TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > X5 Photo/Video/Audio Gallery
      12-06-2018, 04:18 PM   #67
9vapors
Drives: CB X5M
Couple quick driveway pics... not a big deal for some, but it made such a huge difference to the look of the car for me.
Looks sleeker. Time for some springs and spacers.
Spacers will be here today... springs are on the short list...
Great. What sizes did you get. I got 12/20mm but I'm changing the fronts from 12-15mm after I installed the new Dunlop's.
I got 25/15... I think that should put them where I want em!
      12-06-2018, 05:21 PM   #68
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
Excellent.
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
      12-07-2018, 03:15 PM   #69
9vapors
Drives: CB X5M
Got the rears put on, these are 25mm H&R spacers. The fronts needed longer bolts and I didn't know it. I got them ordered, so in the meantime, it's pretty staggered, haha...
      12-07-2018, 04:36 PM   #70
boneca
boneca's Avatar
Drives: 2022 BMW X5
2013 BMW X5M  [10.00]
2011 BMW X5  [10.00]
just about right
9vapors651.50
      12-10-2018, 03:09 PM   #71
do_0b
55
Drives: 2010 X6 M
2010 BMW X6M  [0.00]
looks good....i got 15mm on the rear...i should go up to 25 lol
9vapors651.50
      12-10-2018, 04:24 PM   #72
9vapors
Drives: CB X5M
Yup, throw that 15 up front and grab some 25s for the rear!
      12-10-2018, 04:28 PM   #73
9vapors
Drives: CB X5M
Ordered the H&R 2" kit with the m5 bump stops for all 4 sides. 2" kit because I plan to run the stock wheels for awhile longer, so going that low on these will look right. Hopefully will tie everything together exterior wise.
Having an x pipe welded in the exhaust tomorrow! I'll post some pics and vid of how the exhaust sounds with the x pipe. Supposedly will help equalize the exhaust pulses and eliminate some of the raspiness and drone of the straight pipes. Said to sound more "exotic", but not sure how it will sound with the turbos. Fun week!
      12-10-2018, 10:30 PM   #74
0-60Motorsports
Bahrain
792
Sounds good. Hopefully the ride won't be as bad as everyone says it is on the 2" drop. Please give us a review.
Current Mods:
IG: @060Motorsports
9vapors651.50
      12-11-2018, 07:26 AM   #75
mirob
mirob's Avatar
Drives: M3CX
That would be awesome but won't work. Front and rear have different hub sizes. Just a heads up before he spends his money...
      12-11-2018, 08:24 AM   #76
boneca
boneca's Avatar
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
he can get H&R 25mm spacers/adapters what some of us using, this will solve that issue
      12-11-2018, 08:52 AM   #77
mirob
mirob's Avatar
Drives: M3CX
Adapters are meant to make your wheels fit, not your spacers.
An adapter between the hub and the wheel is a stretch safety-wise...an adapter between the hub and the spacer, and then the wheel on top? No thanks...
      12-11-2018, 09:03 AM   #78
boneca
boneca's Avatar
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
u missing the point! there is no difference between spacer and adapter!
the adapter will serve the same purpose as spacer plus if its a spacer/adapter it will let you modify the hub size so you can run regular wheel on smaller hub size.
The adapters start wilt 25mm up as you will need to bolt on adapter to the hub and then screw u bolts/studs in to the adapter!
      12-11-2018, 10:04 AM   #79
mirob
mirob's Avatar
Drives: M3CX
Right, but that's a whole different point and part altogether. Him fitting the wheels was never the issue. He already has the "regular" rear spacers, I was just making the point that they won't fit in the front, that's all.
The E70 X5 M has a 74.1 hub size in the front and a 72.5 hub size in the rear. He would have to buy both if he want's to run the 15mm/25mm setup. He can't just buy the rears and throw the ones he already has on the front. That's all I was saying. Ask me how I know...
9vapors651.50
      12-11-2018, 10:07 AM   #80
boneca
boneca's Avatar
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
got it and I trust u
mirob3034.50
      12-11-2018, 03:13 PM   #81
9vapors
Drives: CB X5M
Had the X-pipe put in line. Here are my thoughts:
It really changed the exhaust note... in an amazing way! The raspiness of the exhaust is gone and it sounds more like a 350Z car at lower RPMs, kind of a resonated sound, but sounds like a super car when you get on the gas. The turbo spool is just as prominent, but the note is more exotic and refined. The car sounds differently at idle as well. I'm finally happy with the way the X5M sounds! I don't know how to explain it other than it sounds quieter and less obnoxious, but so much better.
Nothing to report on power, can't tell if it made a difference or not, I just know the sound put a smile on my face.
Highly suggest this and I have no idea why this doesn't come this way stock like it does on the S63tu.
      12-11-2018, 04:17 PM   #82
protecon
*May contain nuts
protecon's Avatar
Australia
193
Drives: 2010 X5M MCB
Any chance you can take some videos?
Looking to de-obnoxious mine somewhat
VMAX 0-1000M ▒ ▒ 230@22.619 > 232@22.489
      12-11-2018, 09:44 PM   #83
9vapors
Drives: CB X5M
Not the best quality, sorry... always much better in person!
m5james431.00
      12-11-2018, 09:46 PM   #84
9vapors
Drives: CB X5M
Couple pics from today!
RDR142240.00
m5james431.00
      12-17-2018, 01:52 PM   #85
9vapors
Drives: CB X5M
Friday the lowering springs and bump stops go on... for today, I was able to get the front spacers on finally... also got the key cover from IND. I left the key hole/assembly under the cover in case the battery dies. Mine wouldn't clean up and I stared at it when I got in the car every time.
      12-18-2018, 12:45 PM   #86
0-60Motorsports
Bahrain
792
Looks great
Current Mods:
IG: @060Motorsports
      12-22-2018, 11:41 AM   #87
9vapors
Drives: CB X5M
Finally got it lowered with the 2" H&R springs... I love the look without the roof rails. Someday I'll do some pro pics. Anyone want to swap factory tinted windows to clears? I want clear glass.
      12-22-2018, 12:03 PM   #88
boneca
boneca's Avatar
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
looking good there with 2" drop
9vapors651.50
xbimmers
