      01-26-2011, 07:55 PM   #1
frankcos
frankcos's Avatar
Drives: E90 M3
Correct Offset for 120i Cabrio
Hi,
Sorry if there's already a post on the captioned topic, but i've gone through most of the threads and many configurations are being mentioned, so I would like to start off with a new thread to find out the correct configurations.
Can someone please tell me what is the correct offset for 120i cabrio? Currently, i'm on 18" x 8" offset 35 (tire: 225/40/18) and the front sticks out a bit... i'll also be installing kw v1 so I want to maximize the coilover by lowering the car as much as possible but avoiding the wheels to scrub...
Any feedback and comments will be appreciated.
Thanks.
      01-26-2011, 08:04 PM   #2
AW128i
AW128i's Avatar
Drives: E82 N51
I think the "maximum" wheel/tire/offset mix that can be run without making changes to the front camber is as follows.
Front: 8", 45 offset, 225 tire
Rear: 9", 48 offset, 255 tire
That's just what I've gathered from browsing this site so it very well may be off some.
      01-27-2011, 01:24 AM   #3
frankcos
frankcos's Avatar
Drives: E90 M3
thanks, so anything below the specs provided would be OK? or is it anything above is OK?
      01-27-2011, 09:06 AM   #4
AW128i
AW128i's Avatar
Drives: E82 N51
Unfortunately, it's not as simple as that. If you change the width of the wheels, you'll likely have to change the offset too, and you also have to factor in a tire width change. If you search this forum, you'll find a lot of info about wheel/offset/tire combos that people have that work.
offset, wheels and rims
