Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Lug bolts
      11-18-2013, 01:14 PM   #1
bmwarg
Drives: 2008 E90 335i, 2012 E70 50i
Lug bolts
Has anyone tried the no rust lug bolts from World Motorsports? Are they any good?
http://www.world-motorsports.com/b/5965246011
Any recommendation for replacing my rusted lug bolts without breaking the bank? Gorilla?
2008 E90 335i: JB4 G5 ISO | BMS Pump Gas Backend Flash | ER Charge Pipe | n54Tuning DPs | ETS FMIC
      11-18-2013, 01:20 PM   #2
Dylanize
Captain Dutch Rudder
Dylanize's Avatar
204
Drives: AMG
Damn, didn't realized they ran that much... Need spacers? Just buy some spacers with extended lugs it aint much more. lol
No more E92 or E82
      11-18-2013, 02:39 PM   #3
_Sinister_
_Sinister_'s Avatar
Drives: Very Slow
Here you go
http://www.burgertuning.com/BMW_wheel_spacers.html
_Sinister_
      11-18-2013, 04:32 PM   #4
bmwarg
spacers
BMS spacers and bolts are nice, but really don't want to put spacers at the moment. I would like to get similar BMS bolts though.
      11-18-2013, 05:08 PM   #5
AzureHaze
AzureHaze's Avatar
Drives: 2011 335d Sport
Yes, BMS extended lug bolts are very good quality as I own a set. Contact Jason @ BMS and I'm pretty sure he'll sell them to you separately.
JBD @ 100% | KW ST Coilovers | M3 rep. front bumper | 888Concepts AE Upgrade | GP Thunder 7500k fogs | Cyba 4" carbon tips | BSW Stage 1 | APEX ARC-8 W/ Michelin PSS | Ziza LED interior | Weisslicht LED side lenses | Sprint Booster | Euro side mirrors | M-Sport semi-conversion | Coded | LOTS of carbon fiber
      11-19-2013, 02:39 AM   #6
1QuikWS6
No 55mph
1QuikWS6's Avatar
1621
Drives: F32 435ix MSport
I never really had any problems with the factory bolts rusting - I'm running stud kit/extended lugs now...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      11-19-2013, 12:23 PM   #7
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
http://otisincla.com/index.php?route...roduct_id=1164
http://otisincla.com/index.php?route...roduct_id=1165
      11-19-2013, 01:33 PM   #8
bmwarg
Thanks this seems to be just what I needed. Are they good for protecting against rust/oxidation? I think the rust happened after one car wash at the BMW dealership. I'm not sure why a car wash would cause the rusting/oxidation.
Jason at BMS only sells the bolts with spacers.
      11-19-2013, 01:55 PM   #9
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
I have never dealt with their bolts before, but they do sell locks that we've used, and the locks have been great.
      11-19-2013, 04:35 PM   #10
bmwarg
lug bolt length
It looks like both the Otis Inc and the Rad sold there have anti-oxidation coating. I am trying to order, but a little confused about the length. Your links showed 12x1.5mm, 26mm shank length. The Otis Inc LA rep recommended the 12x1.5mm, 28mm shank length for Rad or Otis Inc. bolts. For the wheel locks he recommended 12x1.5mm, 25mm for Otis or 12x1.5mm, 26mm for Rad. I'm also not sure if the Rad wheel lock is the same silver color as the Rad lug bolt, does anyone know?
So, what shank length should I be getting?
Also, the rep said Otis and Rad are equal, but especially for wheel locks is one better than the other? And aesthetically which is better: Otis black or the Rad silver color for OEM BMW sport wheels?
Thanks for your help!
      11-20-2013, 02:05 AM   #11
bmwarg
26 or 28mm length
I think part of the confusion may be what is highlighted by this posting: http://www.e90post.com/forums/showth...highlight=26mm
28mm shank length is equal to 26mm thread length. Any thoughts VWRwheels?
The wheel lock is M12x1.5x25, which probably means 25mm thread length. But is the 1mm too short bad?
      11-20-2013, 12:11 PM   #12
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
From the bottom of the cone to the end of the threaded portion of the bolt (shank length) should be 26-27mm. I don't think one is going to be better than the other though. Just depends on whether you want black bolts or silver bolts.
lug bolts, wheels
