issue. Oh, I did need a heat gun to warm up the new hose for easier removal from the return line assembly. I noticed in the new turbo cooling lines that the feed line screw is no longer used.
Name:  IMG_9749 (Medium).JPG
      03-18-2024, 08:01 PM   #348
argento
argento's Avatar
538
Drives: 2013 X5M
Clean!
      04-01-2024, 02:30 PM   #349
Jables92
Jables92's Avatar
Drives: 2012 BMW X5 35D
2012 BMW X5 35D  [0.00]
Very clean!
argento538.00
xbimmers
