17" or 18" for a daily drive e91 in Philadelphia
12-02-2020, 04:34 PM | #1 |
198
Rep 331
Drives: 2022 i4 eDrive 40 mSport
I bought a lovely 2006 e91 about two months ago, and it's rolling on stock 16" wheels with all season tires. The car is a daily driver, mostly taking the kids to school (at least in the pre-covid days) as well as running errands, along with the occasional long trip. I plan to put winter tires on the stock wheels, and buy a set of larger wheels in the spring with summer tires. I am torn between 17" and 18" for the summer tires: as the subject says, I am in Philadelphia, and the roads are apocalyptically bad. While I think the 18's will likely look better, I fear that ride comfort will really suffer.
All things being equal, which would you choose? I would love to hear from folks who live close by (or in areas with similarly shitty roads) and have gone through a similar calculus. Last edited by smatanovic; 12-03-2020 at 10:30 AM.. Reason: Spelling |
12-03-2020, 08:29 AM | #2 | |
72
Rep 256
Personally, I think the 18's are the perfect size for the e9x platform. Pair that with a better tire than run flats and you should be good. Again, I don't know how noticeable the ride quality would be if you went 17's instead. |
12-03-2020, 10:26 AM | #3 | |
198
Rep 331
12-05-2020, 11:38 AM | #4 |
28
Rep 62
I'm running 18s with non run flats in the Philly area and it's OK. The biggest thing is to slow down for the more massive potholes to avoid bending a rim. The right tires with a sidewall that protects the rim will help too.
I have a set of style 400 rims off an F30 (square setup) if you're looking to go with 18s. |
12-06-2020, 04:56 PM | #5 | |
198
Rep 331
12-06-2020, 06:37 PM | #6 |
69
Rep 34
If you’re interested, I’ve got a set of 19 inch 313s I’m looking to sell off my e91. Big tires are within 1% so works on xdrive as well (my e91 is an xdrive).
Ride quality was very good but I know this wasn’t even on your list. My car is lci which impacts offset? Don’t know if these would work. I’m in Philly so there’s that! Marty |
12-07-2020, 01:06 PM | #7 | |
198
Rep 331
12-24-2020, 05:31 PM | #8 | |
Rep 35
12-29-2020, 07:06 AM | #9 |
198
Rep 331
12-30-2020, 09:35 AM | #11 |
198
Rep 331
12-30-2020, 06:37 PM | #12 | |
Slow M3 Driver
229
Rep 733
Or style 286 in the warmer months
2014 Citrin Schwarz Metallic M5 2005 Interlagos Blau Metallic M3 |
01-15-2021, 10:37 PM | #13 | |
Rep 783
Drives: 2010 328ix E91, 2011 128i E82
The ride was bone-jarring on any obstructions. I hit one pot hole so hard it reset a bunch of electronics on the car and set off all kinds of codes. It bent the rim (although it was still holding air) and, of course, that is when I found out I could not find a replacement as that size had been discontinued. After about a year of that, I went with 17 inch Style 66 wheels (from early 2000s M5 and 540) with non-run-flat wheels and it is so much better. I had ditched the run-flats on my Corvette years ago but, as I said, the E91 is my daily so I opted for the run-flats. I will never buy run-flats again - the ride is so terrible. I'm better off with a jack and a compressor in the car and a AAA card in my wallet. The 18 inch ASA AR1s: The 17 inch Style 66s: |
01-29-2021, 11:50 AM | #14 |
198
Rep 331
Maaaaan, those AR1's are gorgeous. Thinking of them in 17".
01-29-2021, 07:32 PM | #15 |
Rep 783
I had put them in 17" on my son's Mazda 6 as a birthday gift to him a couple of years before. The 18s have a deeper edge on the rim, naturally, and look a little better but they are really nice wheels for the price. I was not crazy about the fake bolt heads - make it harder to clean and will eventually have the plastic chrome flake off. I have my 18s sitting on a high shelf in the garage in case I ever want to switch things up again.
02-01-2021, 12:49 PM | #16 | |
198
Rep 331
02-01-2021, 08:45 PM | #17 |
Rep 783
Yes, well that is why they were less expensive than the 17s - on closeout. When I bent the one, I tried finding a replacement but no luck. The damaged one held air, was not unbalanced, and is barely noticeable, so it is usable and certainly fixable. I kept them as I really do like them and might one day use them again. Or at least that is what car guys tell themselves about old parts.
I think something comparable are the Alzor Style 881s sold by ECS and very reasonably priced. |
02-02-2021, 10:19 AM | #18 |
198
Rep 331
It sounds, though, like you recommend sticking with 17's?
02-02-2021, 02:19 PM | #19 |
Rep 783
I think the 18s with non-run-flats would have been okay but I didn't want to spring for another set of 18 in tires and find out it still wasn't right. The wife is remarkably tolerant of my car parts habit but . . . Also, I am not in the crowd that always wants bigger and bigger wheels - function, not form, is primary, and for a daily driver, the 17s make more sense. And, I came across the Style 66s and really liked the look and the idea of running genuine BMW wheels (even if they are from a different model/year). |
02-05-2021, 10:55 AM | #20 | |
198
Rep 331
02-28-2021, 08:20 AM | #21 |
Rep 4,084
OP if you decide on 17s and want to stick with RFTs I have a set of 225/45/17 pirelli Cinturatos off my mini clubman with about 21k on them. Plenty of life tho. if you're down for taking a ride up to westchester. Not asking anything for them. Just want them out of the garage. I don't know if that size would be a perfect fit but even if it isn't I don't think it would affect the speedo too much.
7/18/09- I pick up my baby- 2009 E92 335i Xdrive, Space Gray over Coral Red. Premium Pkg, Cold Weather Pkg, M-Sport Pkg, 193Ms, Gloss Black grills, Custom Gloss Black Mirrors, Performance shift and E-brake boot, M3 spoiler, Euro fog switch, gloss black interior tim, Coco-Mats (red/black), H&R coilovers, 19'' Alufelgen SF-71s......
