BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 340i wheel recommendations
ARMA SPEED
      11-01-2022, 03:29 PM   #1
Ivilla035
114
Drives: 2016 340i RWD
Hello!
I own a 2016 340i RWD. I’ve been looking at wheels, not totally sure as to where to look. Looking for a set up around 300 a wheel. Any good recommendations? Any pictures with suspension? I have H&R sport springs I’m gonna throw on. I’ve been looking at possible options….
Apex ARC 8
ESR sr05
Kansei KNP
Rotiform RSE
BBS XR
Also not sure about specs. 19? What offset also. Sorry I’m new to this.
      11-02-2022, 09:18 AM   #2
midxotic
midxotic's Avatar
199
Drives: 2011 E90 M3
2018 BMW 340ix  [9.50]
I would check out the fitment guides for the F30 on Apex's website to give you a better idea on wheel specs.
I recommend 9" wide wheels with +30 offset for the front, and either 9.5" wide with +35 or 10" wide with +40 for the rear. 18" or 19" is completely your preference, I've had both on my 340ix and prefer the 18s.
      11-02-2022, 09:20 AM   #3
Ivilla035
114
No rubbing with either? I don’t wanna go too wide, but I think I want to run 245 in the front and 275 in the rear with little to no stretch.
      11-02-2022, 09:43 AM   #4
midxotic
midxotic's Avatar
199
Drives: 2011 E90 M3
I was on 19x9 +29 235/40 front and 19x10 +40 265/35 rear, zero rubbing and fitment was flush. I've seen people run 245/35 front and 275/35 rear on the same setup with no rub either as well. Here's a picture of my setup:
      11-02-2022, 02:47 PM   #5
Ivilla035
114
WOW. That is insane. If i run 18x9.5, would 22 offset be too much?
      11-02-2022, 03:01 PM   #6
midxotic
midxotic's Avatar
199
Drives: 2011 E90 M3
those specs will poke out about a half inch more than the wheels I have pictured. They will clear suspension components but will probably need a decent amount of camber to tuck into the fender. I would try to find somebody that has run similar specs and see what suspension modifications they had to do.
      11-02-2022, 03:11 PM   #7
Ivilla035
114
Yea I have no idea. I'll be lowering the car, but the Kansei wheels only come with 22 offset. Pain in the butt.
      11-02-2022, 09:33 PM   #8
johnung
This article below can be helpful to explain offset. Remember that the higher the number the further that the wheel goes into the wheel well. A lower offset means that the wheel pokes out more from the wheel well. A typical stock square setup on an F30 is 18"x 8.0" ET34.
https://www.turnermotorsport.com/t-wheel_guide
suspension, wheels
