BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > General M3 Forum (E90 + E92 + E93)
EXXEL Distributions
      02-12-2024, 01:43 PM   #287
Assimilator1
Assimilator1's Avatar
593
Drives: BMW M3 e92 08 & 330d e90 10
2010 BMW 330d  [8.00]
2008 BMW M3  [0.00]
The latter cars (2010 ish) which have the alu/tin/copper bearings seem to fare better than the earlier ones. When pulled, they certainly still come out with some wear on them, but I haven't yet seen any of those which have worn through the babbitt (protective) layer to the copper. But they still have abnormal wear compared to most other engines out there.
You can look through several hundred photos of bearing sets pulled yourself if you like! , like I did! Lol, see here - https://www.m3post.com/forums/showthread.php?t=1253084 , or you could look at my summary I did a few years ago (link in my sig).
Oh and there is still some debate as whether mild detonation at least could be contributing to the bearing problem, but who knows!?
With the earlier bearings it's clear cut, just ditch them because it's pretty much a case of when they fail, not if (for ~98% of them anyway).
The later ones it's not so clear cut, I'd say the risk is lower with them, but failures have occurred. Personally I would change them for piece of mind at least.
Original throttle actuators will fail sooner or later too, but with those you could just leave them until they fail, it won't hurt your engine (it'll just run poorly), although it could be a right pain in the neck if one fails on a long journey!
Welcome to the club btw , got any pics of your M3?
AndyW670.50
      03-19-2024, 05:14 PM   #288
pbinmich
17
Drives: 2013 BMW M3 E93
Thanks. Here's one...I've since cleared the headlight mist, washed, clay bar cleaned, buffed, and waxed - looks great
Appreciate 3
CTMike262.00
PACarGuy683.50
      03-19-2024, 06:19 PM   #289
Assimilator1
593
2008 BMW M3  [0.00]
Very nice
Interlagos blue? That's one of my favourite colours!
      03-19-2024, 06:43 PM   #290
pbinmich
17
I do believe that is the color name...it is nice. Initially, I was just looking for a 4-seat hard-top convertible with a descent engine - there's few options. That this used car popped up, also being an M3, last year with a V8, in a cool color, 45k miles...I'm very happy - found at a HONDA dealer no less.
      03-29-2024, 11:41 AM   #291
Weather Man
Weather Man's Avatar
1124
Drives: BMW M4 Competition AWD
So, since I am thinking of picking up a M-3 V-8 powered auto-trans Coupe, I read through the thread and found the following biggies to look for. Any obvious ones I missed?
AC compressor
Motor mounts
Rod bearings
Buy 2009 or newer
DCT weeping
Auto trans service Pressure filter, suction filter, and a suction jet pump
Gas cap rubber fails to seal
Replace spark plugs often
The E9X M3's two throttle actuators will eventually fail. Replace proactively?
      03-29-2024, 12:18 PM   #292
Assimilator1
593
2008 BMW M3  [0.00]
Personally I'd leave the throttle actuators until they failed as it won't harm the engine.
Unless you often go on long journeys often, in which case it would be more inconvenient.
Btw, curious as to why you mention buying from 2009 onwards?
      03-29-2024, 12:21 PM   #293
Weather Man
1124
Seemed to be enough improvements in engine and transmission reliability in the posts to steer that way.
      03-29-2024, 01:24 PM   #294
Richbot
Drives: Jerez Black E90
Missed:
Recalls - fan blower wiring, possibly battery disconnect module, and airbag, get done if not done
Valve cover gaskets
Engine grounds
Comments:
AC compressor - No, what?
Motor mounts - Yes
Rod bearings - Yes
Buy 2009 or newer - No (unless you want idrive, then yes, but you shouldn't, because screens are for doors). There is zero functional difference mechanically. 2008's are older and were made in larger numbers than most of the other model years, so you'll see more issues popping up with them. I'll go one further and say unless you are keeping it completely stock and really want ZCP (which is 2011+), 2008's are a much better value on the used market than anything newer again because age and scarcity both weigh in favor of a lower price on the 2008's
DCT weeping - Yes (but get a manual)
Auto trans service Pressure filter, suction filter, and a suction jet pump - Yes but get a manual)
Gas cap rubber fails to seal - Yes, I suppose, replace it when you need to get to free shipping at the parts shop
Replace spark plugs often - Yes, halve the factory time (I do mine about every 15,000 miles). Also consider doing coils proactively
The E9X M3's two throttle actuators will eventually fail. Replace proactively? - No. You'll have warning. They start throwing codes that don't immobilize the car. Order some then
      03-29-2024, 01:33 PM   #295
Assimilator1
593
2008 BMW M3  [0.00]
Originally Posted by Richbot View Post
Missed:
Replace spark plugs often - Yes, halve the factory time. Also consider doing coils proactively
Any good data on that?
I saw Evolve did a good video on that, showing dyno before and after figures with new plugs, which had done 30-40k miles.
Change the coils proactively!? Have you see how much those are!?
(IIRC ~£100/coil).
      03-29-2024, 01:35 PM   #296
Richbot
Depends on age and mileage obviously. The coils in my car were about 8 years old and 80,000 miles old when I changed them, and I'm at 142,000 miles and 16 years old now. Mostly for me it was about servicability - the old coils were getting brittle and stiff. They get hot, and are plastic, and you have to yank hard on them to get them on and off. You can always keep the old ones as spares or rotate a couple newer ones to the back of the engine bay.
I noticed a pretty big difference in part throttle/transient response on new plugs after the plugs get above 20k miles back when I let that happen, so I stopped letting that happen, and I no longer notice a difference changing at 15k. The dyno doesn't tell you everything. It's also a good excuse to check for oil leaks on the valve cover with stuff out of the way
I'm one of the ever-diminishing number of people on here who have owned their car since it was new. Please be kind to me in my old age.
      03-31-2024, 10:58 AM   #297
Assimilator1
593
2008 BMW M3  [0.00]
Richbot
Wow! Impressive you're the original owner!
I wonder how many there are of you here?
Re plastic, yea good point, mine's a 2008 year car (81k miles) and I broke a chunk of plastic getting one of the coils out! Had to seal the gap with silicone sealant, lol. Still works ok though.
Next time I pull them though I'm going use a cord and a lever to remove them, hopefully spreading the load will prevent any more damage!
Re plugs, interesting, my plugs have done about 20k miles, and I've noticed it somewhat flutters/splutters on giving it a small to modest blip of throttle from idle when stone cold to 'luke warm'. I've also noticed it getting a bit worse over the past couple of k miles or so (low annual mileage).
Perhaps my plugs are starting to go 'off'......
[edit, it's not the slightly damaged coil as it doesn't seem to be affecting just 1 cylinder and also it didn't happen immediately after the coil damage, and it's fine from warm to fully warmed up/hot).
m3post
