Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > 07 328i not starting transmission code
      04-19-2024, 06:49 PM   #1
[E90Anthony]
BMW
[E90Anthony]'s Avatar
Drives: 2007 BMW 328i sport
Hi, I have an 07 328i with the GM6L45 transmission. My transmission was recently slipping so I decided to change out the megatronics system. The change went good everything fit fine , when i put everything back together and try to go start it the car doesn’t start , accessorie mode comes on but car doesn’t crank. Anyone have any suggestions?
(These are the codes i’m getting.)
      04-19-2024, 07:48 PM   #2
[E90Anthony]
BMW
Update!!
If anyone has had this problem and knows a solution please message or reply.
Thank you
      04-19-2024, 08:50 PM   #3
gbalthrop
Drives: 2007 328xi E91
Originally Posted by [E90Anthony] View Post
... 07 328i with the GM6L45 transmission. My transmission was recently slipping so I decided to change out the megatronics system... accessorie mode comes on but car doesn’t crank... [Fault Codes: CD9E, CD99, U111A, U110F]...
The Fault Codes suggest the DME is NOT receiving messages from the EGS (Transmission Module) via the PT-CAN Bus. If you had INPA or ISTA, or a Scan Tool Capable of displaying Live Data in the CAS Module (Terminal Voltages & Bus Signals received, such as Gear Selected (P/N) from EGS, you could Quickly determine WHY NO Crank.
One Method you can do, with NO Tools:
1) Turn on Ignition (Insert Remote Key into Insert Compartment & Press START Button, WITHOUT pressing Brake;
2) Does Instrument Cluster Light?
3) If you NOW press Brake, can you Remove Shift Lever from Park Position?
4) If you CAN Move Shift Lever, does "Gear Selected" (P,R,N,D) appear on Lower Instrument Cluster display?
That is an indicator of whether or NOT the EGS communication via CAN Bus is working.
Please let us know:
A) Make/Model of any Scan Tool or Diagnostic Software (INPA/ISTA) available to you;
B) Do you have a Multimeter?
C) Are you sure you reconnected X8500 Round Connector on upper-right of Transmission?
D) Did you inspect for any wiring issues/damage at that connector?
E) Did you disassemble anything at the shift lever or center console?
F) What are Last-7 Characters of your VIN?
Please let us know answers to above, and we can suggest Next Steps.
George
      04-19-2024, 09:25 PM   #4
[E90Anthony]
BMW
Hi , The car does not display PRND on dash. The car will not move out of park.
INPA
I’m not sure what that is
Yes
All connections are good
No
KX70315
The cars vin does not match cas module vin cause cas has been swapped.
      04-19-2024, 09:44 PM   #5
Lostwooli
Drives: BMW m4
Hey guys. Im his dad. A while back the CAS went bad so i bought a DME Key and CAS set so those three modules are a diff VIN
Now today his trans wasn't shifting so i bought a transmission valve module and since we put that in the car wont start
When we were having CaS issues before i downloaded the BMW tools suite. I have all the E89 files.
The is a GM trans car
I can navigate around the software but when is comes to identifying the modules and files im lost
Any insight helps or ill even pay someone to remote into the laptop and program all these modules so the car works.
The car is mechanically in good shape, itll be a shame to not have it working because of coding.
      04-19-2024, 09:46 PM   #6
Lostwooli
Drives: BMW m4
We can check the barrel connector again, however i think its in correct
      04-20-2024, 09:49 AM   #7
Lostwooli
Drives: BMW m4
Anyone? Bump
      04-20-2024, 11:07 AM   #8
gbalthrop
... These are the codes i’m getting. [NO "18 EGS", meaning Transmission Module is NOT communicating -- see below]...
...The car does not display PRND on dash. The car will not move out of park... INPA... Do you have a Multimeter? I’m not sure what that is [DMM or Digital Multimeter, used for TESTING electrical circuits by measuring Voltage or Continuity -- see below]... X70315...
Originally Posted by Lostwooli View Post
... A while back the CAS went bad so i bought a DME Key and CAS set so those three modules are a diff VIN. Now today his trans wasn't shifting so i bought a transmission valve module and since we put that in the car wont start...
So the engine started & ran with replacement Key, CAS & DME, UNTIL Trans (GS1912 Module, GM6) repair. See attached pdf: "INPA Tutorial Quickstart" for entry-level info on INPA (BEST diagnostic Software for data ;-).
In your photo of INPA Screen (INPA > Functional Jobs > F4 > F1 Error Memory, ALL Modules, there is NO "18 EGS" which is the GM6 (GS1912) Module. Check fuse F6, 15 Amp, which supplies voltage to EGS when Ignition ON (KL30G active). If intact, also check for continuity to Chassis Ground at the Brown wires, X8500/13 & X8500/16 (Sockets #13 & #16 of Round X8500 Connector at transmission. There should ALSO be battery voltage at X8500/14, Red wire, with Ignition ON (KL30G active).
If you have BOTH Voltage Supply & Ground at the X8500 connector, then there is likely an issue with the PT-CAN wiring at X8500/2 Yellow wire, or X8500/6 Black wire.
If you need a Multimeter, an entry-level model, ~ $10, like linked below, is all you need:
https://www.harborfreight.com/electr...ter-59434.html
https://www.amazon.com/s?k=multimete...f=nb_sb_noss_1
ISTA wiring diagrams, with X8500 Connector View, for your 9/2006 build 2007 328i E90 N52 are attached to NEXT POST.
George
      04-20-2024, 11:10 AM   #9
gbalthrop
ISTA ScreenPrints for 2007A 328i N52 E90, per prior post.
George
      04-20-2024, 11:15 AM   #10
Lostwooli
Drives: BMW m4
Thanks George we will run that down.
      04-21-2024, 02:48 PM   #11
[E90Anthony]
BMW
Hey george,
We checked ground and power. Plug has ground and power. Fuse is good. Any other ideas?
      04-21-2024, 03:15 PM   #12
[E90Anthony]
BMW
Still no Number #18. I am wondering if the replacement module just isnt responsive
      04-21-2024, 03:26 PM   #13
Lostwooli
Drives: BMW m4
Ok plugged in the old module and it read it right away. Now i have to argue with ebay
gbalthrop2717.00
      04-24-2024, 05:08 PM   #14
Lostwooli
Drives: BMW m4
Update, got a junkyard module and the car runs/drives. Thanks for the help
gbalthrop2717.00
