10-19-2021, 09:24 PM | #68 |
Rep 1,934
The newest version is xdrive compatible. The same part number is also for the G2x 3 series.
03-01-2022, 09:33 PM | #69 | |
Rep 3,954
I just tried to mount my square summer wheel/tire setup: 255/40/18 Continental ExtremeContactSport 18x8.5 APEX ARC8 18x8.5 ET38 BMW camber correction wheel hubs for an additional 0.5 degrees of camber This would not clear the updated Ohlins R&T kit at all. I used a 5mm spacer and it barely cleared by 0.5-1mm. The spring perch is the part that is rubbing against the sidewall of the tire. |
03-02-2022, 02:52 PM | #70 | |
Rep 8,511
The tyres are 30mm wider than stock, and you are running camber correction hubs which obviously change the relationship between the wheel/tyre and the macpherson strut rather than camber plates which change the angle of the entire strut / hub / wheel / tyre. Taking that approach increases the likelihood of components coming into contact.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
Tommi_Mav65.50 |
03-02-2022, 04:56 PM | #71 | |
Rep 3,954
So the Millway street version camber plates weren't available when I went the route of the -0.5 wheel hubs. I'm inclined to actually purchase the +0.5 wheel hubs. Based on some very basic trigonometry, I think you would gain an additional 5mm of clearance by going with +0.5 wheel hubs. Also note, that the new updated Ohlins R&T kit does have shorter springs. 180mm vs the original 200mm length from the initial kit. |
03-03-2022, 10:21 AM | #72 | |
Rep 8,511
The lower part of the damper bodies (located in the wheel hub carriers) are not threaded quite as high as I'd like - they don't have quite enough height adjustment range to achieve the stance that I wanted for the car. Shorter spring may be able to compensate for that, as long as the spring rates/length can still provide enough suspension travel and the damper pistons remain in their operating stroke range relative to the damper bodies.
07-08-2022, 03:06 PM | #73 |
a bit obsessed
70
Rep 85
Has anyone noticed that there are now two Ohlins coil-over options that supposedly fit the 2016-2019 x drive?
I ordered the kit that also fits the G series, but the original kit that used to not fit x drive apparently now does. |
07-08-2022, 09:25 PM | #74 |
Rep 1,934
Yes because shocks that fit xdrive in the front can also fit RWD. But front rwd shocks are too long for xdrive and hit the axle boots. I have the ohlins for xdrive. They ride great. Taking them to autocross tomorrow too.
07-09-2022, 08:55 AM | #75 | |
a bit obsessed
70
Rep 85
I believe part #BMSMP00OH was the first option for the F30, but was not compatible with x drive. Now, per ECS and Turner websites, this part number is compatible with x drive. |
07-09-2022, 02:14 PM | #76 | ||
Rep 1,004
Some people complained the rear was to stiff. I have a set of the original and before even installing I swapped to 375 lb fronts and 750 lb rears. For street it's feels like stock just more control but I've taken it the track a few times and it's a bit soft. I might swap in the original 900 lb rears and order a set of 450 lb fronts. I think Ohlins got it just right this time around. |
07-09-2022, 04:13 PM | #77 | ||
Rep 1,934
03-22-2023, 07:23 PM | #78 | |
Rep 7
340i, bms mp00, coil overs, coilovers, ohlins, road and track, spring rate |
