01-25-2022, 05:08 PM | #67 |
Rep 5
I have connected everything to my f32 but its not working. Seems like something is wrong as when I connect 12v positive wire to a board it straight away turns on ignition and does not turns off at all. And plus its not getting a tripple lock signal at all. So maybe I done something wrong or its not compatible with my car. 😂
01-26-2022, 07:32 AM | #68 | |
Rep 817
Drives: bmw M3 F80
you can connect to the idrive wheel as I did it's not mine but it's in the same place |
01-26-2022, 07:36 AM | #69 | |
Rep 817
Drives: bmw M3 F80
I had the same problem it was due to the LM2596S card which was defective (my relays were still on) I bought another LM2596S card and no more problems |
01-26-2022, 07:45 AM | #70 |
Rep 5
01-26-2022, 12:58 PM | #71 | |
37
Rep 80
I am doing something like this for my project as well but with an aftermarket remote fob and an ESP32 with WiFi, Bluetooth, LoRa and LTE. Initially I was using a standalone ATmega328p, but caved in for the extra possibilities of the ESP32 (phone control, OTA updates, etc). I see you changed the unlock to lock to turn on the car. I was going to mention this as well. No need to unlock the car, just by pressing lock from inside the car and keeping the fob on until you turn on the car, it turns off the alarm and doesn't trigger the anti-thief. Also, in mine, since I don't have a spare BMW fob and I'm using an aftermarket remote fob (with PKE), I actually have it to arm the alarm (red rear view mirror LED) when you press lock. In order to do this, if the car thinks there is a remote inside the car, all you need to do is activate the lock and battery of the in-car fob for a really short time (0.3 seconds?)... This way the lock signal is sent but the car does not have time to locate the fob inside the car. Finally, in regards to the current draw you are seeing... 30mA is too high for the car and I'm surprised you haven't seen any messages of high battery use when you turn on the car manually. I believe the usual locked/shutdown battery current draw is 5-10mA. Using a standalone microprocessor would help, but you can also use one of the many arduino libraries to put it in sleep mode until the button signal is received or every X seconds. You can also use transistors instead of relays to drop the current even lower. The other thing you can do is feed it exactly 3.3 or 5V, whichever you are using, with a good quality (and low quescient current) drop down buck converter or similar. Again, amazing project and I'm happy to see someone has finally done this! Hopefully I'll finish my project one day and I can post about it lmao. |
AlbertoSONIC98.50 fe7565556.50 |
01-29-2022, 07:41 AM | #72 | ||
99
Rep 155
ESP32 is really nice but... aren't you worried about its power consumption? The idea of putting arduino to sleep is very nice, I'll have to look into it. 30mA is not so much but, combined with the insurance gps black box, it causes the "Battery discharges" warning in the idrive after a few days of car being parked. About the relays, they don't cause a lot of power consumption. Actually, they don't consume anything when off. Regarding the voltage conversion, it's already done with a step down buck converter, pretty efficiently and with low quiescent current. Hope to see your finished project soon! |
01-29-2022, 05:42 PM | #73 | |
37
Rep 80
https://www.aliexpress.com/item/4000542688096.html?gatewayAdapt=Pc2Msite https://github.com/Xinyuan-LilyGO/LilyGO-T-SIM7000G It has enough people using it that the supplier actually listens to requests and makes improvements + releases code. Current-wise it's supposed to be below 1mA during sleep. I've read of anywhere from 600 to 30 microAmps. Who knows. It has an ESP32, WiFi, Bluetooth, LTE with 2G/3G backup, and a battery charger. The last thing I'd like to add to my algorithm is something to control the AC/heater... But I think I need to deal with LIN in order to get this done. |
01-31-2022, 06:08 PM | #77 |
Rep 5
Man kažko tai nesigauna užvest. Iš pradžių reagavo į pultelio paspaudimus, dabar jau nebereaguoja. Šiaip pats pajungimas tikrai nesunkus. Daugiau darbo išsiardyt pačią mašiną, negu susilituot viską 😂 tik tiek, kad jau 3 kartus bandžiau perdaryt viską, nesiveda nors tu ką 😂
02-25-2022, 04:52 AM | #79 |
Rep 5
Thanks Albertsonic, my remote start works great. Only problem I have is turning the car completely off when I do the shutdown procedure. Lights and stereo stays on.
02-26-2022, 08:34 AM | #80 | ||
99
Rep 155
Yeah it actually does. First of all, you have to connect to clutch switch instead of break light switch. In the circuit, you have to remove the resistor on the brake light switch relay output. Finally, you have to use the code from "manual" branch instead of "master" branch on github.
I'm aware of this battery issue. I'm trying to find a way to make it working without needing to stay always on. I'm aware of this issue aswell but unfortunately I haven't found a solution yet. |
03-05-2022, 05:22 PM | #84 |
99
Rep 155
03-06-2022, 03:48 AM | #85 |
Rep 33
Nope. DRLs stay on.
But still, it's better to have the Xenons and the radio shut down as soon as the car turn off to avoid wasting the battery. As for the loosing battery problem... only idea I have is having another battery for the arduino. It would charge from a 12V feed when the car was on and when the power was off it would use the battery... Only problem would be the autonomy, probably after sitting for 2-3 days this function wouldn't work because the arduinos battery would be empty. |
03-08-2022, 09:37 PM | #86 |
Rep 1
Hey AlbertoSONIC , how did you fetch the IDs for the kcan messages? I'm trying to find a more comprehensive list but there's very little documentation.
EDIT: Nevermind, I found em here: http://www.loopybunny.co.uk/CarPC/fi...ter=flag_KCAN2 Last edited by rkrishnan; 03-10-2022 at 08:57 PM.. |
06-17-2022, 11:44 AM | #88 | |
10
Rep 38
I got manual working and I haven’t got it working all the time. It works perfect. I got 12v from lighter. At the beginning I was pressing close wait 1 sec and the pres 3 times but I realize that works well just pressing 3 times.
AlbertoSONIC98.50 |
f30, remote, remote start |
