10-21-2014, 10:37 AM | #463 |
Rep 10,616
I just replaced the bearings on my 08M3 with 60k using WPC treated bearings and am using Mobil 1 0W40 oil for street use. My 60k mile stock bearings had some premature wear but I think they still had life left in them. I do not plan to worry for another 60k or 6 years at the rate I drive. By then hopefully there will be some reports of WPC bearings being inspected after accumulating some miles and we will have an idea how they are working. Based on that, I will decide to change them again or leave them. Might also be higher clearance bearings available then.
If changing bearings as preventative maintenance is not something you want to consider, sell the car and buy a car that does not have this concern. |
10-21-2014, 07:57 PM | #464 |
Rep 988
Curios... Are the wpc bearings you guys provide come from a stock of part numbers that allow for the best possible clearance?
If not do you guys measure out the clearance once on the car and mix and match to allow for the most clearance? It is it a random set of wpc bearings? Reason I ask is that in another post, Dinan stated in their stroker builds that they use the OE bearings. But they mix and match different oe bearings until they get there in house spec bearing clearances for their stroker builds. My 08 has 70,000 miles on it. So far my blackstone reports are excellent and no funny sounds. If I already have a set that allows the most possible clearance, I don't want to replace with a set that has less clearance. |
10-26-2014, 11:44 AM | #465 |
Rep 100
The wear on those bearings looks like text book detonation.
Bearings should never "wear" in normal use, the oil wedge should always keep the bearing from ever touching the journal, it's only in cases where the oil film breaks down due to oil dilution or cylinder pressure spikes that the bearing is damaged by rubbing the journal. What you guys are seeing in these motors is not going to be fixed by a few tenths of moly sprayed onto a bearing. Those coated bearings are sacrificial, we use them on race motors to keep the motor from grenading in the second or two it takes the driver to get it shut down in case of an oil system failure. Once that failure has occurred, the motor is disassembled and the bearings are replaced because it's known that they will be worn at that point. In a motor which is maintained and running properly I can take it apart after several seasons of racing, or in the case of street motors, 50K miles and the bearings should look like the day they were installed....most oem motors these days have such good oil systems and tunes that the bearings look like new past 100K easy. |
10-26-2014, 12:40 PM | #466 |
Rep 1,017
Drives: 2010 E92 M3 6MT
In around another year or so we will start to see engines with the wpc treated bearings getting cracked open and we will see how they hold up. No its not a fix would need to mill down the crank for that like the guys who build the 1000hp m3 race motors do.
4.4L LC stroker/ESS VT2-625/Volk te37 sl's/AA exhaust/DSS Carbon Fiber driveshaft/ARH Headers.. etc |
10-28-2014, 07:19 PM | #467 |
8211
Rep 18,823
Drives: BMW
2008 BMW M5, 91,XXX mi
Info
Vehicle: 2008 BMW M5, SMG Oil Used: TWS Motorsport 10W-60, 7500mi intervals Mileage: 91,XXX mi Fuel: 91 Oct Driving Habits: Mostly highway driving, no track use Oil Analysis: None provided Notes: This particular M5 was fully serviced under scheduled maintenance and meticulously followed thereafter with oil changes every 7500mi. Our first M5 bearing swap being performed as a preventive measure, no oil samples have been analyzed prior to teardown. A sample has been collected and will be provided to Blackstone for analysis. Bearings were replaced with WPC Treated bearings, ARP bolts.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 10-28-2014 at 08:38 PM.. Reason: typos |
10-28-2014, 07:32 PM | #469 |
Rep 1,673
Nothing to see here folks, move along
As always thanks for the write up EAS
Electronics Junkie, Engine Builder.
10-28-2014, 10:19 PM | #474 |
Rep 7,110
Anyone ever received a feedback or comment from BMW on these freaking bearings? Its clear that they have replaced a good number of at least S65 engines at this point and I'd assume have had complains/requests filed by folks who changed themself. What is their story? Complete silence..?
10-29-2014, 03:11 AM | #475 |
Rep 4,381
Yeah its interesting..had a quick look round the S85 forum and their rod bearing wear pattern is much more even that the S65. Maybe more lubrication related than clearance?
10-29-2014, 08:53 AM | #477 |
Rep 922
Has anyone proactively replaced them and saw no premature wear? That's what I would like to know because it looks like the ones who have posted doing this still shows premature wear. So far it seems we do have a problem, wether or not grenaded. I will get mine replaced when I hit 50k for peace of mind...at worst it grenades under warranty.
'11 Black/Black GLK350 (Wife)
'19 Black RAM 1500 Big Horn Night Package '11 Loaded AW Fox Red/Black/Black Carbon Leather ZCP E90 M3 (Halloween Delivery) |
10-29-2014, 09:04 AM | #478 |
Rep 10,616
I would say all of my lowers were OK and half of my uppers. The half of my uppers that had what I call premature wear look comparable to the worst of the lowers of the S85 bearings posted above. I have little doubt about what would have happened eventually, but my 08M3 with 60k was in no imminent danger of failure and probably would have been fine for a few more years.
10-29-2014, 09:26 AM | #479 | |
92
Rep 383
Search my username for my post. Doug |
10-29-2014, 10:43 AM | #481 |
BMW Super Enthusiast
126
Rep 245
Kinda what I was eluding to in my last post in this thread. No one has torn an S65 down with promising looking bearings. How is this internet hysteria?
'15 ///M3 - Daily ****** '97 ///M3 - Track Car
'04 330ci ZHP - sold **** '08 ///M3 - sold '00 328i - sold ********* '00 323i - totalled '94 325ix - Parted *** '92 318i vert - sold '94 325i - Rear End Total ***** '01 330ci - traded |
10-29-2014, 04:07 PM | #482 |
Rep 7,298
This is just like the E46 subframe issue. BMW knows this is a problem but doesn't care because the majority of these engines will run past 100k miles without failure. Once you are out of warranty, once they no longer have to foot the bill, they do not care what happens to you. This is why they didn't change the bottom end when they went from S85 to S65. It was "good enough" and BMW would prefer you to buy a new M3/M4 anyway.
10-31-2014, 03:52 AM | #483 | |
Rep 963
eas, journal, oil, rod bearings |
