TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > CIC Random Reboot / Restart
      11-30-2021, 09:07 AM   #1
narvp
narvp's Avatar
Drives: BMW E92 335d
2008 BMW 335d  [0.00]
My CIC Pro Nav i-Drive keeps restarting after start up and on the odd journey it would randomly restart numerous times over.
My Logic 7 system, DAB, FM/AM, External Audio, Music Collection, CD/DVD, NAV and Bluetooth Talk all work perfectly fine so I'm not sure if its a module in the MOST.
Kraiden mentioned about an orange defective fibre optic cable.
Do I try the MOST Loop Bridge?
Or would it be one of these units which I've stated above:
-SAT SIRIUS unit always goes bad, we will offer repair of this unit soon
-TCU TELEPHONE BLUETOOTH MODULE RECENTLY WE SEE TONS OF THEM FAILING!
- Logic7 Amplifier
- M-ASK CD unit (ASK)
- Navigation GPS
- AM/FM tuner
- CD itself main screen (CID)
- CD changer CDC
https://www.germanaudiotech.com/page...-sound-failure
What would you all recommend?
Thanks in advance,
Narv
      11-30-2021, 11:13 AM   #2
opjose
opjose's Avatar
242
Drives: 335xi
It is unlikely that an issue with the fiber optic loop is causing reboots.
A failing drive developing bad sectors or failing to start will hang I/O from the CIC and cause it to reboot or randomly shut off and restart.
You can test for the latter by pulling the drive and turning the CIC on.
If the reboots stop, albeit missing navigation and sat play, then the hard drive is to blame and must be replaced.
      12-01-2021, 01:50 AM   #3
narvp
narvp's Avatar
Hi opjose,
I forgot to mention that I did try removing the HDD and the system continued to reboot shortly after turning on ( both with the key in and without the key in).
I did think that may be the case until I removed the HDD.
Could it be a firmware / software issue?
I believe the system hasn't been updated since it left the factory back in late 2008 from looking at the maps.
Thanks
      12-01-2021, 10:32 AM   #4
opjose
opjose's Avatar
242
Drives: 335xi
With the hard drive removed the system is only working from flash memory, which is unlikely to become corrupt.
You are down to an issue with the electronics, e.g, old or aging capacitors, overdriven transistors, shorts, supply issues, spurious signals, etc.
      12-03-2021, 10:34 AM   #5
blue335xi
blue335xi's Avatar
Drives: 2008 335i
Im having same issue cic resets it self or it wont boot on start up and comes back up later and after short time it resets again, i purchased new hard drive and cloned the old one and still same problem I think cic is bad and need to be replaced many used units on ebay just have to learn how to program and code. I heard getting nav to work on used unit is hardest part.
      12-03-2021, 01:30 PM   #6
opjose
opjose's Avatar
242
Drives: 335xi
Did you try with no hard drive in place?
If not try that first.
      12-06-2021, 04:20 AM   #7
narvp
narvp's Avatar
Yes I did try with no hard drive in place and it continued to reboot
I have been having issues with the DAB radio since I last posted so I'm starting to believe it's that module in the MOST.
      12-06-2021, 04:21 AM   #8
narvp
narvp's Avatar
Ah right.
I only ran the CIC with the hard drive out for about 5 minutes to see if it would reboot.
Should I try it for longer?
Or do you think it is worth trying the software update as I've seen many others having success with that?
      11-25-2023, 03:41 PM   #9
ian3924
ian3924's Avatar
185
Drives: 2010 E90 335i 6MT
Bump did you ever solve this?
      11-25-2023, 09:28 PM   #10
ian3924
ian3924's Avatar
185
Im having the same issue where my idrive will get to the BMW logo, go black and try to load back up a few seconds later only to go black again, within the few seconds before rebooting. If my Bluetooth is connected music will still play for a second so im guessing my fault is somewhere in the head unit/radio?
I've checked the fuses and pulled the hard drive without solving the issue. Would an aftermarket idrive get my music working? This one in this video seems reasonable and retains all oem functions with the original idrive screen (@7:52).
      12-01-2023, 11:41 AM   #11
ian3924
ian3924's Avatar
185
Fixed by swapping out the radio unit and having it coded. Haven’t been able to get the Navi working will need a icom cable to get it updated apparently
      01-16-2024, 12:29 PM   #12
Bimmer_Engineer
Bimmer_Engineer's Avatar
1044
Drives: 2007 335i
Heyo...having a similar issue periodically with my '07 CCC i-drive. Looked at the youtube video you posted above but after reading the description of that screen it appears that it just links to the i-drive head unit. Is this why you decided to just go with a swapped head unit? Was the unit you bought "refurbished"?
