Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > DYI: Easiest way to get 1b file and generate FSC codes for CIC navi map update
      04-26-2018, 08:47 PM   #67
opjose
opjose's Avatar
242
Drives: 335xi
Mine never rebooted nor gave any indication of a change.
I plugged in the USB key, waited 3 minutes with the car running, took it inside and found the file and the batch file on the drive.
The script executes on the CIC and causes the HEX file and batch files to be generated and written back to the USB drive/key.
      04-27-2018, 02:49 AM   #68
E90M3DE
Drives: E90 M3
not working on DVD either
....so I burned the 1st USB stick's maps data to a DVD+R DL. Inserted into car's reader, and car recognizes map update. Yay, I think. Enter FSC code.....wrong FSC code. Not sure what I'm doing wrong here
      04-27-2018, 11:15 AM   #69
Davll
Drives: E70 X5 35d
Wow, looking forward to doing this. I successfully pulled my 1b file and generated an FSC code, just need some time to load the maps.
Is there any reason not to choose a lifetime FSC?
      04-27-2018, 02:01 PM   #70
lnxguy
Drives: 2009 335D
No and the 2018 maps are going to be the last ones released for the e90, so really it doesn't matter.
'09 335D
      04-28-2018, 05:08 AM   #71
vox_de_hg
Drives: E91 318d luxe
Unhappy
Originally Posted by theglennster View Post
vox_de_hg
I think I know why your install is not working, the files you have downloaded (BMW Road Map Premium Europe West 2018-1.7z) is for the 3 USB setup. To confirm this is the case look at the files I suspect it is split up into 3 folders USB1 USB2 USB3 intended for 3 DVD or 3 individual USB installations.
I used a different single USB install. Try Download BMW ROAD MAP EUROPE WEST 2018-1 as zipped up in the original post :-
http://www.e90post.com/forums/attach...6&d=1517407334
Hope this helps you guys
Same result with this map invalid code
I even tried to format my 64Gb usb stick with FAT32 ==> same behavior.
my 1b.hex seems ok : a file size of 319 bytes, the content starts with 01 01 00 1B.
I don't understand where is the problem.....
      04-28-2018, 06:43 AM   #72
vox_de_hg
new test : trying to generate fsc using "by date" mode. Got 6 different codes from 6 date selections ==> no one is good. always "invalid code"
      04-28-2018, 10:57 AM   #73
opjose
opjose's Avatar
242
Drives: 335xi
By date is known to work only with a specific range of vins.
Now that you have your 1B file try the other program/method.
      04-29-2018, 01:45 AM   #74
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
OP .....THANK you for this!
I got mine going after a few questions...but really had no real issues.. There was a little confusion on my part...Ill elaborate..
When Unzipping with 7zip, you dont need to unzip them all... just unzip 001 and the rest will be included... the 4 USB folders will be 4-6 gb each when fully unzipped and ready to rock.
you definitely DONT need a 32 gb stick...an 8gb stick will work fine...you just have to have the files you want to load in the root in the order of loading them... easiest would be 2 8gb sticks....have one ready to go while you are loading the other
Car may shut off while loading, but thats not big deal if you are there...it will pick right up where it left off if you are there to reinsert the key (dont know what happens if it fully goes to sleep, wasnt willing to find out)
Also the key generating software is a touch finicky. have patience...go back and forth in the fields a little bit and it will all update fine.... it works, but its a hack so expect it to behave like one. Free and finicky is better than pay for perfect.
      04-29-2018, 07:10 AM   #75
vox_de_hg
I made some research and i think that this is dead for me to update my cic to 2018 map.
Seen on GPS Underground site :
2018-1 USB update only works for cars made after 03/2010
My car was built november 2009
Then
Cars made before 03/2010 with original firmware (no update since you bought the car), then you can ONLY update to 2014 map via DVDs, as the DVD version of 2015-2 map is NOT released at the moment.
We strongly recommend customers with cars made before 03/2010 to have your car firmware updated from local dealers in order to update the 2016-2 and future maps by USB memory stick.
So I have to update the firmware (but for what cost ?)......
      04-29-2018, 05:10 PM   #76
PhilipUK
Going topless
PhilipUK's Avatar
32
Drives: E93 335i, MX-5, RCZ R
Where did you get this information?
Philip
      04-29-2018, 07:46 PM   #77
eZpZ
Drives: 2010 E92 N54 xDrive
Then
Same issues as you, production date: 2009-12-16.
Please update on any progress, I would like to know the process of updating the firmware too.
      04-30-2018, 03:08 AM   #78
vox_de_hg
Better way is to contact your BMW local dealer and request for a quote...
      04-30-2018, 11:57 AM   #79
lnxguy
Drives: 2009 335D
Then
My car is a '09, 2008 build and with c1a module software, the map updates worked just fine...
'09 335D
      05-01-2018, 07:08 AM   #80
m_thompson
m_thompson's Avatar
Drives: M-Sport 128i, 328xi, 3.0CS
2009 128i  [0.00]
1972 3.0CS  [10.00]
Mine was build 07/2009. While it was still under warranty I saw a posting about the "shopping cart" bug in the NAV firmware. I complained to the dealer, and they upgraded the firmware to the post 03/2010 firmware. USB map upgrades work for me.
'09 128i - Black Sapphire Metallic\Coral Red\Glacier Silver\N51 DISA\6MT\Navigation\Premium\M-Sport\Heated seats\Xenon\Headlights\iPod\Smartphone\Euro Delivery
      05-03-2018, 02:20 PM   #81
rthery
France
Drives: E91 325d 2009
Hello everyone
I have a 325d of 2009 I want to recover the file 1B with the method mentioned above. I tried with 2 USB cards but I can not extract the file.
I would like to have your help please.
Thank you in advance
      05-04-2018, 11:41 AM   #82
lnxguy
Drives: 2009 335D
Originally Posted by rthery View Post
Hello everyone
Are you using the glovebox USB port?
'09 335D
      05-06-2018, 08:34 AM   #83
Minde18
Drives: BMW E91 318D 2010
Hello, maybe someone can help me to get FSC code? I have 1b file from my car, but then I add it on "BMW_CIC_FSC_Generator" I can't select region and maps.
      05-06-2018, 11:18 AM   #84
6ixSpd
Save the manuals!
6ixSpd's Avatar
6016
Drives: '16 M3, '23 718 Spyder
Whenever I launch the FSC_generator.EXE it just opens a MS DOS window which shuts itself down in one second. Any idea what is wrong here?
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
      05-06-2018, 02:35 PM   #85
opjose
opjose's Avatar
242
Drives: 335xi
It depends upon which generator you are using.
One is a command (what you called ms-dos) line program.
The Windows version launches a command to download support files.
The former must be run as administrator from the command line.
The latter may also need admin rights to run since it attempts to write files into the folder it was run from.
      05-07-2018, 04:46 AM   #86
PhilipUK
Going topless
PhilipUK's Avatar
32
I had this problem as well.
You need to change the Map Type dropdown from Premium to any of the other options, and then back again to Premium. At that point the Region and Maps fields can be selected.
It seems to be a bug in V1.01 of the Generator, but the above is an easy workaround.
Philip
      05-16-2018, 05:56 AM   #87
ExiizZ
Drives: E92
Hello maybe somebody can help me.
I am driving a E92 with CIC Navigation (Navi Prof).
I successfully got my 1B File.
I am trying to update my MAPS to Europe Premium West 2018.1 with (1x USB)
I generated about 5 different FSC (with and without lifetime) and so on.
I plug in the USB some seconds later the Navi Prof recognize the USBUpdate and want the FSC. But it altways says invalid FSC...
I tried the method with jaegers generator and the other one with changing the FSC.Bat to 0x28 0x10
Smb may know where the Problem is?
      05-19-2018, 02:35 AM   #88
ixxx686
Drives: BMW 328i
Thanks to everyone on this forum, and on this thread for the awesome instructions.
Today(a few minutes back) I was finally able to update my maps from 2013 to 2018 Premium NA, with the resources available on this thread.
I had to make many attempts in getting the car detect the USB stick. That was the only issue I faced. The FSC key from the generator worked like a charm, and once the car detected the memory stick(out of 8), the contents from all four folders were easily downloaded to the car system.
I found two things about the car- The idrive update software available for free in BMW's website can be used only from USB port under the armrest in the center.
For map upgrades or pulling the 1B-hex file, the USB port in the glovebox has to be used.
cic and idrive, cic code, fsc code
