The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > Combox in the car but no bluetooth
      02-21-2022, 09:57 AM   #1
Naitsirk1997
Drives: Bmw 330E M-Sport 2017
Hi there, i have an e91 2012 with a combox in it and im wondering if its possible to get bluetooth on it, as of right now im unsure if it actually supports it or not but i can't see any bluetooth options in the car unless i go into the service menu.
606 Navigation System Business
620 Voice Input System
698 Area-code 2
6FL Usb-/audio Interface
6UH Traffic Information
6VC Control Combox
7KD Navigation Business
This is what i found when decoding my vin that seems to be related to the cic and i drive.
If anyone could help me get bluetooth audio in my car that would be much appreciated
Also if this is the wrong place to post this please let me know so i can post it in the right spot
      02-21-2022, 07:51 PM   #2
Mspbcguy
14
Drives: 2011 E93
What model combox. I believe it only works with the BN2000
      02-21-2022, 10:45 PM   #3
smass
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
I think you can code in Bluetooth and add the missing Bluetooth antenna.
      02-22-2022, 03:39 AM   #4
Naitsirk1997
I just ordered the Bluetooth antenna, and a dcan cable. Also have a icom cable on the way. Do you have any experience with coding it?
      02-22-2022, 03:40 AM   #5
Naitsirk1997
I can check what model it is when I get home, but I also heard from someone that I might need to update the cic, which I have no idea where to get cause the bmw update site just throws me an error when I input my vin
      02-22-2022, 12:57 PM   #6
Luper52
Luper52's Avatar
Drives: 2007 BMW 335i E90
2007 BMW 335i  [10.00]
In the iDrive menu can you see Bluetooth Devices under Multimedia?
If you found my post helpful, please consider hitting the 'Appreciate' button
Instagram - YouTube
      02-22-2022, 11:21 PM   #7
Naitsirk1997
Sadly no
      02-23-2022, 10:56 AM   #8
Luper52
Luper52's Avatar
If you have a combox from the factory then it must be possible. When I retrofitted combox to my car I changed the radio preparation type in my VO while troubleshooting. This would enable the Bluetooth multimedia menu even without my combox connected to the MOST config, so you might try that. Off the top of my head I believe it was one of the $6xx VO codes.
Instagram - YouTube
      02-23-2022, 11:43 AM   #9
Naitsirk1997
I'm fairly new to coding and such so if possible could you help me?
      02-23-2022, 12:16 PM   #10
Luper52
Luper52's Avatar
Just look at combox retrofit tutorials. They will all address changing the VO. There are 3 different radio configs that you can try, and none of them will hurt to try.
It's been 2 years since I last messed with it and I'm quite busy at the moment unfortunately so I don't remember specifics. I may be able to get on later and look but like I said I have a lot going on.
Instagram - YouTube
      02-23-2022, 02:57 PM   #11
Naitsirk1997
I get my dcan cable on Friday so I will post back if I manage to fix it, and how I fixed it so that maybe someone in the same situation might be able to fix it also
      03-14-2022, 07:42 PM   #12
jas25pam
Drives: 2009 335i E92
2009 335i  [0.00]
Bluetooth antenna
Where is the Bluetooth antenna located?
      03-14-2022, 10:56 PM   #13
smass
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
Factory it is under the driver's kick panel. But you may not have the wiring. If not, just get an eBay antenna and leave it in the trunk. Lots of people do it that way.
      03-15-2022, 07:23 AM   #14
neilvan
neilvan's Avatar
858
Drives: 09 E90 335i M-Sport 6MT RWD
My brothers car had a similar situation; 09 with MULF but no bluetooth.
I grabbed the antenna+wiring and the mic wiring from a pick n pull car and just wired it in. His car is non-nav(with nav your have voice input so mic wiring will be there). From that just code the vo to bluetooth then update the radio and voila
      07-21-2022, 06:54 AM   #15
gokhanb
Drives: BMW 320D
same in my car, combox has no bluetooth :/
I am very knowledgeable about this.
Which antenna should I buy?
Which cable and which program is required for coding?
So many questions in my mind
Is the attached bluetooth antenna suitable?
      07-25-2022, 11:10 PM   #16
AWDBooSTIn90
Nomore
AWDBooSTIn90's Avatar
Drives: 335i Coupe 6MT N54
I wasn't aware of any combox multimedia's without Bluetooth. It needs to be VO coded to activate and the antenna itself added if non i-drive.
the blue plug on the bmw stuff is usually always the gps antenna signal. because some cars have the gps antenna plug into the combox, like mine, and the usb, gps, bluetooth phone, bluetooth audio, and all the song info like title, singer, album art, etc over the Fiber Optic cables to the CIC Headunit.
NBT has everything plugged in the back and normal newer things like a built in bluetooth antenna and no need for any external modules like a combox on the newer NBT's which is a major advantage for retrofitting.
But as far as a i remember that will work but you might have to shave the locator tab off the connector bc the stock Bluetooth Cable is the standard purple color. I believe there's actually a Euro Car color code for these cables. that is the correct style end and the right idea. however you might even have a bluetooth antenna if you have the phone prep package or the bluetooth phone calling option or voice guidance option already..
google combox retrofit VO coding and basically add any of the missing features from your car's current option list and only delete something from the VO list if there's a newer/upgraded option being added.
      08-16-2023, 08:48 AM   #17
ahmetcanack
Drives: E90 320D
What happened? Did you manage to activate bluetooth. I am in a similar situation, I have bn2000 but no mic interface and bluetooth antenna. I would like to code bluetooth. I will try to code this weekend when I get my car from the shop. How should i proceed?
What should be my first step?
What do you all suggest?
      08-17-2023, 02:25 AM   #18
ptpending
ptpending's Avatar
456
Drives: e91
the antenna on picture will work
their connector is bluegreen - this is universal coded connector, it compatible with combox beige bluetooth connector
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes.
      01-04-2024, 01:24 AM   #19
polarnight
Drives: BMW 3-Series E90 320D
Hey guys!
I have recently bought a 2010 20D e90 with business navigation only with aux, and a cd player.
It has the smaller display.
I really want to add bluetooth/ipod connection.
Do i need to buy a combox for this and fit in the trunk and also do the coding with NCS? Or is it already fitted and I just need to code the car?
How do I know if it can do Bluetooth?
Thanks for the replies guys!
      01-04-2024, 05:18 AM   #20
ptpending
ptpending's Avatar
456
Drives: e91
if you want a bluetooth streaming AND bluetooth calling and ipod connection via usb - you need combox
if you want only bluetooth calling and ipod connection via usb, you can consider mulf2high or combox, mulf2high is bit cheaper
you need module, wiring and coding of the module AND headunit to enable these functions
      01-04-2024, 06:25 AM   #21
polarnight
Thank you for your fast reply!
Well, i would like get both of them (Bluetooth calling/music, Ipod)
I'm gonna check the trunk, so I can see what I have there.
Gonna try to look for combox here in Hungary.
What headunit do you mean though? I have the little CIC Business Nav.
Also, what coding do I need to do?
Thank you!
      01-04-2024, 09:05 AM   #22
ptpending
ptpending's Avatar
456
Drives: e91
there is a special section on this forum about coding, you can dig in topics in it
i can sell you wiring kit to retrofit combox with bluetooth functions ( without USB cables)
the module you can source on ebay
the headunit which needs coding is CIC MID and combox itself
