09-13-2018, 03:34 PM | #1 |
¯\_(ツ)_/¯
950
Rep 1,763
DIY VIDEO: N20 Belt and Tensioner Replacement
______________________________________________ How to change the belt and belt tensioner on a BMW with an N20/N26 engine. Might be a similar procedure for the the newer B48 engine. For 320, 328, 228, 428 models. Tools required: - Torque wrench for 14 ft/lbs - 5 to 8" ratchet extension - Ratchet - 16mm socket - E10 socket - Flathead screwdriver - Magnetic tool (optional but very handy) - metal pin or ~4mm allen key to hold old tensioners tension - Part number for the F30 328i is 11287618848 for the belt and 11287594969 for the tensioner
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC |
09-13-2018, 05:25 PM | #3 | |
¯\_(ツ)_/¯
950
Rep 1,763
Just under 65k on it. It was never done per the records so I figured it was due for change. The belt wasn't too bad. I would say 10-20k more miles on it would be good before the outer part would start getting work out to the point of being able to be torn. The tensioner I did notice too a little bit less effort to turn compared to the new one. There was a tiny bit of bearing noise/resistant when spun by hand so I'd give it 5-10k more miles. For only costing $42 tensioner/$13 belt it's cheap insurance.
09-13-2018, 06:03 PM | #4 | ||
Rep 5,460
Drives: F30
Im at 59k and will be completing this at 70k per your instructions. Much appreciated. |
09-13-2018, 06:07 PM | #5 |
¯\_(ツ)_/¯
950
Rep 1,763
Just be sure to take a peep with a flashlight to see how the belt looks (shiny outside, any cracks on the ribs and any cracks/tears overall)
sspade2471.00 |
09-13-2018, 07:37 PM | #7 |
¯\_(ツ)_/¯
950
Rep 1,763
Haha who knows. Fortunately I've been wrenching on cars for seven years or so so a lot a lot of money saved. Thanks man!
03-06-2019, 12:50 AM | #8 |
69
Rep 96
Drives: 2013 BMW 328i xDrive
I've heard that early 2013 production 328i's may have belt/ belt tensioner/ tensioner pulley problems but was fixed for the late 2013 models.
Does anyone know what production month in 2013 they changed/fixed this issue?
Bootmod3 stg. 2 FBO |
12-30-2019, 07:00 AM | #9 | |
¯\_(ツ)_/¯
950
Rep 1,763
Bump for anyone looking to replace their belt and pulley!
NicksN20F3069.00 |
320, 328, belt, diy, install, installation, n20, repair, replacement, tensioner |
