BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > *** OFFICIAL bootmod3 de-cat with OBD readiness THREAD***
ARMA SPEED
      11-22-2019, 03:02 PM   #67
zen0s
Drives: 2018 M3 Competition
I'm in Maryland and I'm able to pass emission test without switching back to stock DP. We do have convenience of doing it ourselves and allow to have 1 monitor not ready.
I haven't had any issues with CEL with my Wagner high flow dp. As long as I flash back to stock I was able to pass every single time.
      11-22-2019, 05:37 PM   #68
F36GC_NYC
Drives: 2016 EB 435GC xdrive
Originally Posted by XxThe_RemedyXx View Post
Damn I'm getting my catless DP TODAY and my inspection expires in September. Really don't want to wait until the end of the month to swap it.
fellow NYer here, let me know if you find a solution
i too went with a catless dp cause im an idiot
      11-22-2019, 07:24 PM   #69
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
But the powaaaa and sound!!!
Unfortunately I had to remove my catless DP and reinstall my OEM DP to pass. Then I removed my OEM DP and reinstalled my catless DP because I'm a glutton for punishment.
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Tune Stage 2 - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI
      11-23-2019, 01:14 AM   #70
N55E90toF30
N55E90toF30's Avatar
35
Drives: 2014 335xi 6speed FBO BM3 stg2
Catless DP + Mini cat, without spacer. CEL came on after 40 miles...
      11-23-2019, 09:38 AM   #71
F36GC_NYC
did you do the labor yourself? i just got my car inspected so i have a year.... next year i will try to find a "hookup" but i hear those are almost as much as a catless dp =( which would cost the same amount of labor if someone removed and added it back for me....
      11-23-2019, 11:59 AM   #72
XxThe_RemedyXx
967
No I have a friend who is a mechanic and has a shop. He only charged me $80.
      11-23-2019, 02:24 PM   #73
F36GC_NYC
i do too i guess i will have to speak to him see what he can do for me.
or maybe your friend can be my friend and we can all be friends together
      11-23-2019, 03:08 PM   #74
XxThe_RemedyXx
967
For sure just hit me up when you're ready.
      12-09-2019, 09:49 AM   #75
N55E90toF30
35
Anyone have “friend” in Philadelphia? PM me plz!!
      12-09-2019, 11:02 AM   #76
Steakpizza
118
Drives: 320i
Originally Posted by N55E90toF30 View Post
Anyone have "friend" in Philadelphia? PM me plz!!
Yo let me know too if you can lol, I'm in PA and want to go catless but it's a pain redoing the downpipe.
      04-06-2020, 09:23 AM   #77
PAFD355
14
Drives: 2015 335i
Follow-up
Well I guess later is better than never!
Ive got my inspection this month and have been able to get mt '15 335i into an emissions ready state while running Stage 2 w/o cat using an angled spacer.
Its easily accessible from the top side of the engine bay and takes about 5 minutes to install. *For offroad use only
From my testing you'll need to keep out of Sport+ mode because it will throw a code during spirited driving. Prior to the angled spacer I would not get a ready state from the Cat check and an efficiency code. As you can see in the attached images Cat check passed.
      04-06-2020, 03:39 PM   #78
aps
aps's Avatar
336
Drives: 2018 M3 ZCP
link to the spacer?
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5
2013 Glacier Silver F30 335i (sold)
      04-10-2020, 12:41 PM   #79
PAFD355
14
Drives: 2015 335i
Originally Posted by aps View Post
link to the spacer?
I used a spacer from bigdaddiesgarage.com/
Dropped her off for inspection today and passed. I flashed to the 0+ M2 map and completed a drive cycle.
aps335.50
      04-11-2020, 05:56 AM   #80
XxThe_RemedyXx
967
You were able to install without removing CAT? Pics?
      04-11-2020, 09:52 AM   #81
PAFD355
14
Drives: 2015 335i
Yeah, Zero issues installing, just remove your engine cover and reach down the passenger side of the engine.
In the right foreground you can see the upstream O2. Both are pretty easy to see and access from the top of the bay.
      04-13-2020, 08:45 PM   #82
N55E90toF30
35
Selling big daddy’s garage spacer and the mini cat.
Bought fabspeed catted DP.
message me
      05-28-2020, 11:55 AM   #83
snipagang
64
Drives: 2017 320i xdrive
Ive read through this forum and I am unable to figure out if anyone ever found a solution to this. If you run a catless/catted high flow dp do you just fail emissions? Nobody has found any workarounds?
      05-28-2020, 12:56 PM   #84
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
Guess you need to read more.
If you want to "legitly" pass emissions, get a good catted DP like fabspeed, AA, or CG precision.
Catted versions of Wagner, ER, VRSF, etc, will not pass emissions.
Having said that other people claimed to pass emissions with a catless downpipe (meaning that their catalyst monitor was in ready state) by using an angled O2 spacer on the secondary O2. I forget which thread it was in.
To my knowledge none of the "CEL fix" or other methods (like the VRSF one) ever worked to pass emissions.
Finally, note that some states allow one monitor to not be ready, in which case if everything else is good, you can pass emissions even if your catalyst monitor is not ready to due catless or catted DP that is "not good enough".
      10-21-2020, 08:24 PM   #85
paimon.soror
paimon.soror's Avatar
Drives: 2016 F36 435x MSport
Going to necro this tread just to give a few updates. As many of us know, not only was there a few things mentioned on the first page to try out, but BM3 also released a DTC Code Deactivation section as well. Unfortunately, here are my results:
Stock Map - Setting Decat Charge Min to 199, Max to 0
All available monitors eventually went green
But i saw a pending P0420 code using OBDLink
Stock Map - Setting Decat Charge min to 0, Max to 199
Stock Map - Set DTC Code Deactivation for 180001 and p0420
Not sure what else to try
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current
      10-22-2020, 11:37 AM   #86
JaredG_F30
JaredG_F30's Avatar
1106
Drives: 2014 335i, M-Sport, Manual
Does your state allow one monitor not ready or to all have to be ready?
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
      10-22-2020, 04:41 PM   #87
N55E90toF30
35
PA allows one monitor to be not ready
      10-22-2020, 05:35 PM   #88
paimon.soror
CT also allows only one. Problem with stage 2 is that it throws 2 things into not ready for me. I think it was the catalyst and o2 sensor
