2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum What did you do to your 2 series today?
      03-28-2024, 04:08 PM   #5523
Dantesboyz
recovering e36er
Dantesboyz's Avatar
Drives: 2017 M240i Xdrive
This pump thingy arrived today...
I've also got plugs and vanos actuators on the preventative maintenance list, that will be done this weekend, if not tonight.
Motor is still hot though...
Changed oil last weekend, still need to send the sample to Blackstone
2017 F22 M240i, Xdrive, M Performance Package
Active Autowerke Downpipe, Dinan Carbon Fiber Intake, Dinan Carbon Fiber Turbo Inlet, Dinan Mid-pipe, xHP Flashtool, MHD Stage 2
To do next list- #1- Wheel Spacers & Tires, #2- B58 TU Pump, #3- Flex Fuel Kit
      03-31-2024, 03:53 PM   #5524
freakystyly
Drives: F22 B58 6MT
Was a nice warm sunny day for a change. So I did a driveway oil change.
Old oil was super watery and did the spoon under the faucet trick. Made a bit of a mess.
      04-02-2024, 10:49 PM   #5525
Rich.Wolfson
Thaumaturge
181
Drives: 2014 M235i
Spoon under the faucet trick?
///Rich
      04-03-2024, 05:01 AM   #5526
Hap
Hap's Avatar
153
Drives: 2018 240i
2018 M240i  [0.00]
Originally Posted by JMcLellan View Post
I gave in and put a front plate on my car. This removes that nervous feeling I get when I drive by cops here in MN (where front plates are required) though I have not heard of anyone getting pulled over for not having a front plate. I really like the product that Sto n Sho has making it so easy to take the plate and mount on and off. Definitely starting slow with the mods. A couple weeks back I had the full front and the rockers PPF'ed, and window tint done. Next up is wheel spacers.
Nice snow blower !
JMcLellan2067.50
      04-03-2024, 08:34 AM   #5527
AM20 BMW
AM20 BMW's Avatar
170
Drives: BMW 218i M Sport
Installed AutoTecknic Gloss Black ignition button with IND-Distribution Silver ignition bezel. Absolutely love it 🔥
      04-03-2024, 10:39 AM   #5528
kenken662
kenken662's Avatar
Drives: 21 F22 M240i 6MT RWD Sunset Or
240IR wing installed 😍
      04-06-2024, 10:54 PM   #5529
WolfGTI
WolfGTI's Avatar
Drives: '17 F22,15 E84 M Sport,02 R53
2017 BMW M240i  [0.00]
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
Acquired a stablemate for it.
Integrated Engineering engine mounts, Dinan CAI, AA catted DP, Remus resonated cat back.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD.
Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r).
Appreciate 9
E46ZHP254.00
JMcLellan2067.50
dradernh4414.50
qlaval52.50
hk2354.50
      04-07-2024, 03:58 PM   #5530
freakystyly
Drives: F22 B58 6MT
Put the summer wheels on. I forgot how much of a difference they make with braking, lateral grip, fuel economy, etc.
Coded out the EDC but left the adaptive shocks on. It's too nice out today. It was odd, the module was in a Styrofoam sleeve, not even bolted to the car. Will do the swap to Koni sports another weekend.
///Rich
It's when the flow is spraying uncontrollably in all directions like if there was an upturned spoon under it. It wasn't that bad, maybe lost half a quart.
      04-08-2024, 05:33 AM   #5531
amutti
97
Drives: 2021 Convertible M240i Xdrive
After getting the $1800 quote from the dealer, I was motivated to do the brakes myself… first time changing Brembo brakes and undeniably the easiest brake job I’ve ever done.
dradernh4414.50
      04-08-2024, 09:23 AM   #5532
jzeiler4
jzeiler4's Avatar
Drives: 2021 M240i xDrive vert
You got your car about the same time I did. How many miles on it to need a brake job? Or were you just getting away from the dusty stock pads.
      04-08-2024, 10:00 AM   #5533
JMcLellan
JMcLellan's Avatar
Drives: 2024 M2
Sweet! What are the details on this beauty?
2024 M2
2019 M240i- Sold
qlaval52.50
      04-08-2024, 10:02 AM   #5534
amutti
97
I’m at 35k. The last time I went for an oil and brake fluid change the dealer tried to panic me about the brake pads. Said I had a few hundred miles left on the rear and 1,000 or so miles on the fronts. In reality, the thinnest rear pads had a little more than 2mm and the front thinnest had more than 5mm, so not an emergency. All four rotors were +2mm over min thickness.
I replaced pads and rotors, front and back, but left the sensors since they hadn’t tripped.
      04-08-2024, 07:43 PM   #5535
jzeiler4
jzeiler4's Avatar
Thanks, I have just turned over 26,000 (Retired no commute) so I guess I have a ways to go.
      04-08-2024, 08:19 PM   #5536
WolfGTI
WolfGTI's Avatar
2015 BMW X1  [0.00]
Thank you.
It's a Gentian Blue 2023 GT4, built in late May 2023, original owner took possession in early July 2023. The original owner bought it, put 1800 miles on it and traded it 2 weeks ago for a 911 Dakar.
It's got the carbon buckets and Chrono pack as well as stitching in yellow. I'll post up some pics.
Appreciate 6
dradernh4414.50
E46ZHP254.00
JMcLellan2067.50
qlaval52.50
hk2354.50
      04-09-2024, 08:13 AM   #5537
JMcLellan
JMcLellan's Avatar
Drives: 2024 M2
Thank you.
That thing is really nice. Would love to hear how it drives. I'm sure it's a blast.
2024 M2
2019 M240i- Sold
WolfGTI716.00
      04-09-2024, 06:51 PM   #5538
WolfGTI
WolfGTI's Avatar
2015 BMW X1  [0.00]
Thank you, for me it's a dream come true and my automotive bucket list pretty much fulfilled. Initial impression, suspension is much better sorted than my M240i with Ohlins and the 240i really sticks. Power wise it doesn't have the low down pull of my tuned M240i but above 4k it hauls and the noise is damn near intoxicating, and that's to be expected the lower weight helps it feel even more agile.
The throttle response of the NA flat 6, is really impressive, exhaust note is ok, I intend to address that once my wallet stops self immolating.
JMcLellan2067.50
qlaval52.50
      04-10-2024, 02:41 PM   #5539
ckosiek
18
Drives: M240i
New tires for the summer setup
Michelin PSS. 245/40 18 square
Alutec wheels 18x8. ET 43
      04-10-2024, 04:59 PM   #5540
NKOTB2015
21
Drives: Lexus LS460, Toyota Sequoia, B
Done some cheap, simple add-ons..
-Red start/stop button. Comes w a tiny glob of sticky putty but easiest way to remove the stock button is to melt one end of a hot glue stick, stick it on, let it cool, then use that to yank the old button out.
-Installed a wireless charger. My car had one of those useless coin trays..got rid of it and also removed the bottom housing of the wireless charger and used double sided tape to stick it in place. Otherwise, the charger is wedged up against the bottom of the dash and you won't have clearance to properly place your phone on the charger. Works well.
-Added a phone holder. Installed w 4 set-screws.
-Added knock-off pedal covers. Fits nice and tight and super easy to install.
      04-10-2024, 05:20 PM   #5541
NKOTB2015
21
Umm..you gonna keep both spoilers on there?? Is that a "thing"?
      04-10-2024, 05:22 PM   #5542
kenken662
kenken662's Avatar
Why would I take off the integrated one? It’s body color anyways
      04-10-2024, 05:23 PM   #5543
kenken662
kenken662's Avatar
245 40 fit on front without rubbing?
      04-10-2024, 06:05 PM   #5544
NKOTB2015
21
Just asking..you do what you like with your car imo. Just looked odd to me is all
2addicts
