03-26-2020, 03:11 AM | #1 |
Rep 6
2015 BMW F30 335i N55 MISFIRE BUT NO CODES!
Hey guys, so I just got a 25k miles engine put into my 67k miles 335i 2015, and after I took it out the shop, 200 miles later I start getting a misfire and the car drives rough! The only code for the check engine light I get is that I need a new o2 sensor because it's bad, I ordered another 1. All we used from the 25k miles engine was the block, and everything else was used from the old engine that locked on me. we used same coils and plugs from my old engine, but I had just gotten new plugs for my old engine a month before it stopped on me.
Current Mods: Catless Downpipe Stage 1 93 Bootmod3 VRSF Chargepipe |
03-26-2020, 04:00 AM | #3 | |
Rep 474
J. D. Cordier
03-26-2020, 06:38 AM | #4 |
Rep 919
The 02 code could be for a variety of things upstream... things like clogged air filter or filter; failing fuel pump?
As asked, what was wrong before. Had you overheated and just replaced your warped block? You sure cylinder head wasn't cracked? There are so many things, and it could be as simple as something left unplugged. If it was me, I'd drink something, vape, and stare at the engine with a good led flashlight and hope I find a loose connector. Some hide very well.
03-25-2024, 01:43 PM | #5 |
13
Rep 38
Same thing happened to me rn. My car locked up on my mechanic after doing OFHG. He replaced motor and he has been test driving last few days. I called today to pick up and he says that the it is misfiring but it has new sparks and coils and everything. What was the issue and how was it solved?
03-25-2024, 02:23 PM | #6 |
Rep 7,484
Immediately I thought VANOS but it could be any number of things:
https://www.e90post.com/forums/showthread.php?t=914577 |
bmw, f30, misfire |
