BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Engine temperature above 120 Celsius. should I worry?
Studio RSR
      07-18-2016, 01:15 AM   #1
Funkier
14
Drives: F30 316i + F54 Cooper
Hi.
I drive an F30 2012 N13 136 hp + Racechip. Recently I notice the engine temperature reaches above 120 Celsius. Is that normal or should I worry?
It happened when I was driving in EcoPro around 1750 rpm for 25 minutes.
I was driving in a very tranquil mode so that the average consumption was 5.3lt/100km for 50 kms.
It was kind of uphill but the transmission was in Auto (Drive) and it did not need to shift down. Also the A/C was on and outside temperature was 35 Celsius.
      07-18-2016, 03:42 AM   #2
Project Elite
Project Elite's Avatar
137
Drives: F30
Sounds normal given the circumstances. Long drive, uphill, hot outside, etc.
I wouldn't say I hit that engine oil temp frequently but it does happen on drives over 45 minutes or so, depending on speed.
      07-18-2016, 04:11 AM   #3
Funkier
14
Thanks a lot for the reply. I am very relieved indeed. Some bimmers don't even have the temperature dial so I thought it is OK as long as there is no error or warning on idrive. But suspicion haunted my Racechip'ed mind.
      04-27-2024, 05:09 AM   #4
elborhamy
Drives: bmw f30 316i 2013
Hi
I have the same symptoms with same car, I own the car 10 years ago, it didn't pass 120 Celsius before, now at about 100km/h speed it does,
Any updates
      04-27-2024, 07:30 AM   #5
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
The car lets the oil temperature go higher while cruising, for maximum efficiency. It lowers the temperature when alternately accelerating and decelerating, to reduce the possibility of pre-ignition.
      04-28-2024, 03:02 PM   #6
elborhamy
Yes
Thank you for answering, I'm wondering why the car starts to do this after 10 years, for me there is something wrong, I replaced all related parts ( all coolant hoses, radiator, water pump, aux or turbo cooling pump, expansion tank with cap, thermostat, oil pressure sensor, oil level sensor, oil filter base, the turbo itself, valve cover, I even replaced head gasket)
The water temp. Is 113 Celsius max and oil temp is about 122 Celsius.
This driving me mad
      04-28-2024, 03:41 PM   #7
Billfitz
Billfitz's Avatar
Are you sure you just didn't notice it before? BMW has used this variable oil temperature feature throughout the F series, and I suspect before that as well. The coolant temperature would normally be less than the oil temperature, as the boiling point of coolant is considerably lower than that of oil. If in doubt there's always the method of last resort...the manual.
      04-29-2024, 11:40 AM   #8
elborhamy
Thank you
I'll wait and observe
